Page 2 of 2 FirstFirst 12
Results 41 to 80 of 80
  1. #41
    Veteran Member Four Rings Phrost's Avatar
    Jan 24 2007
    1977 VW Type 2 Westfalia
    Wisconsin
    Re: PIC Request: Blacked out Bi-Xenon housing reflector
    I tinted my ambers also
    Any paint will work, it doesn't have to be high temp. The Xenons burn even cooler than the halogens, but you can use whatever with halogens and it will be fine... It's all up to what kind of finish/gloss you want.
    Ignorance is bliss.
  2. #42
    Jun 05 2007
    Phillips Ranch, CA
    Quote Originally Posted by 12sA4 View Post
    acid, your black out job is the best I have ever seen. Does anyone have any pictures of this done on a silver B7?
    Thx man I appreciate the comment.
  3. #43
    Jun 05 2007
    Phillips Ranch, CA
    Quote Originally Posted by pretarion View Post
    Question...
    What black paint are you guys using? Just standard spray paint? Do you think that the High Heat paint is needed for the temp on the bulbs?
    Here ya go bro. www.Paintscratch.com, they will have everything you will need.
  4. #44
    Established Member Two Rings GEkido's Avatar
    Apr 25 2008
    Miami, FL
    Quote Originally Posted by dandmx04 View Post
    ..what about this , painted almoust all the interior matte black and added leds . Soon will post pictures with them on the car
    AUDI A4 2.0T, QUATTRO, 6MT
    APR 93 , APR FSI PUMP (without softwear update..yet) , APR snub mount
    AWE FMIC , AWE FULL CATBACK EXHAUST , ECODE TEST PIPE , NEUSPEED PULLEY KIT
    FORGE DV , EVOM INTAKE , NEUSPEED SPORT SPRINGS
    Let's see them up!, These LED corners look fresh, I want to see them on..
    2021 S5 Sportback | Glacier White | Sport Package | Black Optic | APR 93 Tune | APR FMIC | AWE CF Intake | 034 F.S.B. | 10/12.5mm Spacers
  5. #45
    Veteran Member Four Rings Doctor's Avatar
    Jun 02 2008
    A4 B7 20vt Quattro,Golf MKV GT
    Greece
    Mine
  6. #46
    Veteran Member Four Rings Bllzll's Avatar
    Jun 09 2008
    b8
    [QUOTE=dandmx04;2642390]..what about this , painted almoust all the interior matte black and added leds . Soon will post pictures with them on the car
    your headlights with the LED blinkers look A LOT like the new headlights on the e90 facelift...
  7. #47
    Account Terminated Four Rings
    Jul 10 2008
    06 A4 / 09 IS-F / 10 Cayenne
    Austin, TX
    Would this look stupid on a silver B7 with silver alloy wheels? any pics? I like the blacked out look, but I feel like you need to have black wheels if you want to complete the 'black out' successfully; especially if you have a light colored car like me. Is that stupid to think that? Any opinions would be appreciated. Thanks
  8. #48
    Jun 09 2008
    b8
    yeah i have a silver car also and am not so sure how it would work. i dont want to black every out, i actually think chrome and silver metallic looks good together. i just dont know how blacked out headlights would look with all of that
  9. #49
    Jun 02 2008
    Greece
    It would kill, especially if you re planning on going with a black wheel later on...
    Chrome is not good with silver from my point of view...Chrome matches well with my blue for instance, or with DG...
    But black goes well with everything...Once black, never go back... :)
  10. #50
    Jun 05 2007
    Phillips Ranch, CA
    ^ Agreed. Black goes good with any color. Or u can color match it to the color of your car if your indifferent.
  11. #51
    Veteran Member Three Rings mrmeth90's Avatar
    Jun 29 2007
    Miami
    color match the housings with your silver and it will look awesome. Ive seen this with ibis white and it was incredible.
  12. #52
    Aug 11 2012
    One Buckled Bicycle
    Sydney, Australia
    Colour coding Bi Xenon housing Dolphin Grey!
    Quote Originally Posted by acidrome View Post
    Well...once you take apart the headlight covers fully disemble the housings from the headlight. After youy fully disassemble the headlight housings you need to prep the housings and the chrome if you planning on painting it like mine.
    1. When you being to prep it begin by using painters tape, tape up all the parts that you dont want painted ie. the inside of all the reflective parts so you dont mess up the lighting.
    2. sand down everything that is going to be painted/clean the area once done sanding.
    3. Begin by spraying light even coats of primer over all the being painted. (about 2 coats)
    4. Once everything is all primered up and its dry begin by spraying light even coats of paint that your using (about 2 coats/however much you need). (in this case black)
    5. Once you finish/let the paint dry hit it with Clear coat (about 2~4 coats or however many u need/want)
    6. When everything is done let it dry completely then reassemble the headlights and your finished all you have to do put everthing back together.
