Results 1 to 24 of 24
    Registered Member Three Rings volks88's Avatar
    May 06 2007
    stg3 s4,02 C32 AMG,88 325IS
    lexington,ky/fond du lac,wi
    tips or tricks on installing ER sidemounts???
    i want to get these on tonight or tomorrow and was just wondering if any cutting or hacking will be involved? im sure its a tight fit, these things are huge compared to the stock ones. i'm not to concerned but would like to be aware of things people have done and maybe what tools i'll need on hand to make this go as easy as possible. thanx
    Jun 14 2007
    2000 S4
    Connecticut
    Re: tips or tricks on installing ER sidemounts???
    did you try getting some upgraded DV's in your car yet? or are you doing that today. post back, i really think that may be the answer lol
    May 06 2007
    yeah im going to pick them up in like an hour
    Jun 14 2007
    2000 S4
    Connecticut
    good... post back ! lol.
    Veteran Member Four Rings BITRBO's Avatar
    Mar 08 2007
    Mr. Worl-Wye
    No cutting or hacking at all. Direct fit.
    '13 C63 AMG -
    '14 Tiguan - sold
    '09 JSW - sold
    '04 GTI - sold
    '01 S4 - sold
    Jan 01 2005
    MN l VT
    Quote Originally Posted by BITRBO View Post
    I followed the AWE instructions and it turned out pretty good. Be careful to not put a hole in the intercooler with the bumper support screws(the T45 screws).
    Best of luck on the passenger side getting in for the first time.
    Feb 17 2008
    Ottawa Ont.
    pasenger side is a bitch, but once you grind down that lip its fine.
    Veteran Member Three Rings ThePaintballGuy's Avatar
    Mar 14 2007
    Phoenix Arizona
    It might be easier, but a little more work, to put the radiator support in the work mode (pull it out a bit). It's only a few extra bolts. LOL
    Josh
    May 06 2007
    its a no go on the dv's i'll throw the intercoolers on tomorrow. after that i'll probably just take it to jersey and buy a one way ticket home
    Jun 14 2007
    2000 S4
    Connecticut
    dam man, i dont know. did you drive by frimmels car and it rubbed off on yours! :(
    Veteran Member Four Rings AMC's Avatar
    Jun 15 2007
    '19 Spektrum Golf RS, '18 Audi TTRS
    lmfao
    Driver Supply
    Current
    '19 Spektrum Golf RS DAZA
    '18 Audi TTRS
    Sold
    '07 Stage 3 2.7t swapped B7 A4
    '01.5 Stage 63463 Silver S4
    '13 black Audi S7
    '03 Porsche 911T
    Jan 30 2007
    2000 S4 stg3
    cincy
    You have pressure tested right? We need to get some logs def and go from there...
    May 06 2007
    Quote Originally Posted by davism1 View Post
    yeah and yeah
    Veteran Member Four Rings Reich's Avatar
    Oct 14 2007
    2001 s4 ; 2001 jetta tdi
    Val-Belair
    Direct fit. Passenger a/c recever is a bitch to move away from intercoolers but not bad. don't forget to cut two bolts of your rad support to prevent doing holes in the front of intercoolers. Of course it was easy for me since i had no rad support in front --> doing stage3+. good luck
    Forum Moderator Four Rings
    Apr 16 2005
    Pearl City, Hawaii
    Direct fit?
    Did I have a different set of intercoolers?
    B5S4/A3S3RS3/Hawaii Forum Moderator - PM Comments/Concerns
    18 Daytona Gray Pearl S3
    00 Laser Red S4 (Sold )
    VAST Performance | BLOUCH | AWE | EvolutionRacewerks | Volk Racing | Vogtland | STaSIS/Alcon | JHM Motorsports | RS4 OEM
    Active Member Four Rings FrimmelNoJerz's Avatar
    Sep 21 2006
    Norjerz
    dude come to the audizine tent at waterfest so i can kick you in the groin! sick!!!
    SBSC
    I also like to live dangerously.
    Jun 14 2007
    2000 S4
    Connecticut
    Quote Originally Posted by FrimmelNoJerz View Post
    lol . was it you last year with the red bulls ? do that AGAIN! .
    Mar 08 2007
    Mr. Worl-Wye
    Quote Originally Posted by Reich View Post
    y'all must've missed the sarcasim... I'm sure the right people got it though
    '13 C63 AMG -
    '14 Tiguan - sold
    '09 JSW - sold
    '04 GTI - sold
    '01 S4 - sold
    May 06 2007
    this was a super easy install. straight forward with minimal cutting. im being totally serious to lol
    Sep 21 2006
    Norjerz
    you KNOW it. My tent gets down like a mother******.
    SBSC
    Feb 17 2004
    Sterling, VA
    That was Ryan. (RaketeS4)
    Brett - Moderator
    Issue?: email me.
    _____________________
    Stage 3 2004 A6 2.7T 6M
    Nov 13 2007
    denver
    The key to avoiding too much cutting is to mount them with the IC tabs under the quarter panel tabs instead of on top so you don't have to cut away at the quarter panel like the AWEs. You will have to cut off the lower outboard thread insert on passenger side bumper support horn. Use the AC condensor relocation bracket. Their is a threaded hole that is perfect for it. You will have to drill out the old IC brackets. It's actually easier than it sounds.
    Sep 21 2006
    Norjerz
    Quote Originally Posted by Daft View Post
    he was in my tent and keeping it cool in MY ice.
    SBSC
    May 06 2007
    Quote Originally Posted by audidweeb View Post
    yup
