Results 1 to 40 of 53
    Dec 01 2007
    Markham, Ontario
    RS4 sway... DO IT
    install them now...
    o
    i can break loose my rears when i turn
    do it now !
    2015 BMW M3 Alpine White
    2013 Phantom Black RS5
    2012 Audi TTRS Black / Black - Sold
    Plus One
    Gabriel
    3255 Highway 7 East Unit 159
    Markham Ontario
    Cellular sales / repairs / unlocking / flashing - PM if you need help with anything
    Established Member Two Rings Mtepete's Avatar
    Jun 17 2008
    2005.5 A4 Black 20% Tint
    Hartford, CT
    Re: RS4 sway... DO IT
    whats a good site to order them from?
    Senior Member Three Rings ron8818's Avatar
    Dec 03 2006
    2005.5 A4 B7 2.0T
    Chicago
    AHHH... So what do I do now? I already did the RS4 sway...
    Hi
    Registered Member Three Rings Firefighter637's Avatar
    May 03 2008
    A4 B6 USP
    Orlando, FL
    Quote Originally Posted by evilgabbie View Post
    install them now...
    o
    do it now !
    What?
    A4 B6 1.8T USP Silver
    GIAC-Flashed
    Forge DV
    De-Badged
    Blacked out Grill
    Clear Corner mod
    APR Snub Mount
    RS4 Rear Sway
    LED Tailights
    May 20 2004
    More cars
    Never Land Ranch
    Quote Originally Posted by Mtepete View Post
    www.Audiusa.com
    It's not expensive at all!
    SEXICAN
    2013 Q5 3.0T-DD
    2002 Honda Civic
    AMD/EPL Tial 605 B5 S4 SOLD
    Active Member Four Rings 3.2some's Avatar
    Dec 19 2007
    ..is full of crap I dont need
    Escondido, CA
    Quote Originally Posted by Firefighter637 View Post
    What?
    he can break loose his rears when he turns...are you deaf?
    V/R -Phil
    B7 2006 Audi A4 3.2L Tip FWD Brilliant Black
    May 20 2004
    More cars
    Never Land Ranch
    Quote Originally Posted by 3.2some View Post
    he Can Break Loose His Rears When He Turns...are You Deaf?
    Haha
    SEXICAN
    2013 Q5 3.0T-DD
    2002 Honda Civic
    Active Member Four Rings marty was here's Avatar
    Nov 10 2006
    992TTS 992GT3 RS7
    nnj
    he Can Break Loose His Rears When He Turns...are You blind?
    fixed
    We have a black president... Racism is dead.
    -JPT
    I have a real sore throat...feels like I've been deepthroating gorillas.
    mister_tu
    Hey, I just read this (and this is crazy), but take your two cents, and fuck off maybe?.
    audia
    May 03 2008
    A4 B6 USP
    Orlando, FL
    RELAX! The way he wrote it didn't make sense to me. Take a chill pill!
    GIAC-Flashed
    Forge DV
    De-Badged
    Blacked out Grill
    Clear Corner mod
    APR Snub Mount
    RS4 Rear Sway
    LED Tailights
    Dec 19 2007
    Escondido, CA
    Quote Originally Posted by marty From Dvag View Post
    fixed
    my sarcasm just got shot down by marty....
    you can't get the full effect of it by typing it you know =x
    V/R -Phil
    Jan 06 2008
    Dacia Sandero
    Arizona
    On Acurazine, sarcasm was posted in Red. It helped eliminate e-battles quite a bit. I think Audizine should adopt the red=sarcasm philosophy.
