Results 1 to 40 of 58
    Veteran Member Four Rings A4 Moda's Avatar
    Jun 11 2005
    2003 Audi A4 1.8TFSM
    SoCAL- City of Industry
    Is something A-Foot?
    Gt71R Eliminator
    I'm boosting 5 psi at 3000rpm
    :: 10 psi at 4000 rpm
    :: 15 psi at 5000 rpm
    :: 20 psi at 5800 rpm
    What numbers are you guys getting?
    5 spd Manual 2003 A4 1.8t
    Thanks guys
    Z out
    UPDATE::::
    No dentist Drill Sound. That was the first sign I checked for.
    I checked out the other pertinent components,
    1. Lo and behold, I found a huge crack at the top of the manifold.
    2. one bolt completely backed out. It didn't stretch, but it backed out. I could move it around very easily.
    3. I'm not certain, but I'm wiling to bet that the bottom of that manifold is going to be cracked too.
    Oh joy, looks like i'm in for a treat.
    I'm going to have to swap out the manifold.
    Give ATP a call
    and while I'm at it, check the damn flapper on the Wastegate
    Now I'm boosting a tiny it better because I re-tightened that bolt:
    20 psi at 4800-5000 or so
    instead of 5800 rpm
    Eurocode TINY Turbo GT71R Eliminator:: REVO Tuning::
    2003 1.8T
    Eliminator||Carbonio V2||ATP EXhaust Manifold ||Neuspeed TIP (Eurocode)||JOE P MBC @ 22PSI B9- Timing 5||Custom 3" Exhaust||Mangaflow Mufflers|| Revo||Reiger||Boser hood||S4 Bixenon Ecodes||LED Tails||Eibach Coilovers||
    Veteran Member Four Rings RLB6's Avatar
    Sep 20 2006
    '05 MV Agusta F4-1000
    MD
    Re: Is something A-Foot?
    Quote Originally Posted by A4 Moda View Post
    Gt71R Eliminator
    :: 20 psi at 2800 rpm
    Thanks guys
    Z out
    Your turbo is dying a slow death and you mean 20 PSI at 5800 RPMs, correct?
    Also, you should be making 20 PSI by atleast 4200 RPM. Let us know when you figure things out. I'm sure my 71r elim. will give up soon soon, just like every other eliminator turbo sold.
    Current: '23 etron-GT | Prestige
    Previous: S5 | Prestige
    Saint Cloud, Fl
    Today all that I could boost was 15 Lbs, damn coupler
    instagram ------------> low_enforcement
    Veteran Member Four Rings A4 TSCHUSS's Avatar
    Apr 24 2005
    E55 AMG, CTS-V
    Jacksonville, Florida
    im guessing that last part was 5800rpm not 2800 for 20psi right?
    and yes something is wrong. Are you on N75 or mbc/ebc? With a mbc/ebc you should see 20psi at like 3800-4000 and on the N75 you are looking at 4000-4200.
    ~David~
    Gone but not forgotten 437whp on 93 octane and washer fluid injection A4 12.2 best ET, 12.3@119 best overall
    480whp/500wtq E55 AMG 11.6@120
    CTS-V 9.6@148
    Jun 11 2005
    Thanks guys,
    Edited::
    5800, that's correct.
    I'm running MBC only.
    2003 1.8T
    Jun 11 2005
    Quote Originally Posted by 7speed View Post
    CHECK THIS OUT
    thats what you need man.
    2003 1.8T
    Saint Cloud, Fl
    Interesting....
    Sep 20 2006
    MD
    Quote Originally Posted by A4 TSCHUSS View Post
    Nothing to do with the method of controlling boost. His turbo is dying OR there's quite an exhaust/compression leak going on.
    Jun 11 2005
    Quote Originally Posted by RLB6 View Post
    Hmm that reminds me, maybe I have a cracked manifold.
    2003 1.8T
    Apr 24 2005
    E55 AMG, CTS-V
    mine has a little crack on the top I noticed recently and I hit 20psi at 3800rpm right now.
    ~David~
    CTS-V 9.6@148
    Jun 11 2005
    Sweet David, at least you got your car working again man.
    But you have a GTRS, so you'll spool a few hundred Revs faster than mine.
    Well seeing as how things are progressing, probably spooling a few K faster than mine. LOL
    2003 1.8T
    Dec 06 2007
    so if i go BT i should only expect my GTRS to last another 20k miles??? thats stupid!
    -Kirk
    BetaAlphaTau Member #58
    Sep 20 2006
    MD
    Quote Originally Posted by AudiA4Turbo22 View Post
    Pretty much. If you decide to upgrade to a GTRS turbo on your A4, you will most likely push it harder because of power rush you never got from the stock K03 unit. So, the harder you push it, the shorter the life. I personally believe that the true life expectancy on at GTRS turbo is about 35K - 40K miles, pushing no more than 1 BAR. I would imagine that you get the same results by pushing it hard every other week and staying out of boost for the other weeks.
    EDIT: This is just a guesstimate.
    Apr 24 2005
    E55 AMG, CTS-V
    My first one lasted about 16-17k then I got a new center section which then somehow lasted 3 months which then made me extemely pissed so after fighting with ATP for about 2 weeks I ended up getting a 3rd center section for half price. This one has about 8,000 miles on it so far.
