Results 1 to 12 of 12
    Veteran Member Four Rings S4evr's Avatar
    Mar 07 2007
    Belmont, MA
    Howling while driving.. already did wheelbearing
    when i switched over to my summer wheels this spring, i noticed that there is a loud howling sound coming from the front of the car while driving. Upon deaccelerating, i get a small vibration that feels like it is coming from the front wheels (vibration changes with speed) I thought it was my wheelbearing, so i replaced my passenger front last week, didnt do anything. i am replacing driver front this week to see if it goes away, but wanted your opinion to see if it may be something else. Initial thought after i replaced first bearing was maybe tire noise? they are cheapish tires (wanli s1088) and i noticed some extra wear on the inner side of the tire so perhaps this was the cause? Secondly.. my CV? a couple of months ago (right before winter) the inside of my wheel KEPT getting dirty and greasy.. i thought nothing of it until i switched over to my winter wheels when i saw that my cv boot on the passanger side was torn open. upon realizing this i started banging my head because i had driven close to 600 miles with it torn open (to and from boston and rochester ny) i immediatly got it fixed and no problems seemed to have occured until now. could a damaged cv cause this howl at all speeds and small vibration during low speed deacceleration?
    ThorTechnik.com
    Veteran Member Three Rings alias747's Avatar
    Feb 19 2007
    La Crescent, MN
    Re: Howling while driving.. already did wheelbearing
    I drove on a torn CV boot for FAR longer than 600 miles on my A6. I never had any howling. I wouldn't think that is the problem.
    Check the brakes?
    2010 S4 Meteor Gray | S-Tronic | Sport Diff | Nav
    Mar 07 2007
    Belmont, MA
    what part of the brake system would cause howling?
    ThorTechnik.com
    Registered Member Two Rings
    Mar 05 2008
    2001.5 Black S4
    SLO, California
    I just had both of my front axles replaced a coupe days ago because of torn CV's. It didn't cause any howling though.
    GIAC Flashed ECU++++FORGE 007 DV's++++ECS 2 piece Front and Rear Rotors++++SS lines++++VOGTLAND GT's
    Feb 19 2007
    La Crescent, MN
    I was thinking if maybe one of the pads was rubbing the rotor wrong it might make some noise, but maybe not "howling" as you describe it.
    Mar 07 2007
    Belmont, MA
    ^rubbing pads would make a low grinding noise, ive heard it before.
    would lack of alignment cause howling?
    ThorTechnik.com
    Veteran Member Four Rings gointoscott's Avatar
    Jan 26 2006
    2001 Audi S4
    Milwaukee, WI
    My vote is tires. I have cheap wearing tires that are wore more on inside and they howl like the wind.
    Original K03's, Ecodes, H&R Coilovers, Inmotion Chip/MBC, Piggies
    Active Member Four Rings FrimmelNoJerz's Avatar
    Sep 21 2006
    Norjerz
    ^beat me to it.
    what type of tires do you have? i had kdw's and after the half way mark on wear n tear they begin screaming. its unbearable.
    SBSC
    I also like to live dangerously.
    Mar 07 2007
    Belmont, MA
    Wanli S1088
    ThorTechnik.com
    2000 s4
    Fairfield, CT
    very hard choppy tires tend to make noise and it wont stop sounds like a wheel bearing or diff or something blowing up.
    i heart my s4
    Established Member Two Rings rick_chicago's Avatar
    Apr 29 2008
    B5 S4 (Stg 2), Honda CR-V
    Chicago (NW)
    I agree with tires. Mine howl like mad.
    Try switching back to your winter's for a day and see if the noise goes away.
    Stg 2 B5 S4
    Account Terminated Four Rings
    Sep 27 2007
    hate on me <3
    under the knife in, CT
    restating the obvious. if its not a wheel bearing the only other noise that could cause a howling as speed increases would be tires.
