Results 1 to 18 of 18
    Veteran Member Four Rings mioStile's Avatar
    Sep 25 2006
    Vibration at high temps???
    Okay - so I drive 30 miles to school and thirty miles back with no problems (ambient temp around 65 degrees)
    By the time I make it back to the SFV, temp began rising to about 95. When I turned the car on after being parked in the sun, each time I turn the wheel I feel a noticeable, smooth vibration whenever the wheel is turned. The best way I can describe it is as if the wheel is rubbing. What do you think?
    Current Iggnshn: 2007 4.2L 6 speed quattro S4. Neuspeed catback. 20x8.5/20x9.5 BBS RSGT. PSS9. USC license plate. always my work in progress.[/FONT]
    AMA
    Together we can all defeat 2.0T and 2.7T crime
    Ya, I'm that guy...
    Veteran Member Four Rings s6sputnik's Avatar
    95 S6 rs2//13 A6 3.0T//12 S4
    Austin Texas
    Re: Vibration at high temps???
    Tire preasure very high?
    Shawn
    2222 & 620 Austin TX
    // 95 S6 RS2 // 13 A6 3.0T // 12 S4 3.0T
    Veteran Member Three Rings nealRlett's Avatar
    Nov 27 2007
    B7 S4, '71 BMW R75/5
    Steering Fluid? My S4 seems to burn it up.
    Sep 25 2006
    Neal - Does it only seem to happen to you when it's hot? How do you check your steering fluid. Thanks so much
    AMA
    Ya, I'm that guy...
    Nov 27 2007
    I seem to have to top-off every 4-5 months or so. My serviceman says it normal with the S4s.
    Not really sure if that's true but when its low on fluid I get a little noise and vibration with slow speeds.
    It does not seem to be related with outside temperature though. Maybe it's the LA smog!
    Hope this helps.
    Veteran Member Three Rings fitzS4's Avatar
    Mar 17 2007
    audi s4 chevy 2500 HD
    new york
    na it happends with my car too...just add some fluid here and there
    Dec 05 2006
    So. Cal.
    never happened to me with my S4. Also, i forget, do you add fluid when the motor is on of off.
    Sep 25 2006
    Unfortunately, I checked the power steering fluid, and its definitely not low, maybe even a little too high (just slightly over the max line). Any other ideas??? :(
    AMA
    Ya, I'm that guy...
    Veteran Member Four Rings nimski62's Avatar
    Mar 11 2008
    2005.5 B7 S4 6mt, 2002 b6 3.0Q
    Pierceton, Indiana
    AWD Binding noise? if so, its normal.
    Nov 27 2007
    How long does the vibration last after you start the car?
    Dec 05 2006
    So. Cal.
    Quote Originally Posted by mioStile View Post
    Iggy, is the car moving or stationary? If it does it when it is moving, than it is normal.
    Sep 25 2006
    Quote Originally Posted by nimski62 View Post
    What is this binding noise? I've never head about it before and am interested. What does it sound like?
    Quote Originally Posted by nealRlett View Post
    It seems to last for around 15 mins. But, it's hard to say because, as of yet, I haven't driven it for more than 15 or 20 mins with this noise occurring. The odd thing is, it doesn't make the noise after it has been sitting for awhile. Like, when I took it out in the morning after being parked the whole night, it didn't act up after driving it for around 20 mins. Then, when I parked it in the sun later in the day to test it out, it proceeded to make the sound.
    It only makes the sound when it is moving. That makes me feel a bit better, but I am still worried. Has this sort of thing ever happened to you, Ed? If so, could you describe how it felt so we can see if it is the same sound?
    P.S. Thanks so much for all of the replies, everybody.
    AMA
    Ya, I'm that guy...
    Dec 05 2006
    So. Cal.
    Are you speaking of the vibration that you feel in the steering wheel and the car when the steering wheel is in a fully locked left or right position? If so then this is normal and is referred to as Quattro bind.
    If it is something other then this, I would have to see the problem first hand to give a proper diagnosis.
    Sep 25 2006
    I dropped it by the neighborhood audi dealership and talked to the service director. He looked at the power steering fluid levels and consistency and said that everything was fine. He said, as we've been experiencing 103+ temps for about 3 days straight now (and this is when I started noticing), the heat could be thinning out the fluid slightly.
    Ed, maybe at the next meet you can take it for a drive and see what I mean if that wouldn't be too much trouble.
    AMA
    Ya, I'm that guy...
    Sep 25 2006
    Oh, and the sound is not when the wheel is fully clocked - I know what you're talking about there and it definitely isn't that - not as noticeable as that. It feels as if the tires are rubbing (smooth, constant, purring vibration when moving) whenever the car is moving. However, it disappears after about 15 mins.
    AMA
    Ya, I'm that guy...
    Nov 27 2007
    ...maybe at the next meet
    when is this?
    Sep 25 2006
    when is this?
    Do not know. I am not aware of any yet, but I hope it's soon!
    AMA
    Ya, I'm that guy...
    Veteran Member Three Rings DGS4's Avatar
    Apr 28 2004
    fast legs
    Quote Originally Posted by fitzS4 View Post
    odd.. my girlfriend said that to me the other night....
