Results 1 to 24 of 24
Thread: k04
    Senior Member Three Rings rams456's Avatar
    Jan 05 2008
    Audi A4
    Bay Area
    k04
    considering a k04 for my b7 once it comes out, but i was wondering if it requires a high pressure fuel pump, intercooler, etc to perform well
    thanks
    Junior Member Two Rings kchizTT's Avatar
    May 21 2008
    2001 Audi TT 1.8t Quattro
    Toronto, Canada
    Re: k04
    meh... honestly if your going to change ur turbo, id go bigger... much bigger. k04 is puny man
    Veteran Member Four Rings Sly Raskal's Avatar
    Jan 22 2007
    Fontana, CA
    Re: k04
    Quote Originally Posted by kchizTT View Post
    By that token, whatever is larger than the k04 is smaller than something else.
    @ the OP:
    Get what you want depending on what your goals are for the car and how you drive the car.
    If you are looking to squeeze every HP and ft lb. out of this car, then go for the best, otherwise, get something that is affordable while still giving you the best power.
    If you are going to get the K04, I would get the fuel pump otherwise you may be running too lean for the upgraded programming and turbo. Also, get the reflash at the same time as the turbo if you haven't already.
    -Anil
    2019 A4 Sedan, Nardo Gray, 45TFSI, Prestige Plus, S-Line, Quattro, Black-Optic, PPF, Ceramic Paint Coating, Ceramic Tint, Audi Black Door Handle Kit
    Registered Member Two Rings
    Apr 03 2008
    Cambridge, NY
    Re: k04
    Honestly at the moment no one makes a K04 for the B7
    Jan 22 2007
    Fontana, CA
    Re: k04
    Quote Originally Posted by pakratt99 View Post
    I thought APR was working on something? That's why they removed the BT upgrade from their site for the B7.
    -Anil
    Veteran Member Four Rings DoThisMyWay's Avatar
    Aug 24 2004
    B9Q5
    Honolulu, HI
    Re: k04
    There was a KO4 from APR.
    Current:
    2024|A5 SB PP+ S-line, 2019|Q5
    Previous:
    2017|S3, 2016|A4 2.0T Quattro, 2006|A4 Avant 2.0T Quattro S-line, 2005|A4 3.0 Quattro UltraSport
    Jan 05 2008
    Audi A4
    Bay Area
    Re: k04
    i emailed the sales rep at apr, and he said that it is coming out at the end of july
    Veteran Member Three Rings Josh_877's Avatar
    Aug 24 2007
    Chicago Suburbs
    Re: k04
    yea i remember there was a KO4 from APR, i wonder what they are tweaking?
    Veteran Member Four Rings IceMole's Avatar
    Oct 09 2007
    E46 M3
    PA
    Re: k04
    a bigger turbo
    -Kris
    Aug 24 2007
    Chicago Suburbs
    Re: k04
    Quote Originally Posted by rams456 View Post
    He said a ko4 was coming out? or a BT setup?
    Veteran Member Three Rings 20AE428's Avatar
    Dec 25 2006
    Ontario, Canada
    Re: k04
    The 2.0T K04 is a larger turbo than the 1.8 K04. This will be a great kit when it comes out and makes some good numbers with the reliability of OEM.
    B9 S5 Sportback | Ontario
    Apr 03 2008
    Cambridge, NY
    Re: k04
    APR is working on a BT kit but I don't think there doing another K04 kit. Hoping that there BT kit is scalable for some of us who need something a little more daily drivable.
    In Limbo Three Rings
    Jan 18 2008
    2006 A4 2.0T quattro mt
    central jersey
    Re: k04
    im getting the garrett gt28r from AWE once it comes out
    Veteran Member Three Rings Nico's Avatar
    Mar 02 2007
    Sydney, Australia
    Re: k04
    APR did have a KO4 turbo kit for the B7 A4 (I've got it) however they took it off the market because the KO4 was going up in price(it was already expensive to start with). I was under the impression they were releasing at GT serries turbo kit - A BT kit, however maybe they are working on an upgraded KO4 kit?
    | APR KO4 | APR TP | APR FUEL PUMP | CARBONIO | AWE CBE | S4 DOORBLADES | BBS Ch | TINT | KW V1 | BSH PCV STAGE II | HOTCHKIS F/R SWAYS |
    Jan 22 2007
    Fontana, CA
    Re: k04
    Oh man if they could be working on a larger turbo application but cheaper price that would be friggin' sweet!
