Well...once you take apart the headlight covers fully disemble the housings from the headlight. After youy fully disassemble the headlight housings you need to prep the housings and the chrome if you planning on painting it like mine.
1. When you being to prep it begin by using painters tape, tape up all the parts that you dont want painted ie. the inside of all the reflective parts so you dont mess up the lighting.
2. sand down everything that is going to be painted/clean the area once done sanding.
3. Begin by spraying light even coats of primer over all the being painted. (about 2 coats)
4. Once everything is all primered up and its dry begin by spraying light even coats of paint that your using (about 2 coats/however much you need). (in this case black)
5. Once you finish/let the paint dry hit it with Clear coat (about 2~4 coats or however many u need/want)
6. When everything is done let it dry completely then reassemble the headlights and your finished all you have to do put everthing back together.
*DO NOT paint when its windy because the paint will bubble*
*primer/paint dries pretty quick depending on the temp. atleast 70 degrees n above, between 10-20 min. a coat.*
*if your gonna paint the chrome like mine, instead of sanding down everything hit it with
Acrylic Laquer Thinner, makes the jobs soo much easier.*
For paint go here:
http://www.paintscratch.com/
They have everything you need here.
