Results 1 to 35 of 35
    Senior Member Two Rings ekaufman's Avatar
    Jul 02 2007
    2008 Black A4 S-line
    Santa Monica
    Confirmed Drop with Neuspeed, Tein, & Eibach springs on sport suspension?
    I have done plenty of searching and found varying answers to this question. Im hoping some of you guys running this set up could chime in and put down some personal experience. The reason Im asking is that Ive read plenty of posts explaining how their drop was much more than the advertised/listed measurement.
    Here is what I have so far based on various posts and manufacturer sites for the drop on the stock sport suspension:
    Eibach: 0.5" F+R
    Tein: 1.5" F - 1.0" R
    Neuspeed: 0.75" F+R
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    Re: Confirmed Drop with Neuspeed, Tein, & Eibach springs on sport suspension?
    get coilovers duddeeeeee
    Nov 12 2007
    Grand Junction, CO
    Coils FTMFW. Gotta pay to play!
    Veteran Member Four Rings ibiski's Avatar
    May 21 2008
    Quote Originally Posted by ekaufman View Post
    Eibach: 0.5" F+R
    Neuspeed: 0.75" F+R
    Good info, thanks. I am planning on springs for my S-Line.
    Veteran Member Three Rings matttl16's Avatar
    Feb 25 2007
    2007 audi a4 and 2010 audi a3
    phoenix az
    i had spring... and my shocks went bad... so now i have coilovers... i would advise coilovers
    07 b7 a4 2.0t stage 3
    May 21 2008
    Anyone with sport suspension whose shocks wore out, or is it mainly people with regular susp?
    Registered Member Three Rings SGVA4's Avatar
    Mar 03 2008
    07 3.2 Quat SLine, 08 MKV SE
    626 SoCal
    supposely eibach will work well with sports suspension. I went with eibach/bilstein combo to be safe.
    save you a couple hundred bucks also I dont need to adjust my stance anyway
    Work Euroline FS/Falken/Cupra R/HID yellow fogs/H&R/Eibach/Bilstein/Apexi/Optic Black RS4 Grill
    Hoen plate bulbs/ZiZa city lights/RS4 foglight grill coming soon!!!
    "J Spec B7"
    May 21 2008
    Quote Originally Posted by SGVA4 View Post
    mind posting some pics?
    Jul 02 2007
    Santa Monica
    ^^ Definitely post some images.
    If the Eibachs drop you about 0.5" from the sport suspension, is that even worth it? How noticable will that drop be?
    I talked to tire rack about the Eibach springs on the sport shocks and they said I would be fine with their conservative drop. Just trying to decide if its worth it for another 1/2 inch.
    Jan 10 2007
    VA
    a spring/shock combo is what...$700. Coilovers are only $200-300 more. They not only give you adjustability, but they ride and handle better than a sping shock combo. Just save up or find a lightly used set.
    both sport and non-sport shocks will wear out quickly with lowering springs, sport shocks will just not wear out quite as fast.
    Veteran Member Three Rings outlaw77's Avatar
    Jun 19 2007
    2010 Camaro SS/RS 6.2 V8 Inferno Orange Metalic 400rwhp 400tq
    Langley BC Ca.
    I've had the h&r springs with stock sport suspension shocks for over 25,000kms now and the shocks are fine.
    07 Ibis White S-Line 6smt - APR 93,91,89 - APR snub mount - 19" Sportec Mono 10's - H&R springs - RS4 rear sway - RS4 pedals -
    May 21 2008
    That's the thing. If you're comparing coils to spring & shock combo, then price-wise it really is close to coils, however, the install is much less and you don't need corner balancing with springs. Most knowledgeable people from the industry I've talked to said the same thing: if you don't track your car, why spend money for coils? Coils were designed for tracking. Yes, your car will handle great, but at the same time you'll be sacrificing ride quality. From what I've read, the only exception here might be Stasis SS and PSS9's on softest damper setting (although I had PSS9's on my M3 on soft setting and wasn't too thrilled with the ride + they were well over $2000 with install and anther few hundred to take them out and put stock back on). I think the key issue here is to find springs with satisfactory drop, since there isn't any height adjustment options with them. I wouldn't worry about shocks wearing out unless the springs are used with stock, non-sport suspension.