    B8.5 []S5 . BBS . H&R . AWE . DEVAL . Stërn . 034 . OEM+
    Dec 19 2007
    Escondido, CA
    Quote Originally Posted by 4RingRook. View Post
    but that would not be as fun and I would have to type everything in red....and then firefighter69 wouldnt get pissed at me and start yelling
    V/R -Phil
    May 03 2008
    A4 B6 USP
    Orlando, FL
    True HA
    GIAC-Flashed
    Forge DV
    De-Badged
    Blacked out Grill
    Clear Corner mod
    APR Snub Mount
    RS4 Rear Sway
    LED Tailights
    Veteran Member Four Rings Glassnpowder98's Avatar
    Mar 07 2008
    Audi A4 B7
    VA
    Any insight about how you are getting your rear end to break loose? My car seems to stay hooked up no matter how hard I try to turn... Are you turning out and then turning in hard to shift the weight or are you dumping the clutch to break traction? When I'm trying to corner hard I usually turn in with minimal gas and then once I hit the apex I'll start to pin it... I pretty much always keep traction or get just a tad bit of understeer. I havent taken any drift or racing lessons so I'm not real familiar with any techniques except for reading a little bit about drifting and hitting apexes. On second thought, maybe its a bad idea to learn how to break loose because I'm sure I'd go through tires a lot faster...
    P.S. I don't try to drive around breaking loose all the time... I try not to be a reckless driver and won't use any information provided to drift every turn I make. Although it might be tempting
    05.5 A4 2.0T Brilliant Red 6MT: Put some money and time into it...
    The only standing start, straight line racing I enjoy is on the way to the first corner.
    Established Member Two Rings GEkido's Avatar
    Apr 25 2008
    Miami, FL
    Quote Originally Posted by Glassnpowder98 View Post
    Are you turning out and then turning in hard to shift the weight ...... On second thought, maybe its a bad idea to learn how to break loose because I'm sure I'd go through tires a lot faster...
    Correct on both counts sir. You have a lot fun hearing the tires scream, but then a lot of pain when its time to buy new ones....
    2021 S5 Sportback | Glacier White | Sport Package | Black Optic | APR 93 Tune | APR FMIC | AWE CF Intake | 034 F.S.B. | 10/12.5mm Spacers
    Veteran Member Four Rings Sly Raskal's Avatar
    Jan 22 2007
    Fontana, CA
    :werd:
    ... awwww the :keyword: trick doesn't work here and I so wish it did.
    -Anil
    2019 A4 Sedan, Nardo Gray, 45TFSI, Prestige Plus, S-Line, Quattro, Black-Optic, PPF, Ceramic Paint Coating, Ceramic Tint, Audi Black Door Handle Kit
    Jan 22 2007
    Fontana, CA
    Or he'll think your post is on fire and try to put it out.
    -Anil
    Veteran Member Four Rings CZA420tAvant's Avatar
    May 24 2008
    06 A4 Avant 6MTQ Brilliant Red
    Orange County, NY
    Where is another site to order, I cant find it on the Audi site, or maybe im just an idiot!!!
    Driving: 2006 Brilliant Red A4 Avant 2.0TQM
    Revo Stage 2|Carbonio Intake|Stasis SS coils|Podi Gauge|iForged 19"|H&R spacers|RS4 F/R sways|custom inlet pipe|Milltek turbo back with custom twin tips
    Endorsing:
    Veteran Member Four Rings Louis J.'s Avatar
    Dec 26 2007
    PNWR
    I understand dialing out understeer but buying an AWD and then inducing oversteer???
    I have the RS4 sway and it does help dial out understreer but I wouldn't call my car neutral. It probably takes a 24mm rear sway to dial it out completely.
    Dec 01 2007
    Markham, Ontario
    HAHAHAHAHAHAHA i am just too happy...
    i just ... turned ... felt completely different
    sorry about the wording guys
    Plus One
    Gabriel
    Markham Ontario
    May 20 2004
    More cars
    Never Land Ranch
    thats like saying your car can go 130PMG
    EDIT 130MPH
    SEXICAN
    2013 Q5 3.0T-DD
    2002 Honda Civic
    Veteran Member Four Rings ABanT's Avatar
    Aug 07 2007
    B7 ABT Avant
    lol are you in need of new tires already?? What tires are you running anyways? I never thought to ask or look at it.