    ~David~
    CTS-V 9.6@148
    Veteran Member Four Rings mtbrider's Avatar
    Oct 31 2005
    Virginia
    I going to venture a guess and go with boost leak/cracked manifold.
    Some fast things and some slow things
    ~Josh~
    Dec 06 2007
    so is there a solution??
    -Kirk
    Sep 02 2005
    Montreal
    Yes, make more money
    Sep 20 2006
    MD
    Quote Originally Posted by mtbrider View Post
    I'm gonna stay with dying turbo for $500, Josh
    Dec 06 2007
    ^^haha ya! no seriously now i'm thinking of just going with my K04 idea, because if i'm gonna be spending $1500 every 8 months for a new GTRS thats stupid!
    -Kirk
    Sep 20 2006
    MD
    Yes, either reduce boost levels OR get a full GT28RS or GT2871R.
    Dec 06 2007
    ^^that costs like 5k no??
    -Kirk
    Apr 24 2005
    E55 AMG, CTS-V
    You would only need the center section aka CHRA and you use your existing housings. It was $844 for the 1st one I bought directly from ATP.
    ~David~
    CTS-V 9.6@148
    Dec 06 2007
    ^^haha! thats a K04 turbo every 9 months thats great! what can i do??? i want BT power but if i know that if i step on it to much my turbo's gonna be shot, i'm gonna stay away!
    -Kirk
    Apr 24 2005
    E55 AMG, CTS-V
    well all I can say there is another old member here Entertainment72 had like 28,000 miles on his GTRS and counting like over 6 months ago.
    ~David~
    CTS-V 9.6@148
    Dec 06 2007
    wow what a way to break my excitement! haha every time i step on it i'm gonna think well there goes a week from its life!
    -Kirk
    Veteran Member Three Rings jojoampt's Avatar
    Jan 19 2008
    02' A4 Avant, 1.8T QM, 08' S-Line A3 MT
    Humboldt County
    this is SO VERY VERY off topic but jesus h tap dancing christ AudiA4Turbo22, you joined a month or so before me and you have like 2000 more posts than me... i guess that quote in your sig is fucking gospel! haha!
    Dec 06 2007
    ^^haha! i'm giving Benzworld.org a brake! haha!
    -Kirk
    Dec 06 2007
    so should i stick with a k04?
    -Kirk
    Sep 20 2006
    MD
    To the OP, I'm boosting 20 PSI at 4K exact.
    Sep 20 2006
    MD
    I'm sure I've said this before. If you can source a SK04 (Super K04) that would be your best bet. I know Kinetic used to have these available. I wonder why not anymore.
    Veteran Member Four Rings manhertm's Avatar
    Jan 21 2007
    "Old Yella"
    san antonio tx
    ^^^^^You have to get a custom tune for a Super K04 right? What kind of power can I expect from this turbo?
    ThetaAlphaThetaMember#1
    MY CAR IS ON AN EBAY BUDGET!! DEUTSCH REIS!
    Sep 20 2006
    MD
    From what I've read, about 230 to the wheels.
    Dec 06 2007
    ^^what programming??
    -Kirk
    Sep 20 2006
    MD
    Not sure.
    Dec 06 2007
    the super K04 by Kinetics was an Sk04-015, just had a bigger wheel not a K04-023!
    -Kirk
    Sep 20 2006
    MD
    I'll have to do more research on this. The SK04 that kinetics had was a K04-15 that was machined to fit a K04-23 comp wheel, I think. All I know is that the K04-23 I saw looked nothing like what comes on a TT 225.
    Jun 11 2005
    Holy Threadjack.
    Stop Threadjacking.
    I'm going to check the mani tomorrow and get back you guys.
    Thanks
    2003 1.8T
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    LOL, because the crap turbo fell apart all the time, it was a waste just like the E05. My friend Juan did a modified K04 way before Kinetic and the thing just blew nothing but hot air, so hot that it was heat soaking a EVOms FMIC just in 1 gear pull. The reason it blew hot air was because it was trying to push way too much air out of such a small housing.
    I noticed not one person here asked the OP if the turbo is making the dentist drill sound. If it isn't making any noise then my guess would be something other then a turbo on its way out. Could be a leaking BPV, dying maf, exhaust leak, clogged cat or a WG that has come loose and is open more then it should be.
    Sep 20 2006
    MD
    Ok, so the Kinetics SK04 was crap. Gotcha!
    I'm assuming that the OP would have stated other symptoms if he was having trouble with his turbo but I'm assuming he would have. You bring up good points and things to check. if it's not a dying turbo, a faulty DV is the only other thing I think it could be.
    Jun 11 2005
    Leaking BPV: could be, I have an HKS SSQV set to recirc
    Dying MAF: Brand new Maf, less than 5000 miles on it
    Clogged Cat: No cats here, Just dogs. I'm running a Test pipe
    Wastegate: Yeah thought about that, when I pull off my Manifold, I will check out the flapper
    Exhaust leak: Definitely, the ATP manifold is cracked in at least 1 place, and probably even more.
    Most on here say to set the WG to 10 PSI, any reason not to set it any higher?
    2003 1.8T
