Thread: ko4 question
    Veteran Member Three Rings LEGO's Avatar
    Aug 20 2007
    SEATTLE, WASHINGTON
    ko4 question
    Is the exhaust part of a ko4 the same as the ko3? I know the wastegate actuators are the same but are the exhaust parts that bolt to the mani and the cat the same. Cause my wastegate is making noise and I think my flap in the ko4 is breaking off. Can I just swap the exhaust part of a ko3 to the ko4 to solve that issue? How difficult would the swap be? Thanks!
    1998 A4 1.8TQM MTM K04 5.82/034 415CC BT TUNE/GENESIS 415CC INJECTORS
    http://s22.photobucket.com/albums/b331/nelly11299/
    Jun 04 2004
    fairfield cnty, CT
    Re: ko4 question
    Quote Originally Posted by LEGO View Post
    it should be, only the compressor side is different iirc.
    Account Terminated Four Rings
    Oct 28 2006
    GT30r'd A4 on Meth, 01 Durango
    Re: ko4 question
    Quote Originally Posted by ModifiedA4 View Post
    the exhaust side has a 1mm bigger impeller than the K03
    Jun 04 2004
    fairfield cnty, CT
    Re: ko4 question
    Quote Originally Posted by AudiRacerS4 View Post
    really? 1mm is a small #.
    Aug 20 2007
    SEATTLE, WASHINGTON
    Re: ko4 question
    Ok. Cause I'd much rather buy a used ko3, swap out the exhaust housing and have a functioning ko4 than spend another 800 for a ko4. Not to mention the ko4 is on backorder everywhere. Will that 1mm make a difference?