    I installed the rs4 sway as well and we have the same rims. I cant get the tail to come out.
    But the car does turn really well now.
    Veteran Member Four Rings VZWalex's Avatar
    Feb 21 2008
    09 Q5 Ibis White
    Los Angeles, California
    Quote Originally Posted by SEXICAN View Post
    EDIT 130MPH
    but our cars can go 130mph... and then some!
    15 Mazda Cx-5 metero Grey - Stock for now ...
    09 Q5 Ibis White. Prem+, B&O, ZiZa Pure Yellow Fogs, Clear Bra,Prestige tint,Tunerdome LED Plate Bulbs, VIM, Vag'd
    06 MkV 2.0T - Sold
    05 XB Silvermist. - Sold
    www.EurovisionProtectiveFilms.com
    Dec 01 2007
    Markham, Ontario
    toyo proxies 4
    try harder !! that means you aren't turning fast enough =)
    Plus One
    Gabriel
    Markham Ontario
    Apr 25 2008
    Miami, FL
    Quote Originally Posted by WhiteABanT View Post
    You cant get the tail to come out?!? I have a lovely left hand turn coming in to my neighborhood that has eaten at least half of the tread on my tires, lol. Drive at around 50mph - 3rd Gear, As you are coming in to the turn brake briefly till you hit around low 40's (by now you should be starting your turn - remember, quick out then hard in) as soon as your car is about half way through your turn, floor that bitch and hear her scream.
    You can get some good driving techniques out of the book "Speed Secrets" by Ross Bentley.
    Veteran Member Four Rings Rotond0000's Avatar
    Apr 30 2007
    Rhode Island
    Quote Originally Posted by GEkido View Post
    YESS ive read like every single one of them good stuff!
    - 2011 A4 2.0T Quattro - 6 Speed Manual - Black/Black - ST Coilovers - 20% Tint - Smoked Tails - Smoked Corners - 6000K Headlights And Fogs - Full LED Interior Lighting Conversion - Custom LED Headlight Strips - RS4 Grill W/ Blacked Out Euro Plate -
    Jan 06 2008
    Dacia Sandero
    Arizona
    Quote Originally Posted by Sly Raskal View Post
    :werd:
    +1.
    I knew you'd catch that reference
    Veteran Member Three Rings freeflow's Avatar
    Apr 18 2008
    2007 A4 2.0T
    Manhattan/Miami
    i got it the first time haha... but seriosuly... there needs to be a sarcasm button. this happens too often lol
    2007 A4 2.0T - Brilliant Black on Black - Premium - 5% tint - 7 spd multitronic - APR 93/Stock - RS4 Sway - FLY's LEDs - CC'd - LED License Plate - Interior xenonmatch - Hoen Fogs - Debadged - VAGed
    Wish list: Stassis Coils, Carbonio CAI, HFC, 19" R8s, Ecode CF Hood, CF Rear Wing, ECS Blackout RS4 grille, S4 blades,
    Veteran Member Four Rings John1.8T's Avatar
    Jun 08 2005
    2005.5 Brilliant Black Audi A4 2.0T Quattro 6spd.
    Waterloo, Iowa
    Those of you who think you're getting the back end out... you're not.
    this thread fails.
    learn about your car and how to drive please.
    Apr 18 2008
    2007 A4 2.0T
    Manhattan/Miami
    ^^^ they might be getting it out... but they shouldnt be trying to lol... just slows you down!
    Senior Member Three Rings rayiish's Avatar
    Feb 03 2008
    Brooklyn, NY
    Does anyone know how much a new metal bracket is? and also do I have to get it at an audi stealership? My friend and I tried to force it in the bushing and bent the bracket all out of shape.