    -Anil
    Senior Member Two Rings g_svan's Avatar
    Jul 25 2007
    -01 RS4, -85 90qt(981whp), -19 RAM 1500
    Sweden
    Re: k04
    "Waterfest will be very interesting this year"
    http://forums.audiworld.com/a4b7/msgs/106398.phtml
    I might fly over...
    /g_svan
    Veteran Member Three Rings scoobycarolan's Avatar
    Nov 02 2007
    Albany, NY
    Re: k04
    VAST has a BT kit, but its custom and like 5k!
    Scooby Carolan: Massive Audio
    2008 Ibis A4 2.0T
    Titanium | S-Line | Sport (20% Tint / Debadged)
    APR 93 octane / JHM SS / EVOms DV / Eurojet PCV
    Koni FSD / Eibach Pro-Kit / RS4 Sway
    **Join the Upstate NY Regional Group!**
    Aug 24 2007
    Chicago Suburbs
    Re: k04
    So the first of july huh? this sounds very interesting, if indeed it puts out numbers like the transverse 2.0T... 382hp/332tq on 93 octane! I'd be more than happy with that kind of power and smoothness of daily driving.
    Jan 18 2008
    central jersey
    Re: k04
    if you want a ko4 get it from KMD
    Nov 05 2007
    Auburn, AL
    Re: k04
    Quote Originally Posted by Jersey Stephen View Post
    Allow me to provide some clarification to some of the misinformation that is in this thread...
    APR is no longer offering our original K04 turbo for the Longitudinal 2.0T FSI engine that is in the B7 A4. The current S3 / ED-30 K04 kit that you see on our website will only fit the Transverse 2.0T FSI engine that comes in the Audi A3, VW Jetta, EOS, and GTI.
    Other companies are also offering Transverse Audi S3-based K04 kits (this includes KMD and AWE) BUT nobody that I know of is currently offering a K04 kit for the LONGITUDINAL 2.0T FSI that is in the Audi A4. There may be some folks working on a new K04 for the Longitudinal engine but I haven't seen any announcements. The K04 kits currently being offered DO NOT fit on the Longitudinal 2.0T FSI found in the B7 A4 withouth significant modification and/or plumbing changes. This is not a jab toward any other companies because we also do not currently offer a K04 for the B7 2.0T either.
    Per Keith's statment on Audi World, there will be interesting news from APR at Waterfest this year concerning some turbo kits that WILL fit the LONGITUDINAL 2.0T FSI that is found in the B7 A4. That's all I can say right now about the new kits. I hope this clears up any confusion.
    Jan 22 2007
    Fontana, CA
    Re: k04
    Quote Originally Posted by Mike@APR View Post
    APR is no longer offering the our original K04 turbo for the Longitudinal 2.0T FSI engine that is in the B7 A4. The current S3 / ED-30 K04 kit that you see on our website will only fit the Transverse 2.0T FSI engine that comes in the Audi A3, VW Jetta, EOS, and GTI.
    Other companies are also offering Transverse Audi S3-based K04 kits (this includes KMD and AWE) BUT nobody that I know of is currently offering a K04 kit for the LONGITUDINAL 2.0T FSI that is in the Audi A4. There may be some folks working on a new K04 for the Longitudinal engine but I haven't seen any announcements. The K04 kits currently being offered DO NOT fit on the Longitudinal 2.0T FSI found in the B7 A4 withouth significant modification and/or plumbing changes. This is not a jab toward any other companies because we also do not currently offer a K04 for the B7 2.0T.
    Thanks Mike, Looking forward to hearing the news!
    -Anil
    Veteran Member Four Rings EuroA4's Avatar
    Feb 12 2004
    PA-NJ
    Re: k04
    Sounds like a BT kit featuring a Garret turbo AND a modified K04 kit will be announced.
    But more importantly what happened to the 4.2L S/C ?
    Jan 10 2007
    ATL
    Re: k04
    Quote Originally Posted by DoThisMyWay View Post
    yea there WAS a k04 and they stopped selling it.
    You can still find them out there that were never sold. APR just doesn't have them. :)
    They are working on a Bigger Turbo kit than the K04 and it was said to be out Summer, but I wasn't holding my breath. :)
    maybe we will get lucky and it will be end of July. :D
    07' Sexy Red A4 2.0T * Quattro * S-line * Titanium
    APR 93/100 * APR Fuel Pump * APR Carbonio * MilTek C@TBack * 18" RS4 Gunmetal * RS4 Rear Sway * Kenwood DNX7120
    Jan 22 2007
    Fontana, CA
    Re: k04
    Quote Originally Posted by lokeh View Post
    In case you didn't see post #20.
    -Anil
