Results 1 to 35 of 35
    Senior Member Two Rings jaykato's Avatar
    May 25 2007
    2009 Mercedes c63, 2001.5 Audi S4 Avant
    NH
    Throwing CEL after downpipe upgrade
    As the title says, I am now throwing a CEL after putting in my Labree downpipes. I put in a GIAC tune, but it didnt help the CEL issue. Curious if anyone has been able to successfully space the O2 sensors to stop the CEL? I know there is not much room for spacing out the sensors behind the cats (I'm getting the below threshold error code), but has anyone successfully done this by rotating the DPs or something similar? I've noticed on some of the Subaru and A4 forums that people have used a spark plug non-fowler to accomplish the task.
    Any insight on this would be greatly appreciated. I know it's not the end of the world to have a CEL for this issue, but I just dont like looking at it.
    Thank you in advance.
    2005.5 S4 Avant Moro Blue.
    GIAC 93, Milltek catless downpipes, Labree catback exhaust, K&N, Bilstein PSS9, 18X8 BBS Diamond Black RE, 35% tint.
    May 25 2007
    NH
    Re: Throwing CEL after downpipe upgrade
    After a bit more research, anyone use one of these?
    http://www.42draftdesigns.com/faq.htm#test
    Mar 12 2007
    Boston
    Sorry, no insight but I hear you on the "just don't like looking at it(CEL)" part. I really, REALLY want DPs for the added sound but, man! it seems like so many have had CELs and other issues as a result of the upgrade. That, coupled with questionable HP gains has me leaning towards a PASS on this mod. I bet it sounds incredible, though!
    SOLD 4/16/15- '08 Daytona Gray RS4/Black leather/CF trim/35% tint/MTM 10mm spacers/Euro steering wheel/GMG catback w/ Magnaflow DPs
    SOLD 9/4/11- '04 Nogaro Blue S4 w/ LaBree Resonated Fullback/ Vogtland Coils/ ECS Snub Mount/18x8.5" et32 Diamond Black RS-GTs
    Oct 11 2007
    Suburbia
    Quote Originally Posted by jaykato View Post
    http://vastperformance.com/shop/prod...products_id=68
    These are the one's I'm using, they work well, and I got em both shipped for 45.00 even.
    Veteran Member Four Rings SuperAvant's Avatar
    May 30 2007
    MA
    First thing is first - what is the code?
    2014 R8 V10 - Gated
    2005 S4 Avant 6 Speed - JHM Stuff
    2017 TRDoffroad 4 Runner
    May 25 2007
    NH
    Quote Originally Posted by WinterRunner View Post
    Winter, did that replace the O2 sensor behind the cat? If so, did you just zip tie the sensor in the engine bay?
    Veteran Member Four Rings 2PUTT's Avatar
    Nov 09 2005
    UBIQUITOUS
    the main reason for the post DP CEL code(s) is that the O2 sensors were switched. try swapping them first to see if that fixes it.
    2009 Audi Q7 TDI
    2001 Audi S4 Avant
    CHALLENGE MW
    AWE | AWE | AWE
    May 25 2007
    NH
    Actually Winter, it's a spacer right? If so, was there enough room to fit both O2 sensors with the spacers?
    And, 2Putt, wouldnt it show up as a swap on a VAG-COM? Right now I just have the below threshold code. That would be very nice if they were just swapped.
    May 30 2007
    MA
    It would show up as one bank running lean while one bank is running rich. Below threshold could be another possibility...
    2014 R8 V10 - Gated
    Nov 09 2005
    UBIQUITOUS
    are they new or used DPs?
    2009 Audi Q7 TDI
    2001 Audi S4 Avant
    CHALLENGE MW
    AWE | AWE | AWE
    May 25 2007
    NH
    They're used, meaning I was expecting to have some sort of issue with O2 sensors. But I did save a lot of cash.
    I am just looking to find some way to trick the O2 sensors to not throw a CEL. The cats themselves looked fine though when I put them in. That being said, it is likely that they arent working as well as they did new, equaling the CEL.
    Nov 09 2005
    UBIQUITOUS
    Sia Bani (AW) used to have Labree DPs. he had very similar issues. it was a flaw in the initial design. you may want to talk to Danny @ Fast Intentions to get some details since he was originally the other half of the Labree partnership.
    2009 Audi Q7 TDI
    2001 Audi S4 Avant
    CHALLENGE MW
    AWE | AWE | AWE
    Veteran Member Three Rings Jdubya's Avatar
    Apr 05 2006
    05 S4
    Dayton Ohio
    You can also use spark plug arrestors. You can get them at just about any auto parts store. I used one on my TT when I put the high flow on there. No more CEL.
