Results 1 to 10 of 10
Thread: will these fit?
    Feb 15 2007
    marimont
    will these fit?
    18x8.5 2.5" lip
    18x9.5 4" lip
    et 30 all around
    Also wondering if they will clear A8 and b7 s4 brake setups.
    Veteran Member Three Rings BrokeDown[20V]'s Avatar
    Sep 06 2007
    Re: will these fit?
    I know 100% that the set up will fit and will clear A8 upgrade. I however have no idea about the S4 brakes.
    Original.
    Feb 15 2007
    marimont
    Re: will these fit?
    Well I guess I shouldn't have asked about the s4 rears since they are a little smaller then the A8s.
    So will it not give me any rubbing issues?
    Veteran Member Three Rings nrowensby's Avatar
    May 04 2008
    1999 Porsche Boxster
    Columbia, SC
    Re: will these fit?
    So, I take it 9.5" wide wheels will fit a stock A4? (30-40mm offset?)
    ▄▀▄▀▄▀▄▀▄▀▄▀ B8.5 Squad ▄▀▄▀▄▀▄▀▄▀▄▀
    2014 Audi A4 - Stg2 - Monsoon Gray Metallic
    2015 Audi A4 - S-Line - Ibis White
    Sep 06 2007
    Re: will these fit?
    ^30mm, yess. Aslong as you dont run beefy tires, You have to watch the control arm.
    Original.
    Feb 15 2007
    marimont
    Re: will these fit?
    Are 225/40/18s safe or can I go to a 235/35
    Veteran Member Three Rings aaronamerica's Avatar
    May 31 2005
    Dallas
    Re: will these fit?
    pics anyone??
    1998 Audi A4 built 1.8t Quattro--MaxxEcu Standalone---ID1300cc injectors ---Gt3582 turbo---on E85 --- AEM fuel pump---
    2003 Audi Avant built bottom end 1.8t Quattro 5speed--Eurodyne Maestro---gt35 turbo--- On E85--- 870cc injectors--Walbro 450 fuel pump--19" Staggered iForged Daytona wheels
    2011 Audi Q5 Daily--H&R springs--Eurodyne Stage 1 tune
    May 04 2008
    Columbia, SC
    Re: will these fit?
    Quote Originally Posted by BrokeDown[20V] View Post
    What about a 40mm offset?
    Veteran Member Three Rings soupie69uk's Avatar
    Apr 15 2005
    A4 1.8T quattro
    Scotland
    Re: will these fit?
    Anyone fitted them without too much of a stretch and any poke?
    Pic of my A4
    K04, 034 manifold, coilovers, fmic, stage 4 clutch, plus a few more bits and bobs.
    Veteran Member Three Rings prodrive's Avatar
    Feb 24 2006
    1999 Audi A4 1.8TQ
    Istanbul,Turkey
    Re: will these fit?
    As far as I know if you change the width of the wheels the rolling diameter also changes so this is not good for quattro system.
    Just A4 ... A4 which we know
    2.0L - HTA35 - Cat3658 -Autronic EMS - Autronic 500R CDI etc..
    Feedback: Clicky
