Results 1 to 12 of 12
    Veteran Member Four Rings FromS60toB61.8t's Avatar
    Aug 26 2007
    07 Fahrenheit GTi, 09 S8, 17 GSW S 4-Motion, 19 S4 Black Optics
    Will these BBS's fit?
    ok well i was doing some wheels searching and i stumbled onto these
    here is the link to them on tirerack, http://www.tirerack.com/wheels/Wheel...+Stainless+Lip
    I was just wondering if these would fit without spacers or even fit in general because these with the polished lip custom painted nogaro for a color match would just be mint IMO
    Account Terminated Four Rings
    Nov 30 2006
    01.5 pearl white S4 6speed
    annapolis, maryland
    Re: Will these BBS's fit?
    no..
    but yes.. You cannnn make them work, but not direct bolt on.
    Aug 26 2007
    what would be needed, spacers??
    Nov 30 2006
    annapolis, maryland
    whats the lug pattern
    Aug 26 2007
    idk they dont really specify anything on there thats why i was hoping someone had some insight on these
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    call tirerack see if they have them in a 5x112 et35. if they do you can directly bolt them up.
    anything under et35 will poke and anything over et35~45 could require spacers
    and being that its an 18 inch wheel you should do 18x8.5/9 in front and 18x9.5 in back for a perfect look
    Veteran Member Four Rings nizmosx's Avatar
    Feb 13 2004
    2007 b7 a4 6MT Ti avant / 1990 300zx TT / 2014 Honda Grom / 2012 Tiguan SE
    Lakewood, CA
    go with a 32mm offset, it will sit more flush with fenders for an aggressive look, however you will most likely have to roll fenders. if you do the staggard setup as mentioned above make sure the tires are the same size.
    Veteran Member Three Rings A4SUM's Avatar
    Mar 03 2004
    ^^ What Nizmosx said.
    2004 B6 Black A4 1.8t | 2001 B5 Casa S4 | 2000 B5 Silver A4 1.8t
    Aug 26 2007
    Well i might be picking up a nogaro S4 tommorrow so im looking at the possibilities, these wheels just seemed to stick out to me as the perfect wheels for what im looking for, im planning on doing RS4 widebody conversion so i might go with wider wheels. Im gonna go for a black/blue look, black wheels with colormatched lip, all painted boser, etc. i have big plans but thats if the price is right tommorrow. Hopefully ill get it, i really look forward to being in the S4 community and getting out of the slow lane
    My secondary option is just going to be some Black Edition CH's and paint the chrome on them nogaro
    Veteran Member Three Rings Go_S4's Avatar
    Mar 20 2007
    Nor Cal
    those are nice...
    Feb 12 2008
    01' S4/ 98' Boxster
    Lake Oswego/Corvallis
    Those wheels are perfect. and if you get them you may be one of the only people on here with them. DO IT
    Feb 13 2004
    Lakewood, CA
    in case you havent seen them work makes wheels that look similar to them. check em out.
