Page 1 of 3 123 LastLast
Results 1 to 40 of 93
    Oct 29 2005
    10speed
    San Francisco, CA
    All you 3.0 guys who want power...
    2.7 manifolds = 2.8 manifolds = 3.0 manifolds
    http://www.audizine.com/forum/showthread.php?t=163483
    Can someone do it ?
    - Clint
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    Re: All you 3.0 guys who want power...
    Those guys aren't messing around... that could be a sick set up...
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Clint,
    I'm sorry but your link goes to 40+ pages of info that I have been trying to read up on. My guess, based upon your equation (haha), is that your link would go to an image showing the physical differences (if any)?
    I know the 2.8 cams are different than the 2.7 cams and work well with a twin GT set-up on a 2.7 or 3.0 (2.7 stroked) set-up.
    -Doug
    Veteran Member Four Rings skeeball's Avatar
    Sep 20 2006
    Baltimore
    A large portion of that 40+ pages is garbage too. I know, I've been keeping track of the thread for weeks. A couple of guys are fabbing up manifolds and piping to single turbo their S4's. And then hopefully selling the hardware as a kit. This would bolt right up to a 3.0. The piping should be similar as well, if not the same.
    You would definitely need to build the motor though.
    Dec 06 2007
    ^^how about software??
    -Kirk
    BetaAlphaTau Member #58
    Sep 20 2006
    Baltimore
    Custom ME7 tune or SEM.
    Oct 29 2005
    10speed
    San Francisco, CA
    someone do it!
    - Clint
    Dec 03 2005
    2 pedals 1FG
    connecticut
    What crank are they using for a 3.0 stroker? Does the 3.0L from the B6 fit in the native 2.7 block?
    -Doug
    Veteran Member Four Rings 02silverb6's Avatar
    Nov 20 2006
    ATL, GA
    You will definitely need to build the bottom end. Steve (3.0 King) and I have talked about using the 2.7tt manifolds before. Although not really proven yet, the internals would not be able to withstand that kind of power. I would think that we would need to lower the compression on the 3.0 motor, forged internals, port and polish, etc... Im sure someone who is more familiar with forced induction on this motor will chime in. I have also considered just throwing a 2.7tt once my 3.0 motor goes but all the wiring is just way to complex for the average DIY'er. Hopefully Steve will chime in and shed more light on this topic.
    PM me if you need RNS-E installed in Atlanta area
    R.I.P 2002 Audi A4 3.0
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by 02silverb6 View Post
    to be honest, Im sure pistons and rods would be all you need. Obviously along with any build comes the need for bearings and such but the work isnt much more than a 1.8T, just 2 more cylinders. Obviously the manifolds are a bit more but the power numbers could be insane.
    Im building a single turbo 2.7T in my garage right now, if that goes well Ill keep my fingers crossed that someone asks me about a 3.0
    - Clint
    Oct 27 2007
    2001 Golf 2004 A4 USP
    In the lab
    eh, idk... the 3.0 are aluminum blocks iirc, which means youll want to do a 2.8
    Veteran Member Four Rings sandspeed's Avatar
    Mar 13 2007
    05 S4 Avant Abt AS400 clone, 14 SQ5
    Sunny UK
    The BMW guys have been pushing good numbers (600-1000 rwhp) on aluminum block sixes for years now. An aluminum block is not a prohibitive factor when considering boost. Spacing between the cylinders, compression ratio, and whether the internals will hold out would be the main physical limiting factors, if they even exist. I wish the forced induction community was as big and active here as it is in the BMW scene. Just seems like there is so much incorrect info thrown around here, and very few people are willing to take a chance either.
    -Tim
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by sandspeed View Post
    I concur, someone needs to do this
    - Clint
    Oct 27 2007
    In the lab
    point noted... well the 3.0 in untested, and i personally wouldnt throw several thousand into it when it could be done for another 200 in a proven cast iron block. i dont know what bore spacing is on the 3.0, but i know that the 2.8 block is fine, hence why i suggested the switch to that block... id rather get the unknowns out of the way, esp since its so cheap to do so
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Unknowns are good to test, and find out, but its all about how much risk are you willing to take? And how deep are your pockets to cover that risk?
    -Doug
    Nov 20 2006
    ATL, GA
    If my car wasn't in the shop two or three times every month then I would actually have some money to venture to the dark side.
