Results 1 to 32 of 32
    Veteran Member Four Rings J-jizzle's Avatar
    Aug 28 2007
    Tools, Parts and the GTI beater
    Birmingham Alabama (Tennessee)
    Camshaft & Crankshaft seals
    I recently started my timing belt DIY and during my next day off I'm going to finish it up. I purchased the the kit off ECS that came with the Cam and Crank seals, because I figured I would replace them while everything was off. I am worried though that I might mess up the timing getting the pullies off/on (after I put it a top dead center and get the old belt off).
    Also should I use a impact wrench/gun to get the bolts Off and On (anyone know what the torque spes are) ? Whats the best way to get the old seals out?
    Thanks for any help and any other suggestions.
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    Re: Camshaft & Crankshaft seals
    I bought them too just in case but mine weren't leaking so we didn't mess with them...
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Bingo. You might cause an issue by replacing them. I used the original 90k cams seals when I did my motor. I did replace them when I put in the cams. If you oils has been changed on the regular they shouldn't leak for a long time. If you insist on replacing them, I'd loosen the bolts before you remove the belt.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Aug 28 2007
    Thanks for the replies. Ill just leave the stockers there then and have these for down the road.
    Aug 26 2005
    Quote Originally Posted by dirtybrd View Post
    I second that advice. To the OP, I recommend replacing the seals now. Do you have a Bentley? If not you can get a 3 day subscription for online access for about $30, and you can print as much as you want.
    http://www.bentleypublishers.com/sho...ME01-01-001-04
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Crank seal? Are you referring to the front main seal? If it is not leaking I suggest not touching it. You need a 1200ft-lb impact gun (or something of that caliber) to get the crank bolt off and on. You also need a new crank bolt. Not worth it and I haven't heard of anyone doing it during a timing belt install.
    The cam seals? If they are not leaking I would leave them alone as well. In order to do that, right, you need the cam tensioner tool to tighten down that chain so you can pull the cams (to do the rear cam seal under the VVT tensioner). Not worth it if you are not sure how to time your cams back up and time the whole engine back up. The front cam seals need the reluctor ring and TB cog to come off. The front cam cap also has to be loosened and/or removed.
    -Doug
    Veteran Member Four Rings CO AVANT's Avatar
    Feb 12 2004
    '03 B6 Avant, '15 B8 A4, '14 S8, '15 Duramax
    Everywhere
    All you need is a long ass breaker bar and yo guns
    Veteran Member Four Rings wolfdog's Avatar
    Nov 22 2006
    Yea, I too bought the ECS timing ultimate plus timing belt kit that includes the camshaft seal and crankshaft seal. I was told by the dealership I had a cam seal leak so I was planning on doing both of them with Clint. I'm hoping this isn't going to be too much trouble.
    2002 A4 TQMS
    Motoza 1+ w/Genesis 380s, 034 HFC, K&N drop-in, 710N, Neuspeed snub, StopTech SS lines w/Hawk HPS, Conti DWS, full Votex, Pioneer FH-X700BT, DDM 35W 4500K HID
    12/23/09 - My car has been phenomenal to me. Runs strong. Don't think I'm ever going to sell it. Rather throw $7k into it for a refresh than buy a new A4 that has no dipstick.
    12/5/10 - 100k miles & counting!
    9/22/13 - 146k+ & running strong w/a new TB, water pump, etc.
    Aug 28 2007
    I was only planing to do the front cam seal only but I think today Im just goin to get this back on the road and worry bout those when they go out, like you guys said.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Quote Originally Posted by CO AVANT View Post
    Doesn't work. I've tried on two engines and couldn't get them loose. Had to go to the VW dealer and have them use their impact gun. I am a weakling in the upper body thanks to my cycling career.
    Clint had the same problem with his engine when he dismantled it.
    -Doug
    Feb 12 2004
    Everywhere
    yo gunz ain't big nough then
    Dec 03 2005
    2 pedals 1FG
    connecticut
    the ladies don't seem to mind
    -Doug
    Feb 12 2004
    Everywhere
    No but seriously, it is a total bitch to get that bolt off with a breaker bar. The breaker bar I was using was like 3ft long too...
    Nov 22 2006
    Hmm, I have to do the cam seal. you guys are making me think the crank seal isn't worth the trouble now. I'd really prefer to do it while I'm in there, though. Clint, how much does that impact gun of yours have in it?
    EDIT: New question: can someone tell me more about the crank seal? Precise location or anything else you want to share. Thanks.
