    May 10 2008
    PA
    Resonator question..
    I have a 96 2.8. What resonator can I run? Im looking to do a custom exhaust with a magnaflow muffler. I would like to run a magnaflow resonator as well? Can I run a magnaflow resonator made for a 97-99 2.8?
    Registered Member One Ring B5Audee's Avatar
    May 03 2008
    Neenah, WI
    Re: Resonator question..
    If it will fit under the car and the diameter of the inlet/outlet matches pipe size then you can use whichever one you want
    Established Member Two Rings gotboost?!'s Avatar
    Oct 16 2007
    Chicago
    sry to thread jack but need some opinions if i should run a resonator on my 1.8t ?
    "god gave us turbo lag to give V8's a chance"
    98 Audi A4 1.8TQM
    Oct 30 2006
    B8 A4 Avant 6spd
    Quote Originally Posted by gotboost?! View Post
    I wouldn't run one at all, the turbo acts like a resonator. If you're using a stock muffler, you're barely going to notice any sound difference. I'd just cut the bitch out, less back pressure.
    -18 718 GTS
    Established Member Four Rings Yaktizzle417's Avatar
    Aug 05 2007
    2000 A4 1.8TQM
    SpringVegas, MO
    ÖMGHI2Ü
    Photography