    Ever since I have gotten my timing belt replaced I have had oil leak after oil leak. As far as the BMW guys pushing 600-1000 rwhp, are these guys going completely custom or just slapping on a kit that has already been made for their motors?
    Custom motor work is definitely not cheap which is why it would be cost effective to go ahead and get everything done at once rather than have the motor pulled two or three times.
    I think that is what is stopping people since not everyone has a couple grand lying around to just throw at a motor that is not even guaranteed to be running right after its all said and done.
    Oct 27 2007
    In the lab
    trust me, they are building their motors at that level... they may even be sleeving the block at that level but ill let sandspeed confirm or deny that
    Active Member Four Rings Maverick's Avatar
    May 03 2007
    german
    heaven/hell
    F80 M3 DCT|C250 Coupe|i3|16 RS7
    B6 A4 3.0 back to stock |B8 S4
    E46 M3 Heavily Modded IR/Black Cloth - track car
    E46 M3 TiAg/IR Moton/GC Track Ready - sold
    E92 M3 Melbourne Red/Black cloth/CF Roof - Exported
    E93 M3 AW/Black Sold
    E39 540iA Minor front end mods. Smashed|E39 540iA Aggressor - sold
    W126 1989 560SEC Totaled
    Bentley Continental GT Black/Black Mulliner Package - sold
    Porsche 944 NA - totaled
    Oct 29 2005
    10speed
    San Francisco, CA
    this would not be a custom really at all... The manifolds are weeks away from being sold to the public... The only things that would have to be custom are the oil and coolant lines, which arent a big deal. Im pretty sure JE or Wiseco could get you some pistons and I'm fairly certain there are drop in rods for you guys.
    I think the 3.0 motor could be a monster for just a bit more than the 1.8T. If I could do one I would but I don't have a 3.0 motor! lol
    - Clint
    Veteran Member Four Rings T0M3K's Avatar
    Sep 14 2007
    Valley Stream, NY
    As an unemployed college student I can only drool of having that under my hood.
    May 03 2007
    german
    heaven/hell
    ^^^ clint, how much do you thnk it will cost for you to build the 3.0 motor. This might gets other guys more into this
    Mar 13 2007
    Sunny UK
    Quote Originally Posted by 317ssayzarc View Post
    Negative. A lot are running stock block 2.8 or 2.5 liter motors, but there are a few high hp 3.0 and 3.2 motors running around too. And the castings for those motors are very similar. There are at least three guys over 600 whp running stock bottom ends, a low-cr headgasket, bigger injectors, and aftermarket or custom intake and exhaust manifolds. One guy even made 996whp on a stock-bottomed 2.8 liter motor for several weeks before a rod went. He was running in the high 700s for a while before they went crazy with the boost and decided to see how long the stock internals would last. The hardcore engine builds I've seen on Bimmers are usually a block that is dipped, cylinders honed or bored for oversized pistons if they are going that way (ie: 2.5 to 2.7 liter conversion for added low-rpm torque, etc.), h-beam rods (everything from Eagle to CP and Arrow has been used. They are all good companies, and more than sufficient for 1000whp on a 6 cylinder), forged pistons in stock config or dished for lower cr (again, many options like Wiseco, Flatlander, CP...), a good MLS head gasket, possibly pyramid or cutting rings (o-ringed head and block), custom intake manifolds (tubular into plenums with velocity trumpets or log-style even. there are a lot of options for them), custom exhaust (again there are options. tubular or log, top mount or bottom mount), and various injector and fuel rail setups, with many different turbo choices. Even twin turbos have been done, although that's very rare. But there are kits out there that can get them 300-500whp, and then you tweak the tune and a few things and crank the boost. It's just disappointing that we are the bastard step-child of the VAG scene. But hey, for years they said the BMW blocks couldn't take boost. Im my experience from research and friend's cars, and from the many mechanics I've spoken to, the Germans tend to over-engineer the engines and transmissions to the point that they can usually handle twice the stock power and torque before breaking. I think if we had a decent manifold and turbo mount setup, along with some good head gaskets, you could probably make 400awhp on these motors. The problem is the tuning and computer stuff. If there was enough demand and we could find a tuner to work out a program for us, the parts wouldn't be hard to get. Custom exhaust manifolds with turbo mounts can be made by a good welder who has a test car to fit them on. And The intake mani could be ported a bit to open up that end. If you got really froggy, you can get a set of forged pistons and h-beam rods for about $1600 made to your specs from a couple places. Eagle or Pauter rods and Wiseco or Flatlander pistons are not too expensive and can make damn near anthing if we have a sample piston or rod. Injectors could be found I'm sure. If I was stateside and had some spare time, I would think about finding a spare motor and a rear-end wrecked A4 to play with. Too bad we don't have a big community that could come together and work on this as a team.
