Results 1 to 3 of 3
    Veteran Member Three Rings DGAFxxx's Avatar
    Nov 27 2006
    Salt Lake Shitty, UT
    Alternator Squeeking after replacement
    I replaced my alternator over the weekend.
    Everything was fine for the first day. Today it started making a loud squeeking noise as if the belt was loose on it. I thought i put everything on tight after I replaced the alternator. But apparently not tight enough.
    I tried spraying on some belt dressing, it temporarily stops when I am spraying the belt at the alternator pulley, but then starts again as soon as I stop. So I'm guessing the belt is loose.
    My question is, can I tighten this without having to take apart my car (removing headlights, bumper, fan, fan clutch) Or am I screwed. I'm just trying to figure out how to save myself a few hours labor time. i was hoping the top bolt of the alternator was one that could be adjusted, but it doesn't look like it.
    Thanks in advance!
    Hooray for boobies!
    Veteran Member Four Rings Ewok_Fetus's Avatar
    Mar 04 2007
    nothing
    nowhere
    Re: Alternator Squeeking after replacement
    You cannot adjust tension... Did you get a new or use alternator? Is it a constant squeek or is it when low engine speeds and power steering are in effect? Mine squeeks but when I am under 1200 rpm and turning the wheel... Also, I put an alternator on with a fixed pulley when I should really have the freewheel pulley...
    ΜΟΛΩΝ ΛΑΒΕ
    Nov 27 2006
    It is a new alternator. I got it at autozone. It was a duralast replacement for the valeo. It didnt come with a pulley, so I took the pulley off of my old one, and put it on the new one.
    Hooray for boobies!
