Results 1 to 12 of 12
    Registered Member Two Rings
    Apr 03 2008
    MD/NC
    Can someone give me a GOOD way to hardwire the V1
    ok so I have read over so many different ways of hardwiring the V1.
    Anyways I have the v1 hardwire kit. Has anyone done it on a S4 in a manor that they didnt have to take the whole car apart. Someone please help. I just spend 20 bucks on this kit and I can not figure out a good way to wire it.
    Account Terminated Four Rings
    Mar 09 2005
    Widebody S4 Noobs Destroyed: 9
    Santa Clara, CA
    Re: Can someone give me a GOOD way to hardwire the V1
    tap into the fuse box, use the windshield wiper fuse or any of the other numerous switched ones
    Veteran Member Four Rings channad's Avatar
    Oct 14 2007
    2008 S4 DTM; 2017 Q7 Prestige
    Mammoth Lakes, Ca
    STFA
    down the Apilar - slide it in with a credit card.
    tap the fuse box to something switched - Gas pump - 28 or 29....
    ChannaD aka Techno Dad | New DJ Mix | New YouTube Video!!
    2012 Q5 - Black | Black | Premium Plus | S-Line | Nav | B & O
    2008 - DTM | Sprint Blue Pearl | Black leather/Alcantara | Navi | CF trim | OEM 18" RS4s
    Mar 09 2005
    Santa Clara, CA
    Quote Originally Posted by benaudia4 View Post
    ok so I have read over so many different ways of hardwiring the V1 and when I thought I found a good one (using the power from the switches near the sunroof) I ran a volt meeter and found that the connection that other people used did not have power on my sunroof. Maybe this was because mine is a s4 and theirs was an a4.
    i had mine hardwired to the sunroof as well, did you make sure to turn your key on?
    Apr 03 2008
    MD/NC
    Quote Originally Posted by ngng View Post
    Is your a s4?
    What wire did you tape into?
    Can you provide a pic of the install?
    Established Member Two Rings baungS4's Avatar
    Jul 05 2007
    Queens,NY
    I hardwired mine to the Fuse#31..
    Followed this writeup and I had no issues so far.
    http://forums.audiworld.com/a4gen2/msgs/941898.phtml
    Good luck!
    Veteran Member Three Rings quattro.it's Avatar
    Mar 24 2008
    2004 BMW R1150RT
    Bellevue, WA
    This is how mine is wired. It's wired into a 5amp fuse on the right side of the fuse box.
    2007 A4 2.0T quattro Tip S-Line Titanium / Lava Gray / APR 91 /
    Senior Member Two Rings MikeS4's Avatar
    Feb 14 2008
    searching for something new
    Savannah
    like the others said, run it along the roof between the glass and the headliner, down the drivers A pillar using a credit card, back along the seam where the pillar meets the dash, then to the fuse box. use a fuse tap to a switched fuse.
    if your radar detector works while the car is off, you arent using the right fuse. this happened to me, i got done plugged my radar in, it came on and realized my car was off "crap". i think i ended up tapping the fuse for the rear wiper or something non vital like that
    should take you about and hour. that includes driving to radio shack for fuse taps.
    oh and i use an escort so ymmv. pretty much the same concept though
    Dec 30 2007
    Constantly changing.
    DC
    Mine's also hardwired to my windshield wipers.
    Veteran Member Four Rings Eddie Man's Avatar
    Nov 05 2004
    Detroit/Clarkston
    Hardwire just as everyone has mentioned, down the A-Pillar then use an OEM Dash Switch for a remote mute connected to your V1 hardwire kit.
    Also to make it even cleaner, route the cable in through the RVmirror trim plate.
    That's how my V1 is hardwired and it is clean as hell !!!
    I only have about 2" of telephone wire coming out of that trim.
    For more info, click my sig "HwV1".
    2006 S4 Avant
    dolphin gray | 6speed | alcantara | premium | cold | bose | sirius | navigation | bluetooth | parktronic | ebony | carbon fiber
    >>> Got Mods?
    Established Member Two Rings wat2022's Avatar
    Mar 24 2008
    04 S4,98 Jetta
    WA
    Veteran Member Three Rings covertS4driver's Avatar
    Jun 11 2008
    2007 Audi RS4 (Gone), 2005 Audi S4 (Gone), 2002 Audi S4 (Gone)
    Dutchess County, NY
    All these replies are spot on!
    I used the fuel pump fuse. Done in 30 min and the only thing you have to take off is the fuse box cover.
    Installed the concealed display in the ashtray... looks sweet!!
    Eddie: I love the idea of using a stock switch on the dash... that is smooth! What switch did you use?
    2000 Audi A4 Race Car, 2014 Audi SQ5 (Daily)
    Run Silent, Run Swift...
