Results 1 to 4 of 4
    Registered Member Two Rings
    May 29 2007
    louisville, ky
    Turbo set-up question
    will the atp gt3071r setup from a b5 work on my b6? except the ecu
    Feb 17 2005
    Sarasota, FL
    Re: Turbo set-up question
    Manifold yes, downpipe is different. If they made an inlet it will fit a bit differently around the headlight as well. Oil and coolant lines will work, ECU/tune most definitely will not
    May 29 2007
    louisville, ky
    so out of the whole kit all i will need is ecu and down pipe? everything else will line up and fit
    Veteran Member Four Rings mtbrider's Avatar
    Oct 31 2005
    Virginia
    Dont forget the inlet pipe like shawn said that may or may not work
    Some fast things and some slow things
    ~Josh~
