Results 1 to 2 of 2
    Registered Member Two Rings
    Apr 03 2008
    Clutch questions?
    My car has 127k, original clutch. The clutch grabs really high, you only have to depress the clutch pedal about 1 - 2 inches to put it in gear. I don't know if that has anything to do with anything though. With the high miles, I do want to change the clutch. When i had my 02 Jetta 1.8t I was able to use a g60 single mass flywheel with a VR6 clutch. ECS sells this for the Jetta. I notice it is not offered under the clutch section for a Audi A4 1.8t. Can i not use the g60/vr6 combo? Or is anyone running this combo? Also, does anyone elses clutch grab as high as mine?
    His : 1989 BMW M3 - 2001 Audi A4 Avant - 1971 VW Baja Bug
    Hers : 2005 Xterra - 1989 Bmw 325ic
    FS: 1995 BMW 525i Touring
    Veteran Member Three Rings 2001A4QUATTRO's Avatar
    Jun 05 2007
    2001.5 A4 1.8TQMS
    Re: Clutch questions?
    stock clutch is really high. Go get a southbend racing clutch. Go Stage 3 or higher depending on your plans.
    Engine : Carbonio V2 Intake - RAI 3" TP - APR cat-back w/glass pack - APR TIP - Forge 007P - 00Black1.8T Heat shield - GIAC-X - APR Snub mount - RS4 motor mounts - SB Stage 4 w/DMFW - 034 Street trans mounts - Evolution Motorsports Phenolic spacer
    Braking : Centric Cryo Black Zinc / Hawk HPS (F+R)
    Exterior : Ultrasport 18" ET43 235/40/18 - RS4 grill - Debadged - S4 sideskirts and rear lip - E-codes/Philips+ HID
    Interior : AWE boost guage / vent
