Results 1 to 6 of 6
    Veteran Member Four Rings Elliott's Avatar
    Oct 28 2007
    Ocean Beach, CA
    Wheel stud engagement
    So I test fitted my new 18" B5 RS4 reps yesterday and the bolt pattern is right but for some reason the wheel studs don't go in as far as on my stock wheels. I would say they engage about 70% as far before they bottom out on the wheel itself.
    Should I be worried about this or should I just regularly check to see if they are tight?
    CEO and General Manager of the AZ Pedal Responce Team
    Deactivated Four Rings
    Oct 06 2006
    South Bend, IN
    Re: Wheel stud engagement
    You need at least 7 full turns of encagement to be safe.
    Oct 06 2006
    South Bend, IN
    You need at least 7 full turns of engagement to be safe.
    Jun 14 2005
    Anaheim, CA
    Quote Originally Posted by Doc@tirerack View Post
    Ditto! 6-8 turns.
    -Charles@VMRWheels
    www.vmrwheels.com
    Brandon @ VMR Wheels
    Oct 28 2007
    Ocean Beach, CA
    Quote Originally Posted by VMRWheels View Post
    Ditto! 6-8 turns.
    -Charles@VMRWheels
    www.vmrwheels.com
    If it does not, where do I find longer studs?
    Registered User Four Rings Mike@PureMS's Avatar
    Jul 19 2007
    San Diego, CA
    We've got all the bolts with matching locks. Check our site!
