You obviously do not know what you are talking about. So please do not repeat incorrect info you heard elsewhere. It does not do anybody any good.
SS lines help in 2 areas. 1) they do not expend under pressure as much as rubber lines, and 2) they provide better protection against road debris. American cars of 80s and 90s and even today had/have very soft rubber brake lines and could benefit from ss lines. But this is B5 S4 forum. S4 OEM brake lines do not expend much under pressure. Thus, there is only nominal difference, which almost completely disappears after the hydraulic force moves through ABS controller and modules. On S4, the “firmer paddle” is just a marketing ploy. BTW, spirited driving “heat” has no real effect on additional expansion of OEM lines. Brake fluid is far more important. Not only there are superior fluids, but even if you use OEM fluid, it must be changed frequently. About once a year. If you changed to ss lines and felt great improvement – 99% of that is fresh fluid. Why track S4s should use ss lines? Mostly debris. During a race, but even during HPDE, there is a lot of it on the race surface – primarily marbles. At very high speeds there is a small chance it could damage OEM line. You simple do not want to be in situation where at the end of 130mph straight you have to make a 90 degree turn with no brakes. Furthermore, on a race car with no ABS or race build ABS, ss line allow for better brake modulation. Bottom line – do not waste money on ss lines for a street S4.
The primary goal of a properly designed floating rotor is to allow metal expansion and contraction under heating/cooling cycle. The weight reduction is a great byproduct of the design. One might safe ~ 10lb per side on the front. However, all of that saving is almost at the center of the rotation and therefore the weight reduction acts similar to reduction of 20lb anywhere else in the car, e.g. ~ 2.5g of fuel. Can your grandmother feel 2.5g less in the tank??? Mine cannot. BTW I am talking about the same size rotors. All BBK have larger diameter rotors, which means you save weight at the axle, but increase it farther out from the center of rotation. If the increase in rotor diameter large enough, you or your grandmother my “feel” added weight rather than any redaction. Bottom line – do not waste money on floating rotors for a street S4.
