Results 1 to 27 of 27
    Senior Member Three Rings Stockton's Avatar
    Mar 04 2008
    2004 A4 Quattro 1.8t 6spd
    Palm Beach Co, FL
    Home Link: Does yours work?
    Does your Home Link on your garage door opener?
    I just moved and I programmed mine, it took fine but when I got home it didn't work on the garage door.
    Anyone have problems or solutions with theirs?
    Veteran Member Four Rings CO AVANT's Avatar
    Feb 12 2004
    '03 B6 Avant, '15 B8 A4, '14 S8, '15 Duramax
    Everywhere
    Re: Home Link: Does yours work?
    Can't get mine to code on my craftsman garage door but can on my liftmaster. Was programming fine on my old house with the craftsman but won't on my new house with the same procedure. That learn button on the garage motor isn't learning with the car's homelink. Pain in the ass.
    Active Member Two Rings fumihiko's Avatar
    Apr 17 2008
    sumner,wa
    i have mine set up for the gate at my work and have yet to have any issues with it other than i have to be way close and hold it down for a bit
    Mar 04 2008
    Palm Beach Co, FL
    This is pissing me off I don't feel like buying another garage door opener when my car has it built in.
    Veteran Member Three Rings scorneil's Avatar
    Oct 27 2007
    Oakville, ON, Canada
    works fine for me
    2010 B8 S4 Quartz Gray S-tronic Black Alcantara MMI
    2003 B6 A4 Canvas Beige 1.8T Tiptronic 1+ SOLD
    Dec 06 2007
    it works great here 2! just make sure u [rogram it with the remote first then the garage door learn button! the only thing that sucks is its range, u have to be like 10 ft from the door! in the benz i can open the door from a 100ft away!
    -Kirk
    BetaAlphaTau Member #58
    Veteran Member Four Rings michgo's Avatar
    Oct 21 2007
    Wagon/Variant/Avant A4 B6
    Mine works flawlessly too
    I heart wagons.
    'It's actually a pretty big pet peeve of mine when people mess around with my photos', MmmBoost
    shave it mold it sand it paint it
    Veteran Member Four Rings mnkyA4's Avatar
    Aug 10 2004
    The City
    Mine works great as well. Wish the range was better though.
    03' 1.8T A4 Avant Tiptronic ----- SOLD!!!!
    FUTURE: 2013 Ibis White Q5 3.0T
    Feb 12 2004
    Everywhere
    Quote Originally Posted by AudiA4Turbo22 View Post
    just make sure u program it with the remote first then the garage door learn button
    that's prolly what I was doing wrong. Was hitting the learn button first then programmed...
    Dec 06 2007
    ^^haha the manual says: hold remote control 10-12 inches from passenger side front bumper and have someone push the button inside the car down till the light starts flashing quickly then u have 5 min to push the learn button and then push the button in the car until the garage door light turns off and on!
    -Kirk
    Nov 14 2006
    600hp glorified Beetle, e-tron, 1G DSM
    Gig Harbor, WA
    If your door has a "rolling" (secure) frequency, the Homelink won't work. Secure openers change the frequency every time you open the door, so the car can't learn it.
    For everything else, the Homelink in my car works perfect.
    -Darrick
    Dec 19 2007
    York, PA
    funny you bring this up...i tried to get mine working yesterday. So first:
    press and hold 1 of the buttons down until it SLOWLY fashes...well, that doesnt work. As soon as i press button I (one) it flashes super fast and stops after about 5-10 seconds and then just stays permanently on until i release it. I tried it anyway and continued with programming the transmitter in the bumper but nothing happened. I have NO CLUE wtf is wrong...can anyone help us garage-less souls?
    Senior Member Two Rings BIG EYE's Avatar
    Sep 22 2005
    A4 USP 3.0Q/A3 SLine
    San Diego
    Quote Originally Posted by Capt. Obvious View Post
    My garage opener is a rolling code one and i was able to program it no problem.