    EDIT: OK, some of those guys have moved on to building the motor with rods and pistons. But who can blame them? If I was doing this, and knew that I could spend another $2k to strengthen my internals, I would do it. Really, for the $5k it takes to get a G3 on, we should be able to turbo our motors and make better power.
    -Tim
    Mar 13 2007
    Sunny UK
    There's really no problem getting parts made. I think it's the tuning that stops most people from thinking about this. If someone had a kit with headgasket, manifolds, intake setup, injectors, and a flash/chip for X dollars, I bet they would sell a good amount of them. Even if you had to source your own turbo, I can't imagine it costing more than a few grand for this. In this case though, it will come down to how much tuning will be, and what will be charged for those exhaust manifolds.
    -Tim
    Veteran Member Four Rings IronAudi's Avatar
    Jun 13 2007
    Middletown, CT
    instead of paying off my CC i would easily drop 8k into my car if this were a more feasible application, thought if i won the lottery id bring it somewhere and tell them to get nuts and 20g later id want 600whp dd
    2018 C7.5 A65 3.0 S BB Bone Stock - for now.
    2008 B7 A4 2.0 T Brilliant Black|20% Tint|18" RS4 Reps LE|Bone Stock Brand new old Engine.
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by Maverick View Post
    Id Imagine for $10k you could have a fully built 600+whp beast with a NASTY torque curve on a 3.0....
    If your pretty good at labor or just want to learn, Id say you could save $3-4k...
    Im building a single turbo setup on an S4 in my garage and to be honest sans the pistons Im almost doing the same exact build...
    Id love to see someone even just build their motor for the time being and see how it holds up.... For a G3 owner whose busted a piston already it would be a good idea
    - Clint
    Sep 23 2006
    Houston TX
    might happen sooner rather than later. But it isn't me, I don't have the extra cash for it, plus my G3 runs fine. But as you said, if I break a piston, different story.
    Sep 20 2006
    Baltimore
    There is at least 2 being built right now.
    Jun 13 2007
    Middletown, CT
    Quote Originally Posted by skeeball View Post
    All smiles right now to see how those come out
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by IronAudi View Post
    yea but they'll be running S/Cs... You need that hairdryer to get the good power
    - Clint
    Veteran Member Four Rings mtbrider's Avatar
    Oct 31 2005
    Virginia
    too bad I dont have a 3.0
    Some fast things and some slow things
    ~Josh~
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by mtbrider View Post
    lol I know right?
    - Clint
    only the intake camshaft is different. exhaust are shared.
    contact via email please.
    Sep 20 2006
    Baltimore
    Too bad I didn't know Clint two years ago when I was shopping for a s/c.
    Jun 13 2007
    Middletown, CT
    Ill trade you straight up.
    Sep 23 2006
    Houston TX
    with his built BT, pretty sure he was joking...
    Jun 13 2007
    Middletown, CT
    Quote Originally Posted by Ill 3.0 View Post
    Thats why i said straight up, after hes done with the BT 3.0 hell have twice the HP so it would work out for him
    Can no one take a joke.......
    Nov 20 2006
    ATL, GA
    We need to have more direction though when this kind of thing gets brought up...Alot of these threads all start and end the same way. If someone knows where we can source forged internals then put a link up. If you know where we can get a port and polish..etc post a link up.
    Sep 20 2006
    Baltimore
    The rods and pistons can be found but there is no link. This stuff is so small volume no one is going to have them available to buy right off their website. You need to pick up the phone.
    Oct 27 2007
    In the lab
    ill get you custom pistons and ill get you a port and polish if you are serious... almost EVERY company does custom pistons and any real performance shop can do a port and polish
    Mar 13 2007
    Sunny UK
    Yep. The easiest way to do this is have a shop measure all kinds of stuff on the block, head, rods, and pistons, and then send whatever info the piston/rod manufacturer needs. Then they can produce pistons to reduce or increase compression ratio. If you just wanted forged versions of our stock stuff, sending in a rod and a piston would be the easiest way, and they would just basically copy the specs. All it really takes is a phone call or two, just like he said.
    -Tim