    May 21 2008
    Quote Originally Posted by outlaw77 View Post
    please post some pics of the drop, thanks!
    Jul 02 2007
    Santa Monica
    Thanks for info ibiski. I got the same response from the guys at the dealership and people from tire rack, that as long as you put a conservative spring on a sport shock, you'll be fine.
    I knew a couple of people would post advice to get coilovers, but thats a huge over-kill just for aesthetics. Im not arguing that they are a bad idea. They are an unbelievable improvement, but for me, not worht the extra $600-$800 that I can put towards wheels and a grille.
    I would, however, like to see some images of different springs on the sport suspension if anyone has them.
    Senior Member Three Rings jejeclown's Avatar
    May 22 2008
    Carrera4S-dad LS460L-mom A4-me
    ny
    your better off spending the extra couple hundred bucks and getting the co's not only that but you could probably find a lightly used set of co's for the same money as the spring/shock combo.
    08 Audi A4 2.0T S-line Titanium pkg., Quattro, SE pkg. , convenience pkg., nav, tip, Phantom Black on black.
    Registered Member Three Rings turbo4s's Avatar
    Mar 27 2006
    AUDI B7 S4 / MKV GLI
    Eibach: 0.5" F+R = wrong, they are really 1"
    _______
    Artic White B7 S4 Fully Loaded
    Mods= Titanuim RS4 Grill
    Salsa Red MKV GLI Fully Loaded
    Mods= Revo Stage III KO4, Carbonio, AWE Full Exhaust, AWE FMIC, H&R spring & Sways, AWE Vent Guage,
    ECS Blacked Out Coners, ECS Snub Mount, KMD Fuel Pump, KMD Cam Follower
    Mar 27 2006
    _______
    Jul 02 2007
    Santa Monica
    Quote Originally Posted by turbo4s View Post
    Thanks man. Thats what I was referring to in the original post; the listed drops dont seem to be accurate.
    Anyone else?
    Active Member One Ring greenhornet's Avatar
    Feb 22 2008
    528i, 125cc vespa ciao
    Texas
    After buying the car, it had regular 16" and 2.5" gap between tire and lip on the front, on the back were almost 3". I got OEM 18" with 240,35 BF and the gap was almost the same, then I got newspeed springs and normal shocks. I paid $190.00 for the set and paid $200.00 more for the dealer to install them and service the car. The frt gap is about 1" and 1.5" back. A little bumpi but nothing significant. I had 5 people in the car and never touched the tires. Aligment did not change after the new springs (audi verified). This was done 3 months ago. Since then I got arround 10 offers to buy it. It looks awsome...... The only thing I neede to do is to re-program the settings of the rim and tire size in order to have the correct speed in the car computer. I do not have pictures at this moment but if you wait until tonight, I will post some of them. Eaven my woman likes it and she rides a 2006 525i
    Jul 02 2007
    Santa Monica
    turbo4s - are you on 18s with 235/40s?
    Feb 22 2008
    Texas
    Sorry for the typos . NEUSPEED, AWSOM, NEEDED
    Jun 19 2007
    Langley BC Ca.
    Quote Originally Posted by ibiski View Post
    no problem:
    May 21 2008
    Very nice! Gorgeous wheels.
    Jul 02 2007
    Santa Monica
    Anyone using the Neuspeed springs? They are listed at dropping the sport suspension a nice 0.75, which would be perfect. The probelm is turbo4s already posted that his Eibachs were actually 0.5" lower than advertised.
    Anyone have personal experience with these?
    May 21 2008
    no problem:
    any rubbing issues? what offset are you running?
    Mar 03 2008
    626 SoCal
    dont get neuspeed..they tend to sag and its bouncy as hell.
    Eibach is about an inch drop with sports suspension.
    If your car is a lease just buy the springs no need for shocks since you'll need to return the car anyways
    someone up there made a really nice point about coils. theres no need for them unless your tracking.
    the stance eibach pros give you will be just fine
    "J Spec B7"
    Veteran Member Four Rings audimeister's Avatar
    Jan 05 2006
    '07 A4 Avant S line Ti 6MT Quattro
    Oakland, CA
    Between my B6 and B7, I've had two coilover systems (Koni and Bilstein), sport suspension, stock suspension, and now Koni FSD.