    You have to go trough the normal programing procedure with your current remote, and then there is another step that involved the learn button on the garage opener motor.
    Took me a couple tries to get it programmed, but now works like a charm.
    Senior Member Three Rings demea's Avatar
    Jun 12 2008
    2004 A41.8q | 05 Tr. Blzr LT
    Warminster, PA
    Not true. You have to follow the instructions from the opener mfgr. to program the rolling code to your Homelink. I have my A4 and Trailblazer both setup for the rolling code openers.
    Takes an extra step or two.
    Oct 27 2007
    mine works fine with rolling codes
    Mar 04 2008
    Palm Beach Co, FL
    Ok I got mine to work.
    It was the garage door opener. I was falling the car's manual to program for rolling code.
    Luckily the opener had instructions right on it how to program it and it was slightly different but all is well now.
    Thanks.
    Dec 19 2007
    York, PA
    Quote Originally Posted by n7plus1 View Post
    what about me bitches...i searched and found someone with the same problem, but there was no resolution
    Mar 04 2008
    Palm Beach Co, FL
    I originally had the same problem then I read on in the manual.
    When it's flashing fast it means that channel is already programmed.
    To clear all channels you have to hold down the I & III together for about 20 seconds.
    Look in the manual a few chapters after how to program, it tells you how to delete clear the channels.
    Mine was just hold I & III for 20 seconds, I forget what the light does to indicate it's clear.
    Once you clear it though, just start from the beginning.
    Mar 11 2008
    B7RS4 & e46Ms
    Quote Originally Posted by mnkyA4 View Post
    +1
    I figured since the transmitter was up in the front bumper I'd get better range, but to no avail...
    Feb 12 2004
    Everywhere
    Keep holding the button down, might take 30-40 sec, then it should blink slowly. Got my other garage door to work today. Had to hold down and get the homelink button slowly blinking, then went in front of the passenger side of the bumper and held down the opener and let the car lights blink 3 times. Then went over and pressed the garage door learn button, then went back to the car and pressed on the same homelink button for ~30 sec again. Light on the garage flashed and it was set. What brand of garage door opener do you have?
    Veteran Member Four Rings skeeball's Avatar
    Sep 20 2006
    Baltimore
    What kind of range do you guys get? Mine isn't too bad, I can hit far enough down the street that by the time I get to the garage the door is all the way open and I can pull in.
    I've programmed mine with rolling code openers twice. I think you have repeat the procedure 2 or 3 times. I vaguely remember using the instructions on homelink.com instead of the manual. It's been a couple years though.
    Feb 12 2004
    Everywhere
    I can get ~120ft max on mine
    Sep 20 2006
    Baltimore
    Hmm... Make sure the antenna on the opener is coiled up. I guess it could depend on how the garage is constructed also. I definitely get less range on my 1920's concrete block garage than I used on my 1990's cheaply constructed townhouse.
    Active Member Two Rings KingTurbo's Avatar
    Jul 28 2007
    07 Honda CR-V EX
    Pittsburgh
    Mine works
    Veteran Member Four Rings rxrep's Avatar
    Feb 28 2006
    has nothing in it but memories.
    Pittsburgh-Philly
    Mine's rolling and works fine. I had it replaced when I bought the car new and it didn't work (on another house), but has since worked fine there and at my new house as well.
    My 2004.5 APR Stage 3+ is SOLD
    Established Member Two Rings sloweryucf's Avatar
    Feb 21 2008
    2003 A4 1.8T (sport package)
    Orlando, FL
    I wish I had a garage.
    GO KNIGHTS!
    Veteran Member Three Rings sadpandas's Avatar
    Oct 05 2006
    b6 a4 grocery warrior
    High Atop The Eagle Rock
    yeah, mine works i had to hold the 'learn' button on the opener as well. I almost ate it coming off the ladder. Our garage is super tall so the opener is waaaaay up there.
    p
    b6 a4 avant-blk/blk
    2010 Kenny Anderson 'Bar' series, Royal O.G. trucks, 54mm Girl Streamline wheels