    2002 A4 TQMS
    Feb 12 2004
    Everywhere
    This is a mean impact gun. Good 'ol Harbor Freight...
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by wolfdog View Post
    Well Reilly broke it but Im borrowing my friend Jons gun this week.
    We can do the cam seal but like Doug said, the crank bolt is a BITCH
    - Clint
    Aug 26 2005
    Quote Originally Posted by J-jizzle View Post
    Sure, doing the cam seals/crank seal is optional now, and is a matter of preference. The factor to consider is the possibility that the seal/s will fail at some point in time in the future (assume usually sooner than later,) requiring the timing belt be removed again to replace the seals. The difficulty of the tasks involved depends your skills and experience level. BTW, there is no radial shaft seal on the timing adjuster end of the cams.
    Nov 22 2006
    Anyone?
    2002 A4 TQMS
    Aug 26 2005
    Honestly guys, the key thing is holding the crank sprocket using a tool similar to the special tool shown in the Bentley, a tool can be made by gas cutting some 1/4" steel plate, or 1/4" aluminum plate cut out using a band saw, shaped like the tool shown in the Bentley, and drilling a couple of holes to match the sprocket holes. The arm of the tool needs to be held by something on the engine, the snub mount will work fine for this. Then, a long 1/2" breaker bar and socket will loosen the bolt. Re-tightening the bolt needs to be torqued to 90 Nm, then turned another 90 degrees. With a little pre planning preparation, this is really not that big of a problem.
    Aug 26 2005
    Anyone?
    The crank seal is directly under the timing belt drive sprocket on the front end of the crankshaft. It is installed in the seal carrier bolted to the front face of the engine block.
    Nov 22 2006
    so it's under the sprocket at the very bottom of this photo, which is taken from the TB DIY:
    Correct? Sorry, visualizing helps. I think that's right because that looks to be like a lock of some sort on the sprocket.
    2002 A4 TQMS
    Aug 26 2005
    The crankshaft seal is behind the sprocket circled in yellow.
    Nov 22 2006
    Great, thanks.
    2002 A4 TQMS
    Oct 29 2005
    10speed
    San Francisco, CA
    Larry, I got a new gun, but seriously its only 280ft lbs
    you need 1000+ to get that crank bolt off, Jordan is crazy
    - Clint
    Nov 22 2006
    Who's Jordan and why is he crazy?
    2002 A4 TQMS
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Clint.
    John's method of making a tool that bolts to the four bolts on the crank TB sprocket is a good idea. The more I think about that suggestion the more I like it. You can make the handle sized appropriately so you can put a huge cast iron pipe over it to get more leverage (like you would a 1/2 drive breaker bar).
    That is, if your crank seal is leaking. I understand John's argument of 'it could leak soon' but my attitude is if it ain't broke don't fix it. I guess because tearing down my front end to get to this crank is nothing for me to do. Its a big deal for other people which is why he's suggesting doing it while things are apart.
    -Doug
    Feb 12 2004
    Everywhere
    Doug, this is how I did it. Forgot to mention I had an audi holding tool...
    That's me. They think I was full of shit. Obviously I am not ;)
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Forgot to mention a minor detail, huh
    In that image above. The ? by the gas shock: I think that distance should be about 10mm (or 1cm). That provides adequate adjustment for the gas shock during normal operation.
    -Doug
    Feb 12 2004
    Everywhere
    After 2 years of not messing with it, yeah
    Established Member Two Rings sloweryucf's Avatar
    Feb 21 2008
    2003 A4 1.8T (sport package)
    Orlando, FL
    So anyone got a pic location of the camshaft seal?
    GO KNIGHTS!
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Quote Originally Posted by sloweryucf View Post
    Its the seal behind the exhaust cam sprocket (top left) and the intake cam reluctor ring (top right behind that cover)
    I have detailed pictures of the actual seal on the cams at home. I can upload them and add them to this post tonight.
    You need to take both the exhaust cam sprocket and intake cam reluctor rings off to remove the seals. Its a full 360 rubber seal. Like the crankshaft seal, its your call on whether or not you want to do it. I've never replaced them in TB swaps I've done. The only time I've replaced them was when I build my new 2.0L stroker motor.
    -Doug
    Nov 22 2006
    Here's what my car looked like while doing TB at 74.3k miles (leaking water pump):
    Thanks Clint and Doug!
    2002 A4 TQMS
