Results 1 to 8 of 8
    Apr 07 2007
    05 S4 /81 scir./02 A4
    delta B.C
    b6 S4 power steering
    after owning both an a4 1.8t avant and now newly aquired S4 im not sure if i like the way the steering really stiffens up at higher speeds
    my question is and i searched , is there a mod of some sort to decrease the
    stiffness slightly at higher speeds? as i like the way the 1.8t a4 feels better
    at over 80 kph
    Veteran Member Three Rings fitzS4's Avatar
    Mar 17 2007
    audi s4 chevy 2500 HD
    new york
    Re: b6 S4 power steering
    i believe its called servitronic...... but it helps cause when you going 80 and you turn the wheel sharply, well you know.....also its a completely different suspension to the a4...but to help you out look for eddieman's post about disactivating it
    Apr 07 2007
    delta B.C
    cool thanks
    Nov 07 2005
    RS6, M5
    Melbourne, Australia
    Quote Originally Posted by fitzS4 View Post
    Almost - it's called 'Servotronic'.
    Senior Member Three Rings JoeM's Avatar
    Nov 01 2007
    Vancouver, Wa
    And I thought the mod was to turn off power steering all together, for track purposes so that you have an even more direct feel in the wheel.
    -Joe-
    '08 A4 2.0T Q
    '01 Land Rover Disco II
    '99 Porsche Boxster
    Veteran Member Four Rings 40valve's Avatar
    Mar 24 2008
    khgkhg
    Why in the world would you want the steering to be soft at high speeds?
    It does that for a reason not to annoy people.
    Dec 30 2007
    Constantly changing.
    DC
    Quote Originally Posted by 40valve View Post
    I too was thinking and wondering the same thing.
    Why would anyone want the steering to be lighter and less connected from the driver when traveling at higher rates of speed?
    Jul 21 2004
    South Florida
    Yes, servotronic sucks. Unfortunately if you pull the relay you get a very oddly weigted system. It does not just go back to typical audi steering if you pull the relay. I had the 1.8t with the standard steering and it is much better to drive from a performance standpoint. Servotronic is really laggy in abrupt speed and directional transitions such as road courses. It becomes very artificial and laggy. It's a typical complaint of all of the electric speed sensitive steering systems though. Even BMW is getting dinged for it. Best thing to do is just live with it unfortunately.
    cheers! Mike
    2018 Audi S5
    Gone-
