Results 1 to 32 of 32
    Veteran Member Four Rings Redgoat's Avatar
    Sep 16 2005
    1.9 TDI Discussion
    Just curious if anyone has done this. I know Greg mentioned it in another thread, and I have had a friend/mechanic suggest it as well.
    Has anyone tried doing the 1.9 TDI long block and going to a 2.2 liter setup?
    What all would you need for this? I know the fueling is obviously different so it makes me wonder how and what you would need to swap out on the head. I dont think the heads on the 1.8 would match the 1.9 TDI or be sufficient enough for the 2.2 conversion. But I am not sure.
    Figured it would be nice and informative to open a thread up for discussion of this.
    -Karl
    NWQuattro - Northwest Audi Club
    USP CLUB MEMBER #8
    BetaAlphaTau member #10
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Re: 1.9 TDI Discussion
    Might want to talk to the B5 guys, or even Issam.
    Good luck finding a block for a reasonable price...
    -Doug
    Sep 16 2005
    Makes me wonder if the ALH block would line up.
    -Karl
    USP CLUB MEMBER #8
    May 20 2004
    More cars
    Never Land Ranch
    you wonder too much...
    SEXICAN
    2013 Q5 3.0T-DD
    2002 Honda Civic
    AMD/EPL Tial 605 B5 S4 SOLD
    Nov 14 2006
    600hp glorified Beetle, e-tron, 1G DSM
    Gig Harbor, WA
    You'd pretty much need to a complete drivetrain replacement. The gearing in the gas-powered models is too high for the low-revving TDI's. Not to mention the fueling system, ECU and all other components. Basically, you'd need a fill donor car.
    -Darrick
    Veteran Member Four Rings 1point8teeNW's Avatar
    Nov 11 2006
    North Webster, IN
    Quote Originally Posted by Capt. Obvious View Post
    I believe he's saying he'd use the block and lower rotating assembly from a 1.9TDI and using a 5 valve head. I also believe he's looking for a way to build a bigger "1.8t" than the 1.9 and 2.0 builds than have sprung up lately.
    Current - 2004 Pontiac GTO 6M *FOR SALE*
    Looking for - B6/7 S4 TIP or 6M
    Veteran Member Four Rings Groove1797's Avatar
    Apr 08 2004
    Your mom on a unicycle
    Eating Cheese Curds
    I wish I could find a ALH block for cheap
    4Runner, Rs5 and Alfa Guilia QV
    Sep 16 2005
    Quote Originally Posted by 1point8teeNW View Post
    Exactly!! I was thinking block and head.. bored out to a 2.2 With a MUCH BIGGER turbo
    Just not sure if the engine would bolt up.. what you would need for the fueling system etc.
    I would think that the driveline would hold up.. I mean heck, if it can hold up to the bigger power of the 2.0 BAT builds.. then it "should" be able to hold up to a 2.2 bigger turbo build. Just that the block being bigger on the 1.9 would be more suitable for bigger displacement. I am not sure though if the 1.9 head would flow more.. or if the 1.8 head would even bolt up to the 1.9 block
    -Karl
    USP CLUB MEMBER #8
    Sep 16 2005
    Quote Originally Posted by Groove1797 View Post
    Whats considered cheap?
    Link to ebay ad
    Even cheaper short block
    -Karl
    USP CLUB MEMBER #8
    Apr 08 2004
    Eating Cheese Curds
    The question is will it work
    Sep 16 2005
    exactly what I'm wondering..
    Reading other posts show that even the crank from a Automatic 1.8T to a Manual 1.8T is different.. so who knows.
    -Karl
    USP CLUB MEMBER #8
    Nov 11 2006
    North Webster, IN
    Well consider this.
    The VW'ers use the 1.9 crank in the 2.0 ABA and use a 16 valve head.
    we'd have to be 1.9 crank in the 1.8 block with 20 valve head only if the 1.9 block woudn't work for some reason.
    Sep 16 2005
    the main reason I am wondering this is to go to a 2.2L setup where as the 1.8 block is pushed to its size limits (safely) when bored out to a 2.0 .. so we could get more displacement with a 1.9 block to start out with.
    Now granted, if this does work, it might be cheaper easier instead of building the engine to a 2.0 to do a 1.9
    I am not a mechanical engineer by any means and don't possess a lot of knowledge when it comes to these things. So this is all just kinda thoughts and speculations.
    -Karl
    USP CLUB MEMBER #8
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Eurospec sells a 2.2. It uses a 1.9L TDI block with 100mm rods IIRC. A 2.2L would be $ with a 35r. It's 16mm taller then a 1.8L block but they say everything bolts up without issue. If I were to do it again, I would have had David build me one.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Registered User Four Rings
    Feb 26 2006
    Over 20! too many plant pots!
    Earth
    Send me a PM to discuss this further.
    Thanks
    Sep 16 2005
    cough... $6,890 ... cough
    -Karl
    USP CLUB MEMBER #8
    Sep 16 2005
    Quote Originally Posted by Issam@034 View Post
    Thanks
    PM sent
    -Karl
    USP CLUB MEMBER #8
    Mar 21 2006
    Lakeland, FL.
    I didn't say I'd buy a Eurospec motor but they sell them. Call David @Eurocode, or talk to the 034 guys.
    I'm back bitches!
    Sep 16 2005
    Quote Originally Posted by dirtybrd View Post
    I have tried Numerous times to try and get in contact with David with no luck at all. I sent a PM to Issam, so hopefully I can get some answers
    -Karl
    USP CLUB MEMBER #8
    Mar 21 2006
    Lakeland, FL.
    How did you try to get ahold of him?
    I'm back bitches!
    Sep 16 2005
    email
    -Karl
    USP CLUB MEMBER #8
    Mar 21 2006
    Lakeland, FL.
    Are you really serious about building one?
    I'm back bitches!
    Sep 16 2005
    More curious as to what it would entail etc.. its kind of a pipe dream right now.. but it will vary on cost etc. So I cant say at this time whether I am serious or not. It all depends I guess
    -Karl
    USP CLUB MEMBER #8
    Sep 16 2005
    I figured if we could get a thread going with enough discussion/details about it that it could be a possibility for others as well. Kinda like an alternative to the 2.0 Stroker
    -Karl
    USP CLUB MEMBER #8
    Mar 21 2006
    Lakeland, FL.
    I just got off the phone with David and he said the longer stroke of the 2.2 really kills the ability to rev. the motor and suggests just building a high revving 2.0. But said if you want it, he will build it, price was not discussed.
    I'm back bitches!
    Sep 16 2005
    Good to know. Thanks for that!!
    -Karl
    USP CLUB MEMBER #8
    Feb 26 2006
    Earth
    You can rev a 2.2 stroker motor.The bearing failure is a myth....that just keeps coming up month after month....
    2.2 20V - aint she sexy?
    Sep 16 2005
    That engine is pure sex!! What are the plans for it?
    -Karl
    USP CLUB MEMBER #8
    Oct 29 2005
    10speed
    San Francisco, CA
    Hey man you can make a 2.1 with a TDI crank and custom pistons. You would keep your block though, might want to do that instead, youd save a lot of $$
    - Clint
    Sep 16 2005
    I thought 2.0 was about at the limits ... hmmmm
    -Karl
    USP CLUB MEMBER #8
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Told you to talk to Issam
    -Doug
    Feb 26 2006
    Earth
    95.5mm crank in the 220mm block produces a 1.50 rod ratio.Too small for what he wants to do.
