Results 1 to 11 of 11
    Senior Member Two Rings Allaidback's Avatar
    May 23 2008
    Columbia, SC
    OBDII Ebay Scanner? Worth buying?
    Can someone please let me know if this is worth buying for $50?
    http://cgi.ebay.com/ebaymotors/ws/eB...MEWA:IT&ih=012
    Veteran Member Three Rings Rajan147's Avatar
    Nov 23 2007
    Columbus, OH
    Re: OBDII Ebay Scanner? Worth buying?
    post a link to the scanner
    do a search on "ebay vagcom" lots of good info there.
    B5 S4 AWE Stage 3 - sold
    Veteran Member Four Rings gointoscott's Avatar
    Jan 26 2006
    2001 Audi S4
    Milwaukee, WI
    That seams a bit high for an ebay obdII I bought mine for around 25 bucks over a year ago off ebay.
    LIke someone else said, post us up a link to the one you are looking at.
    Original K03's, Ecodes, H&R Coilovers, Inmotion Chip/MBC, Piggies
    Apr 18 2007
    ny
    It all depends on what you want to do with it. Do you want to read codes, play around with modules, do live tests?? If all you want is codes than cheap scanner is fine, but if youre looking to do that and more, invest in a vagcom.
    Senior Member Three Rings SoEvoL's Avatar
    May 11 2008
    2001.5 S4
    Bama
    A generic code reader itself is useless, even if its 50 dollars. I would spend a bit more for a Vag com unit or if your just needed a pc based scanner auto enginuity is pretty good for all around obdII pc scantool. Thats just my 2 cents....
    Keep It Simple
    2001.5 Silver S4 Stg 0.5 or 1-
    Veteran Member Four Rings Rated S's Avatar
    Apr 02 2007
    '01 S4 '94 D21
    Studio City, CA
    I bought the $7. Use Vag-Com with it. Does everything I need it to. I do have the full version of Vag-Com though.
    SoCalS4.com/Repair - For All Your Delicious B5 S4 Tuning/DIY Needs
    Don't like me? Feel free to email me and tell me all about it - [email protected]
    May 18 2007
    01 Laser Red 6MT, 13 Touareg TDI
    Baytown, TX
    ebay vag-com = PITA. yu still have to buy the registration from VAG-COM to do anything and everytime you do anything on your computer (such as defragment or system clean up), you have to get a new verification number for the "dumb" ebay dongle to work. It's worth the aggrevation to go with Ross-Tech's any day of the week. I'm actually going to order ross-tech's newest dongle because i'm tired of having to wait for a new code whenever i need to use the dongle.
    Apr 02 2007
    '01 S4 '94 D21
    Studio City, CA
    Quote Originally Posted by RedRocketS4 View Post
    Funny I haven't had a single problem with 9 months of use.
    I do everything from log to scan to change modules.
    Senior Member Two Rings Jayco88's Avatar
    Jun 02 2008
    2000 S4
    just got my $20 generic cable from ebay. Works like a charm.
    -It's got nothing to do with your vorsprung durch technic, you now.-
    Jan 24 2006
    orlando
    has anyone tried this cable? http://www.alpha-bid.com/product222.html i emailed them, but they are pretty vague. he says it works with the new ross-tech 704 software. i was looking for a cable where i can cycle the abs pump.
    Active Member Four Rings
    Dec 11 2006
    Boston
    I bought a generic reader from Autozone for $99
    Stage 3+ RS6's
