Results 1 to 7 of 7
    Veteran Member Four Rings JumboBlack1.8's Avatar
    Sep 16 2006
    '98 528i
    Boston/West Hartford, CT
    Some Quick Questions -- Greddy Profec B Spec II Install
    I'm installing my EBC and I've got mostly everything hooked up except for the power line. Where have you guys run your power source from for you boost controllers? I was thinking of running it from the same location that my boost gauge is hooked up to.....I searched, but found no info.
    Ps. I'm STRUGGLING to get my car started right now after finally finishing my BT build. The idle bounces around like crazy, and the car dies. Just installed:
    Siemen 630cc injectors
    t25 GT2871r internally wastegated
    NGK BkR 7e's gapped at .034
    TT 225 MAF
    Ctapp Tune
    ....I'll post fault codes tomorrow...But did anyone experience similar symptoms after their BT install?
    2000 Audi B5 S6 ** 4.2L 40v S6 6spd - http://www.audizine.com/forum/showth...n-s6-4-2L-swap
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Re: Some Quick Questions -- Greddy Profec B Spec II Install
    Connect it onto the 75x post or tap it into a fuse wire.
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Sep 16 2006
    '98 528i
    Okay....just did that.....and it still doesn't power on....
    Jun 04 2007
    Austin/DFW, TX
    do you have a ground? a good one!
    My 5-Speed Swap DIY
    - B6 USP
    Sep 16 2006
    '98 528i
    Yup, used the same ground that my boost gauge is using too.....should I switch it?
    Jun 04 2007
    Austin/DFW, TX
    Quote Originally Posted by JumboBlack1.8 View Post
    Id check your other connections first.
    My 5-Speed Swap DIY
    - B6 USP
    Sep 16 2006
    '98 528i
    This is weird......everything is connected and I'm still getting no power. It won't turn on with the key in the ignition
