This started a few days ago, it came with the slew of other problems.
When my car is in accessory the radio comes in perfectly clear. When I start the car, I have a static whining noise that seems to get louder as RPMs rise. The CD players comes in perfectly clear.
Last year I had a signal booster (not sure the technical name?) installed, it was like $20 installed so it isn't anything fancy, but it gave me reception when I had none otherwise. I had the place that installed it check it out for me today, they replaced it and it didn't fix the problem. They said it might be a bad ground on the antenna, but why does the static only appear when the engine is running?
Ideas?...
