Results 1 to 9 of 9
    Veteran Member Three Rings mmxruffryder15's Avatar
    Mar 28 2008
    new york
    darintake question
    i swapped my stock air filter to a k&n filter....would that be good wit the darintake or should i keep the stock
    Senior Member Three Rings gaspeedracer's Avatar
    Jun 02 2007
    2001 Imola Yellow S4
    Daytona Beach, FL/Conyers, GA
    Re: darintake question
    that's what im using. absolutely no problems at all
    "A true leader has the confidence to stand alone, the courage to make tough decisions, and the compassion to listen to the needs of others. He does not set out to be a leader, but becomes one by the equality of his actions and the integrity of his intent."
    -Douglas McArthur
    Semper Fi!!!
    Mar 28 2008
    new york
    thanks...i dnt feel like spending money on a intake when a darintake does the same thing
    Dec 06 2007
    Calgary, AB, Canada
    Put a new OEM paper filter in and do the darintake mod. /thread
    Dec 02 2007
    2020 Ford PIU, 2017 D675R
    DC/MD/(VA)
    Quote Originally Posted by The_Jerbel View Post
    Theres a mixed reaction on K&N versus OEM. Personlly, I didn't know any better so I spent the extra $40 and bought the K&N and put it with my Darintake.
    Only downside to K&N is over-oiling after you've cleaned the filter...which in turn screws up your MAF.
    Lesson: Buy OEM and replace when needed...its cheaper than spending money on a new MAF. There REALLY isn't any sort of significant "HP" gain between OEM/K&N. In fact, there really isn't any sort of significant gain with the Darin mod, just better throttle response.
    Have fun cutting.
    2015 B8 SQ5
    Click Here
    Past
    Dec 06 2007
    Calgary, AB, Canada
    The other downside to the K&N is the larger weave, allowing more debris past the filter, also screwing up the MAF. No gain to be had with K&N, why bother?
    Apr 05 2007
    on the flip side, all my Blackstone Labs oil analysis showed extremely low silicates "indicating excellent air filtration" they even specifically said on one report - all while running a K&N.
    but now I'm running a paper and will continue to.. so.. um.. yeah.
    Jun 02 2007
    the only reason i use the k&n filter is because i got it for free from a friend. if i had to start from scratch i dont think it would matter to me.
    -Douglas McArthur
    Semper Fi!!!
    Veteran Member Three Rings dgrs4sd's Avatar
    May 25 2008
    So Cal
    I did the intake mod a couple of weekends back and installed Amsoil's filter in there. It was only $22 and has a 100K mile warranty, it is a paper filter but you can clean it with a vacuum or 20 psi of air
    I believe it or not noticed a difference from doing that and the intake mod. I cut a nice size square out of the bottom angled piece with my dremel. You can hear a bit more now. I am glad I did it.