    *DO NOT paint when its windy because the paint will bubble*
    *primer/paint dries pretty quick depending on the temp. atleast 70 degrees n above, between 10-20 min. a coat.*
    *if your gonna paint the chrome like mine, instead of sanding down everything hit it with Acrylic Laquer Thinner, makes the jobs soo much easier.*
    For paint go here: http://www.paintscratch.com/
    They have everything you need here.
    Having seen this after locating RHD Bi Xenons, I just had to go the whole hog! All dolphin grey not much in way of reflectors will be left. Have been taking before and after, plus a few in the making pics. Hope to show it off in a few days! Acid, your car and DIY instructions have given much inspiration and help. Cheers mate!
    Coxy
  13. #53
    Aug 11 2012
    One Buckled Bicycle
    Sydney, Australia
    My grayed out bixenon retrofit... Big inspiration via the Doctors Blue A4 above!!
    [IMG][/IMG]
    If you haven't got left over torq screws, cuts on your hands or 6 beer cans crushed in frustration ... Then you haven't modified it properly!
  14. #54
    Veteran Member Four Rings Schweini's Avatar
    Sep 12 2011
    2011 GTI mk6 DSG
    Hamilton Ontario
    Quote Originally Posted by Coxy View Post
    nice job, your sig made me laugh and remind me of my little box I use for collecting leftover miscellaneous screws.
    2008 A4 S-line 2.0T
    JHM Stage 2
  15. #55
    Feb 25 2011
    Seacoast NH
    Quote Originally Posted by Schweini View Post
    ha, agreed!
    like the sig quote, coxy!
  16. #56
    Aug 11 2012
    One Buckled Bicycle
    Sydney, Australia
    Quote Originally Posted by wildcat333 View Post
    ha, agreed!
    Cheers guys! I have been scoping out all the custom lights on here since I bought my A4. Slowly building up all the bits and pieces needed. Has been a joy to drive and tinker with..
    Seen your blog Schweini.. Such a tidy A4. All class with the chrome on black. Was wondering what globes you have for fog lights? Its a good match!
    Can't believe there have been no additions since 08!!
  17. #57
    Sep 12 2011
    2011 GTI mk6 DSG
    Hamilton Ontario
    Thank you my friend, that's much appreciated and the exact look I'm striving for. I used a 6000k HID for my fogs, I got them from SonicTuning.com. Error free resistors built right in, very happy with them
    2008 A4 S-line 2.0T
    JHM Stage 2
  18. #58
    Established Member Two Rings V6Quatt's Avatar
    Dec 16 2011
    England
  19. #59
    Veteran Member Four Rings Sly Raskal's Avatar
    Jan 22 2007
    Fontana, CA
    I saw something similiar on another car, a silver B7 a couple years ago on this board. Where did you have that done or did you do it yourself?
    -Anil
    2019 A4 Sedan, Nardo Gray, 45TFSI, Prestige Plus, S-Line, Quattro, Black-Optic, PPF, Ceramic Paint Coating, Ceramic Tint, Audi Black Door Handle Kit
  20. #60
    Senior Member Three Rings Dawid's Avatar
    Mar 09 2012
    Denmark
    I know you all might just gonna hate but go all-in and do full black :)
    Nothing worse than chrome on A4's imo.
  21. #61
    Veteran Member Three Rings Adub-Drew's Avatar
    Feb 07 2010
    Wilton, CT
    Makes it look like a cheap ebay headlight kit when blacked out, but to each his own I guess. I just understand why the whole "blacked out this, and blacked out that" thing is so popular...
    B7 A4 tip (daily) Mk6 Gti Drivers Edition (toy) Soon to come Mk4 R32
  22. #62
    Jan 22 2007
    Fontana, CA
    Quote Originally Posted by Adub-Drew View Post
    While I'm against blacking out everything. I think badges, chrome housings, trim etc is enough. I really despise blacked out taillights, tinted headlights, super dark tint, etc. Blacking out functional pieces intended for the safety of you and others I think is stupid, but blacking out other things is the same as any other mod you may do to your car, an extension of yourself/style.
    -Anil
  23. #63
    Aug 11 2012
    One Buckled Bicycle
    Sydney, Australia
    Quote Originally Posted by Sly Raskal View Post
    Agreed.. LEDs when its not OEM looks ricey. Although Flys kit does pull it off, but its still not for me. Blacked out everything seemed massive 5 years ago. A good combination of chrome n low, although tricky, can still look stanced but classy (it is an Audi). Did 10 years ago and still does now.. My 2 cents. For the record I matched my housings Dolphin Grey, so no blacking out. Just sets the OEM lights deeper in the car.. Keep it classy San Diego
    Sent from my GT-I8150T using Tapatalk 2
  24. #64
    Veteran Member Four Rings adub's Avatar
    Nov 20 2008
    spiders
    Orange County
    from back in the day...
    -Andrew
  25. #65
    Jan 24 2012
    Connecticut
    Here are my headlights. Phil blacked them out when he installed the LED's.
