Results 1 to 4 of 4
    Senior Member Two Rings tketke's Avatar
    Oct 07 2007
    Pennsylvania
    fuel injector question
    Can you use higher flow fuel injectors, before you chip the car?
    Established Member Two Rings utripn's Avatar
    Jul 13 2007
    2006 Audi A6 4.2 S-line
    Mission Viejo
    Re: fuel injector question
    software is the only thing that can enable your high flow injectors, without software your car will only push the amount of fuel the computer tells it.
    Veteran Member Four Rings oildrpr's Avatar
    Apr 07 2007
    Huntington Beach, Cali
    you can run them. just don't do it for an extended amount of time.. it's going to run rich..
    Established Member Four Rings A4TL's Avatar
    Nov 06 2006
    335is
    atlanta
    ecu can pull 25% easily and you can run on the rich side if you don't drive hard.
    change your oil afterwards :)
    02 1.8tqs - apr 1+ - SS forge - Hartmann B5 RS4 18" ET35 - Delsa (ebay) spoiler lip - debadged, B7 A4 320mmx30 front brakes - 335i Montego Blue/black; Sport;Prem; iDrive; Step and Heated Seats.