    Coilovers are more "fiddly" and will cost more in money or aggravation. Just leveling and setting the height you want means the install is roughly 2x the effort of a spring/shock combo (unless you get lucky on your first try.) In almost all cases, coilovers ARE NOT HEIGHT ADJUSTABLE ON THE CAR. That means a new suspension reinstall anytime you want to raise or lower your height. Most are not damping adjustable on the car either, although the Bilsteins were, even with the car on the ground. Lots of coilovers develop noises as spring perches settle, loosen, etc.
    Springs go on perfectly, will give a desired drop, and work pretty well on the street. The Koni FSD+Eibach set is my favorite setup so far- 90% of the handling I had with Bilstein coils, and 4x the comfort. The roads in Houston's inner loop are getting so bad, coils are really not an option for me anymore.
    "Obsessed" is a word that the lazy use to describe the committed.
    Veteran Member Three Rings mksap11's Avatar
    Apr 06 2005
    Boston, MA
    Anyone else?
    Eibach Pro-Kit with Koni Yellows. One thing I like about Eibach is that they have Avant specific linear rate springs.
    I posted these to AudiWorld awhile back..
    http://forums.audiworld.com/a4b7/msgs/40097.phtml
    http://forums.audiworld.com/a4b7/msgs/84634.phtml
    Jul 02 2007
    Santa Monica
    Bump to see if anyone else put Eicbach springs on the stock sport suspension. There is one post of it being twice the advertised drop.
    Im leaning towards this set up, so anyone else with pics/feedback?
    May 21 2008
    ekaufman, have you decided which setup you're going with? I'm thinking H&R, which sits a bit lower than Eibach. Just hope I won't have any rubbing issues once I decide to go with 19's.
    Jul 02 2007
    Santa Monica
    Im pretty sure Im going with the Eibach springs because they dont drop as far as the H&R springs, and will put less stress on the stock sport shocks. Additionally, I wont have to worry as much when I move to a 19" wheel.
    All you need is a slight drop to make your 19s look good. Obviously, you can go further and it still looks good, but I dont want to have to be concerned with rubbing.
    I'll probably put those Eibachs on in about 3 weeks when Im back in town, and I'll definitely post images.
    When are you goign to install the H&Rs?
    May 21 2008
    thanks, definitely post pics! I would liket o do it soon, and I'm leaning toward H&R, but I would like to do some more research, since Avants are a bit different than sedans.
    Veteran Member Four Rings redlabel81's Avatar
    Nov 24 2007
    A4 1.8TQ 2005.5 + A6 1.8T 1998
    Tromsoe, Norway
    Let me know Ibiski. I have a avant to....
    I agree with the coils beeing for tracking mostly. You can get almost the same setup for half the price with some good shocks and springs.
    Most of the people here never go tracking with their cars. CO have become a got to have.
    I am not saying I don't want COs but I am just saying I don't need them for my use.......
    If I decide to lower my car is is because I think it is to high with the s-line suspension, so it will be purly cosmetic.
    Just my 2 cents, 50 cents and 2pac
    Life is too short to drive ugly cars!
    Phantom Black B7 A4 1.8TQ Avant
    //BSR PPC stg 1, 98 Oct//BSR cat back//S-line front rebuild//S-line suspension//Supersport loweringcaps//Votex valence//S4 doorblades//RS4 mirrors//S-line roofspoiler//S-line door sills//LED interior//Hoen fogs//mTec 6000k HID//RNS-E//S4 grill//MMR HR4//H&R 8mm//Dectane HL//LED licenseplight//Euro RS4 steering wheel//Sonniboy "Tint"//RS4 rear sway//
    May 21 2008
    I had coilovers (Bilstein PSS9's) on my M3 and can't say that I liked the ride. Not only was it a bit harsh, but I was experiencing some strange noises, which installers (at a reputable BMW tuner shop) weren't able to pinpoint. If my A4 didn't have sports suspension, I'd probably get the Koni shocks on top of springs, but since it does, I'll stick with stock shock setup.
    Mar 27 2006
    yes I am, Im running 235/40 on that car. I was good size for that car.
    _______
