Results 1 to 14 of 14
    Veteran Member Four Rings Beemer832's Avatar
    Sep 21 2004
    98.5 a4 1.8tqms
    KC MO
    who wants to play "guess that LWFW manufacturer?"
    So i have a LWFW (light weight flywheel). Its all aluminum minus the steel friction surface which is removable and replaceable, great. Now I have no idea who to go to and purchase the removable plate. It does not look like a fidanza flywheel, it looks more like an unorthodox flywheel. BUT heres the catch, there are NO part numbers or stamps on the flywheel at all besides to capital G's stamped on the back side. They are right next to each other and look like this:
    G G
    I have asked unorthodox and fidanza and neither use this marking. The bolt pattern of the removable plate looks like unorthodox as well. If anyone can please help it would be greatly appreciated.
    I have the receipts from southbend where the clutch came from but it does not include the flywheel. No receipts show where the flywheel came from.
    Here is a link to the unorthodox flywheel that it closely resembles.
    http://www.unorthodoxracing.com/Merc..._Code=a4ultraL
    thanks
    josh
    -josh
    98 AEB 1.8t Laser Red
    EFR 6758 with VEMS standalone in the works.
    Jun 04 2004
    fairfield cnty, CT
    Re: who wants to play "guess that LWFW manufacturer?"
    awe?
    Sep 21 2004
    98.5 a4 1.8tqms
    KC MO
    Quote Originally Posted by ModifiedA4 View Post
    awe?
    i tried that but they said it wasn't there's either. this is really annoying...
    -josh
    -josh
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Aasco is the largest manufacture of billet flywheels.
    Does it look something like this?
    Sep 21 2004
    98.5 a4 1.8tqms
    KC MO
    yes very similar bolt pattern on the removable steel plate
    -josh
    -josh
    Jul 07 2004
    socal
    Here is a picture from ATP's web site.
    Juan used to deal with Aasco for his flywheels back when he sold the WOA clutch, he said he could get their replacement inserts. Only bad thing is that he is no longer around.
    Jul 07 2004
    socal
    You can also try Stillen, they list a few different flywheels for the Audi A4 1.8T.
    Veteran Member Four Rings salz2135's Avatar
    Sep 15 2005
    Austin, TX
    Matrix Integrated is an aasco dealer if it turns out you need to purchase a new friction liner and the fw is in fact from aasco.
    97 A4 2.0TQM
    Rochester, NY
    It's probably an Assco, a lot of companies re-label those and sell them as their own.
    Jul 07 2004
    socal
    Quote Originally Posted by pac1085 View Post
    Pretty much, some shops actually contract aasco to cut the flywheel to their spec.
    Sep 21 2004
    98.5 a4 1.8tqms
    KC MO
    ok i contacted matrix integrated hopefully they will have the right answer.
    thanks for the help as always
    -josh
    -josh
    Sep 21 2004
    98.5 a4 1.8tqms
    KC MO
    it ended up being a muheler something company who made the flywheel almost 10 years ago. i was able to get in touch with a guy named Vince from Aasco. Awesome guy who really was very helpful and informative about my issues.
    They can replace the steel liner but I mentioned to him the flywheel condition and he thinks it would be best to replace it. So thats where I stand now, need to come up with that cash for the new flywheel.
    the issue with the flywheel is that the bolts either were not torqued or weren't installed with loc tite so they backed out enough to be hand tight. This caused the back side of the flywheel to get chaffed up while it unevenly rubbed on the crank.
    Would anyone be interested in a fine hunk of aluminum you can call a flywheel? 100$ takes it
    -josh
    -josh
    Jul 07 2004
    socal
    I have one of those aluminum door stops already. lol
    Sep 21 2004
    98.5 a4 1.8tqms
    KC MO
    i think i am going to make an audi scrap parts chandelier in honor of cars and car enthusiasts alike....
    pistons, rods, flywheels, cam chain, exhaust valves.... ill see what else I can find.
    I can hang it up in the new shop!!!!!
    -josh
    -josh