    Ray
    2006 Audi 2.0T Quattro w/ Tiptronic -Dolphin gray | APR 93 | RS4 Rearsway bar | Tinted head lights/tail lights/side reflectors | Bulbs changed | Clear Corner
    Veteran Member Three Rings A4addict's Avatar
    Jan 23 2008
    '08 Audi S-line 2.0T A4
    San Diego, CA
    Sarcasm is assumed on every Audizine post.
    APR 91/93/100, Forge DV, Debadged, PIAA, Blacked out filler/grille/reflectors/fog covers,
    2.5" custom catback, Remus axleback exhaust, H&R Coilovers, Vredestein Ultrac Sessanta 235/35/19 tires, 19/8.5" BBS LM reps, RS4 centercaps, EVOM intake, 35/5% tint, Lamin-X
    | Caution: Asian driver |
    Veteran Member Three Rings JGreen76's Avatar
    Jun 05 2008
    Houston, TX
    Quote Originally Posted by CZA420tAvant View Post
    ECStuning.com
    '21 RS5 Sportback-Tango Red - Black Optics Carbon Package
    '20 R8 Spyder Performance - Kemora Grey - Black Optics Carbon Package
    PAST:
    '21 SQ5 - Quantum Grey
    HIS: 2019 Glacier White TTRS Black Optics///HERS: 2019 Tango Red TTRS///2017 Macan GTS///2014 Q5 3.0T Glacier White with Black Optics///2015 S3..........:::Glacier White, APR Stg3::::.......///2013 MK2 TT Roadster///2007 B7 A4 S-Line 3.2
    IG: TwoCarGarage_HOU
    Veteran Member Four Rings viperdsa's Avatar
    Aug 28 2007
    Angry Gerbils
    west of the equator
    Can't wait till mine gets here.
    '06 Dolphin Gray A4 2.0T
    Motoza Tuned EFR
    Veteran Member Four Rings Phrost's Avatar
    Jan 24 2007
    1977 VW Type 2 Westfalia
    Wisconsin
    All I have is APR 93 stage 2 (intake and test pipe) and I can break my tires loose on any corner I want to. Sure I'm on oem tires and they're at about 50% tread, but I always could.
    We have this one sharp, winding turn that is a 30-40mph road, and I always start out real slow then go into a drift around it if there are no cars. I actually did this a few days ago and almost went completely sideways, so I had to do a panic counter steer and slow way down to not spin out. Quattro is great and it was very easy to correct. I have no idea why my tires have only 50% tread left
    Ignorance is bliss.
    Veteran Member Four Rings a4dc89's Avatar
    Nov 07 2007
    Land Rover Disco I
    Washington DC
    I've gotten the tail out too, it is deff not impossible. If i peal out on to almost any road and floor it while im turning i will get the rear end out for a bit. Im stock so it should be even easier with software and the sway.
    2006 A4 B7 2.0TQ Dolphin Gray Metallic 6MT
    REVO Stage II, 034 HFC, AEM turbo inlet/intake, OEM Piston DV, BSH PCV Fix, HID Fogs/Fog Mod, AWE Boost Gauge, Debadge
    All go no show
    Jan 24 2007
    Wisconsin
    Yeah, just software and it will be really easy.
    Here, I made a picture of what I do on Google Map
    Ignorance is bliss.
    Jan 01 2008
    Long Island NY
    i have an H&R rear sway bar. best bang for your buck mod.
    Dec 01 2007
    Markham, Ontario
    Quote Originally Posted by phrost View Post
    yeah, Just Software And It Will Be Really Easy.
    Here, I Made A Picture Of What I Do On Google Map
    Hahahahahah Phrost For President
    Plus One
    Gabriel
    Markham Ontario
    Feb 03 2008
    Brooklyn, NY
    does anyone know where i could get that metal bracket for the 2 bolts? I bent mine out of shape and the dealership wants to charge me $104.97 for it.
    Ray
