Results 1 to 8 of 8
    Oct 23 2007
    2003 a6 4.2 - looking for aftermarket cat
    So my dealer just told that my cat is bad and it keeps tripping the MIL light. They won't cover it under the emissions warranty because apparently there is impact damge. I can't pass emissions without buying a new cat and they want $1700.00 for one. Any know of a source for good aftermarket cats that are cheaper?
    Senior Member Three Rings skiroad'r's Avatar
    Apr 21 2008
    2002 allroad Tip, 2005 Mazda 6 Wagon 5MT
    Central New Jersey
    Re: 2003 a6 4.2 - looking for aftermarket cat
    impact damage? did you run over something? Try [email protected] for a quote. He has OEM stuff for much cheaper than dealer retail.
    '02 allroad 2.7T Tip
    ASP Flash, 034 Snub Mount (DIY), VAST EFK (DIY), H-SPORTS (Hard)
    Anrott Gen II Front Airsprings (DIY), Magnaflow mufflers with 3.5" tips
    Summers: Yokohama Avid W4S/RS6 Reps
    Fog DRL's, Toggable 628 Relay, Tip Override Recode, Remote Window Recode, Clear Corners (DIY)
    Timing Belt DIY (at 60K miles), Tiptronic Drain & Refill Service DIY (at 62K miles)
    GET OEM PARTS HERE: http://www.europaparts.com/
    Veteran Member Four Rings Stampy's Avatar
    Oct 02 2007
    A6, A8, X5, etc
    Windy City
    What the hell did you hit? Did you actually see this damage? I might try another dealer for a second opinion.
    Village Idiot!!!
    (\__/)
    (")_(")
    lots of rings in my garage
    Oct 23 2007
    I personally don't remember hitting anything. I just have a fault code and you can't pass emissions in the state of Washington with any emissions related fault codes. I am going to a different dealer to see if they will cover it under warranty. If not I am going to have to replace it.
    Oct 02 2007
    A6, A8, X5, etc
    Windy City
    I would ask to be shown the damage too. I have never heard of this happening.....well ever actually. Especially to a C5 4.2
    Village Idiot!!!
    (\__/)
    (")_(")
    Veteran Member Four Rings oc-drop's Avatar
    Nov 20 2005
    B7 A4, C5 A6, 79 Camaro
    Newport to Rancho Sta Marg
    time for a whole new custom setup you can get 2 high flow cats on there instead =)
    ~Rick .. currently driving a B7 3.2 S-Line 6MT Dolphin Grey | DTMish | EuroGEAR CF Hood | H&R | sick halogen Ecodes | AZ Plate frame
    is it 4:20 yet?
    Oct 23 2007
    I went to an independent shop and had them put it up in the air to see the damage myself and there are some scrapes on the lower cat and the flex pipe is frayed but it's not really impact damage. I have a call into Audi USA and we'll see where that leads.
    Registered Member One Ring ming4.2's Avatar
    Jun 26 2008
    big little city
    I think it would be cheaper to just get custom exhaust. Ask an indy to give you a quote. That way you could get a less restrictive exhaust for the same price.