  26. #66
    Veteran Member Four Rings nnnick's Avatar
    Nov 01 2005
    2006 S4 6MT
    La Jolla, CA
    Mine:
    B7 S4 at Tempe Town Lake by nickroshon, on Flickr
    Current: 08 R8 6MT, 14 Cayenne GTS, 98 Saleen XP8
    Past: B7 RS4, '12 Audi TTRS BT Build | 2006 Audi S4 HPDE Build | 2006 Audi A4
    Visit my blog: NicksCarBlog.com
  27. #67
    Senior Member Four Rings A410's Avatar
    Feb 29 2012
    2004 Pontiac GTO
    Baltimore, MD
    Wow!! I can't WAIT to do this to mine one of these days. All three of those cars look amazing ^^^ but of course I favor the silver haha
    2008 A4 2.0T Quattro / 3M Matte Orange Vinyl Wrap / APR Stage II+/ APR HPFP / RAI TP / RAI Catch Can / Custom RAI Exhaust / TR-11 FMIC / 034 Motorsports TIH / K&N / AudiUp Race Snub / 640 Mod / Various VAG Mods / New South Boost Gauge / R8 Coilpacks / NGK BKR7E / 200+ Lbs Weight Reduction / 19" RS3s / RS4 Rear Sway Bar / Coilovers / Cupra Lip / LED Taillights / 20% Tint /
  28. #68
    Aug 11 2012
    One Buckled Bicycle
    Sydney, Australia
    Quote Originally Posted by adub View Post
    Bingo! That's the money shot right there. Real tidy adub
    Quote Originally Posted by nnnick View Post
    Mine:
    Nick.. Outside of the forums, I've easily been on your blog the most when looking up Audis. Awesome blog mate and top DIYs! Both White n Red A4s have been all class.. I've looked at those 2 cars a thowsand times! haha
  29. #69
    Aug 11 2012
    One Buckled Bicycle
    Sydney, Australia
    Ahh nice ones. With built ins, happy days. I'll be looking them up! Cheers schweini
  30. #70
    Veteran Member Four Rings Sanjman's Avatar
    Nov 16 2006
    nothing else special
    Skokie, IL
    I love it when old threads come back to life!
  31. #71
    Veteran Member Four Rings seal66's Avatar
    Aug 05 2011
    2008 Audi A4, 2015 Audi A3
    CO
    [QUOTE]
    What ever happened with this setup?
    2008 Audi A4 2.0T
    320awhp/420awtq...E85---UnitedMotorsports Tuned
    2015 A3 8v P-Stock
    2003 A4 Avant 3L-sold
  32. #72
    Dec 22 2009
    2008 A4 Avant
    Bellevue, WA
    Quote Originally Posted by menace1930 View Post
    How much does Phil actally black out when he does the LED mod? Just the chrome parts in the front? I was looking at my headlights and it looks like everyething else is already black or gray (besides reflective stuff around the lights).
  33. #73
    Established Member Two Rings rtop2's Avatar
    Jun 11 2012
    Allendale, NJ
    Finished it today. This is a halogen housing.
  34. #74
    Oct 19 2012
    United States
    This is exactly the look I'm going for. How did you do it?
  35. #75
    Jun 11 2012
    Allendale, NJ
    Quote Originally Posted by m.geezy View Post
    I used these two DIY's
    http://nickscarblog.com/diy/b7-audi-clear-corner-mod/
    http://nickscarblog.com/diy/blacked-...-audi-a4s4rs4/
    2007 A4 B7 | 6MT | 2.0T| ST Coils | TSW Mirabeu 18x8.5 Et32 | Milltek Turboback Exhaust | Stage 2 Revo | HID Retrofitted Headlights | JHM Stage 1 RS4 Clutch Kit | S-Line Conversion
  36. #76
    Established Member Two Rings A4InIowa's Avatar
    Jan 28 2013
    Sioux City, Iowa
    kinda bringing this thread back but has anyone done or have a picture of a B7 with blackout WITH the amber cap? i saw a picture of one with the halogen housing. just want to see how it looks.. doing the mod this weekend
    2013 A4 Prestige | CTS Turbo Intake | Carbon Imports CF High Kick | Avant Garde M590 19x8.5 ET35
  37. #77
    Aug 19 2013
    Miami
    BI XENON threads are so nice. There are indeed beautiful headlights.
    Ivan
  38. #78
    Jan 28 2013
    Sioux City, Iowa
    I know I love them so much.
  39. #79
    Aug 19 2013
    Miami
    Wish i had them in my car :/ i will do a retrofit soon.. not oem but anything but halogens..
  40. #80
    Veteran Member Four Rings Axis's Avatar
    Nov 15 2011
    3.0T 6MT Stage III Allroad | A4 B8.5 Sedan
    Montreal | I sell in USD
    Quote Originally Posted by A4InIowa View Post
    Wagons are made to haul things, mine is made to haul ass
    *****I sell in USD*****
    Click here to read my seller feedback
    B8.5 Allroad 3.0T 6MT Sport Diff 034 Stage II+
