Results 1 to 19 of 19
    Registered Member Two Rings Fuzz_Duster's Avatar
    Apr 15 2008
    Scottsdale/Prescott
    Reverse goes forward now??
    So I just put in my new JHM shortshifter, and I followed the online video step by step. I got everything assembled, and all the gears go smoothly. But when I started it up to go test drive it, I went to back out of the garage, stuck it in reverse and it started rolling forward. Took it out, tried again, same thing. So basically every gear INCLUDING reverse goes forward now. Please help.
    Veteran Member Three Rings fikes's Avatar
    Aug 04 2007
    2001 Audi S4 Sedan
    Perkasie, PA
    Re: Reverse goes forward now??
    is that even possible?
    1997 Audi A4 Sedan 1.8t- Sold
    1999.5 Audi A4 Avant 1.8t- Sold
    2001 Audi S4 Sedan- Current
    Apr 15 2008
    Scottsdale/Prescott
    that what I said. But yeah, I went through every gear, one by one, and all of them, including reverse goes forward. It worked fine before I took it out to re adjust it and tighten all the bolts up, so idk what could have happened between then....
    Dec 14 2006
    Halifax, NS, Canada
    are you push down?
    2001.5 1.8T Manual Quattro Celebration | Startup Racing Vogtland Coilovers | Giac X Chip | SPP A pillar with VDO Gauge | Boxster/A8 Front brakes S4 rears | Neuspeed Catback VMR Testpipe |
    NOW DEAD :(
    Account Terminated Three Rings lotusgardener's Avatar
    Dec 24 2006
    1997 Audi A4
    NW & NE
    Did you align it properly. The front of the linkage should be 1.5" from the front of the gearbox. Look in a Bentley, says it right there. Also, you didn't mess with the linkage did you? Because this happened to me, found out the wrong bolt was in there.
    Apr 15 2008
    Scottsdale/Prescott
    yeah but its the upgrade to non-pushdown. Like I said, I installed it, took it for a drive and it worked, just a little notchy, so I took it all apart again, and re adjusted it, and now no reverse.
    Apr 15 2008
    Scottsdale/Prescott
    I didn;t mess with anything. I put everything back just how it was, and it all went in without a problem
    Dec 14 2006
    Halifax, NS, Canada
    so originally your car was push down and you did an upgrade to non push down?
    NOW DEAD :(
    Apr 15 2008
    Scottsdale/Prescott
    right.
    Veteran Member Three Rings soupie69uk's Avatar
    Apr 15 2005
    A4 1.8T quattro
    Scotland
    You sure its not a 6 speed upgrade!! Ha.
    Pic of my A4
    K04, 034 manifold, coilovers, fmic, stage 4 clutch, plus a few more bits and bobs.
    Veteran Member Three Rings jm121189's Avatar
    Jun 05 2007
    Portland, ME
    Don't you need to get the pushdown shifter? I wasn't aware you could remove that feature.
    2000 1.8t A4 qtm gone but not forgotten
    2008 R32
    2015 S4
    Feb 12 2004
    2018 M3 CS, i3 REx
    Orange County CA
    sounds like your going into first... Reverse is on the left of first, correct?
    Former:
    BMW F80 M3 CS
    BMW F80 M3
    BMW I01 i3 REx
    BMW F30 340i M Sport ZTR
    Audi B7 S4 25Quattro
    Audi B5 A4
    Account Terminated Four Rings
    Aug 05 2007
    B5 Nazi Sled
    Indiana
    Quote Originally Posted by JMG View Post
    Not on a B5 A4. It's in the regular 5 speed position. Bottom right.
    Apr 15 2008
    Scottsdale/Prescott
    ok, now its fixed?? I went and started the car again, and tried one last time, and it works now. I went to shift it into reverse, and I gave it a nice tug, and I hear a loud clank noise inside the shaft, and now it works. Something must have been out of alignment...
    Now I feel gay for making a worthless thread. Thanks for the help though guys.
    Senior Member Two Rings ElSnake's Avatar
    Jul 07 2007
    01 Tial 605'd Audi S4 / B5 Audi A4 Avant BT / 17 Tacoma DCLB TRD 4x4
    Long Beach Cali
    i think you didn't align it properly and your not getting reverse because your hitting the sides, iirc thats the problem i had except with 1st gear. try repositioning the shifter. forward or backwards
    Jul 07 2007
    Long Beach Cali
    Quote Originally Posted by Fuzz_Duster View Post
    id go back in there and check the bolts
    Stage 3 Forum Advertiser Four Rings Matt@JHM's Avatar
    Feb 24 2007
    2001.5 S4 Stg III
    Central California
    You didn't align it properly. Reverse was not going forward, you were most likely going into 4th gear because it was hitting the wall...
    You have to get the shifter sitting straight up and down and then tighten down the linkage. If you tighten down the linkage when the shifter is slightly tilting to the side you will not have all the gears. It may explain why it feels notchy too. Watch the videos again.
    JHMotorsports Shop - (209) 968-0077 - [email protected]
    2001.5 Audi S4 JHM Stage III
    Lots 'o Goodies
    Veteran Member Three Rings dingguhlbary's Avatar
    Jul 17 2007
    New Jerzzzzzzzzzzzzzzzzzzzzzzz
    you prob got the angles wrong. if you watch the video, the guys uses like a protractor kind of thing to get the angle aligned back up. good luck brah
    Apr 22 2007
    Riverbank, Ca
    Does it move forward the same as going into 4th? because thats what your doing... You need to readjust.
