Results 1 to 8 of 8
    Veteran Member Four Rings dualaudi's Avatar
    Dec 13 2004
    allroad 2.7t
    san diego
    Exhaust Leak Test?
    I'm hearing a loud exhaust leak. I used an old flange from turbo to my CAT - could this be it?
    Any way to test for leaks in that area? A bolt on the GTRS exhaust side was missing - so I replaced that and it quieted it down a bit, but I still hear an exhaust leak...
    (sold) 1999.5tqm :: gtrs, atp 3"TP, tweaked mika t3/t4 8k, adj. fpr, forge 004, MBC, neuspeed: catback exhaust, E-bay special FMIC! 9"x28"x2.75" - SOLD
    https://www.instagram.com/dualaudi/
    Veteran Member Three Rings audinutt's Avatar
    Jan 11 2007
    2001 A8l 2001 A4TQM Avant
    texas
    Re: Exhaust Leak Test?
    If you had a bolt missing you probably blew out the gasket as well.
    I'd pull the rest of the bolts and check it out.
    -richard
    2001 Audi S8
    2011 Q7 TDI
    2001 A4 TQ Avant
    Jan 11 2007
    texas
    Another way is at idle grab a rag or two and have a helper plug up the tailpipe.
    It should increase flow out of any leak.
    -richard
    2001 Audi S8
    2011 Q7 TDI
    2001 A4 TQ Avant
    Veteran Member Four Rings Euro-Tuner's Avatar
    Jan 06 2007
    NH
    ^^ X2, PUT ON SOME GLOVES if the exhaust is hot and block the tailpipes and listen/feel around the area for air
    Veteran Member Four Rings njm23's Avatar
    Feb 28 2007
    04 a4 USP ; ATS
    or you could sea foam your car and watch the smoke billow out the leak.. haha that is how I found mine. It is very obvious since the smoke is so white.
    Dec 13 2004
    allroad 2.7t
    san diego
    Thanks for the tips guys... i'm going to dread taking the gtrs out, but i might need to.. that's prob my problem right there...
    Jan 17 2006
    Cali
    Uhh, don't clog the exhaust pipe. Use a bit of sea foam and look for the smoke.
    Veteran Member Four Rings t1demont1's Avatar
    May 08 2007
    1999 1.8tqm gt3071r
    Orlando, FL
    sea foam that hoe! its more fun
    BetaAlphaTau Member #40
    1999 2.0 hx35 dbw conversion
