Results 1 to 4 of 4
    Veteran Member Three Rings Gondi Stylez's Avatar
    Oct 22 2006
    B6 3.0 Q
    Calgary, Canada
    Needed: DIY for 3.0Q rotor/pad F/R install... searched
    Help me out please
    PS - I did find some but they were for the B5
    '02 DG A4 3.0Q 6MT | Member of Club 3.0
    .:. OEM+ : Custom I.C.E : Vogtland GT : Hartmann : SPP : Hawk : Goodridge : JHM : Apikol : 034 .:.
    Sep 23 2006
    Houston TX
    Re: Needed: DIY for 3.0Q rotor/pad F/R install... searched
    I'm starting mine tonight, so I can let you know if its different from B5 in terms of bolt size etc.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Front brakes: http://www.audiworld.com/tech/wheel25.shtml
    Rear brakes (scroll down): http://www.audiworld.com/tech/wheel139.shtml
    Rear brakes, I suggest a brake caliper piston tool. You need to rotate the rear pistons to retract them. Front pistons can be pushed in with a C-Clamp.
    -Doug
    Sep 23 2006
    Houston TX
    So I ran into a snag (of course). How do you access the lower hex bolt that keeps the rotor and carrier on on the rears? My lower shock seems to be too close to let me get any kind of socket in there.