    FI DP | FI CB | JHM IM | JHM TUNE | JHM N20 | SB STAGE III/LWFW | PORSCHE BBK | BBS CH | KONI/H&R
    May 25 2007
    NH
    I am going to try Wayne's angle block that I linked to above. I would have tried the non-foulers or the VAST CELiminator, but I have very little room to work with and the angle block put the sensors at a right angle to give the needed space. I'll keep everyone updated to see if it works out for me.
    Thank you for everyone's help.
    Jul 21 2004
    South Florida
    dont plan on o2 spacers or o2 simulators working for more then 200 miles or so. As for the programming, GIAC does not cancel out the low threshold CEL from downpipes so dont worry about it being an issue. APR and Revo do this. According to Labree their cats dont cause a CEL but they dont appear to use a very high quality cat and even their more restrictive 300 and 400cpsi cats seem to cause them occasionally. You can either get APR or Revo or get new downpipes. Make sure it is just an inefficiency code though as you'd want to rule out plugged and broken cats but likely youd be betting misfires.
    cheers! mike
    2018 Audi S5
    Gone-
    Apr 05 2006
    05 S4
    Dayton Ohio
    My O2 spacer worked for thousands of miles with no CEL's at all.
    Oct 11 2007
    Suburbia
    I was told that ANY software for the S4 wont fix the CEL. I spoke directly with APR, and indirectly on GIAC. The o2 sensor spacers work very well. I just got mine in today, I would suggest trying em out at 49$ a pair shipped from VAST. There is plenty of room to fit both the upper and lower o2 spacer. Hope this helps.
    Veteran Member Two Rings intoblue's Avatar
    Feb 15 2004
    07 S4 DTM 6SPD
    florida
    I am not clear as to other peoples experience with downpipes, but my car puts down 291whp with a full labree exhaust system and a drop in k&n filter.
    So i would venture to say that there are marked improvements over stock with these exhaust sytems. In additon i have driven my car for roughly 5000 miles without throwing a cel, but since i have switched out to straight pipes i have thrown a cel once and reset it and it has not come back since.
    Veteran Member Four Rings S-Fore's Avatar
    Sep 17 2007
    I put Milltek DP's on my car and have no issues, never had a CEL (Knocking on my desk with one hand and typing with the other). I do have a tip, not sure if that has any impact on it. 8K mi and I do have GIAC Flash.
    Oct 11 2007
    Suburbia
    Quote Originally Posted by S-Fore View Post
    Milltek Dps with the catback, or are you still running the stock exhaust?
    Sep 17 2007
    Full Exhaust. GMG/Labree, 2.5" all the way back.
    Veteran Member Four Rings Dodge2Dub's Avatar
    Feb 18 2007
    E90 M3; Ducati S2R 1000
    San Diego, CA
    Quote Originally Posted by bhvrdr View Post
    cheers! mike
    LaBree is now using 400 cel ceramic cats because they have proven to be better on our cars then the metal versions used by FI and APR. Go figure, a cheaper cat working better than its expensive counterpart.
    Cool stuff with a little growl!
    May 25 2007
    NH
    Quote Originally Posted by intoblue View Post
    Straight pipes and no CEL??? Maybe my O2 sensors are swapped.
    Registered Member Two Rings
    Apr 12 2005
    LAS VEGAS
    I would try swapping the sensors and clearing it and see if it comes back....But there could also be a small chance the downpipes you bought are burned up. Happened to mine and my friends Labree dp's both around 25k miles. Sent them back for new cats and the CEL went away almost instantly. (I was getting Low Threshold and Misfire Codes)
    May 25 2007
    NH
    I am just getting the low threshold fortunately. Car runs great, so that's a plus. No backfiring at all, I just hate looking at the stupid "lightening-bolted engine" CEL. If I have a burnt cat so be it, I paid very little for the downpipes (maybe that's why, hmmm...).
    Dec 05 2007
    992 911, C8 RS7, Citroen 2CV
    Naples, FL
    I am with GARS4. I bought used DPs and I got the same CEL error. After months of debate and putting fowlers and having the dealer check everything (very friendly by the way for once), it ended up being a bad cat. Learn from my experience and avoid the hassles.
    The easiest way is to uninstall the DP that is throwing the CEL and visually inspect the interior of the cat. Mine had a big hole in it.
    Shipped the DP back to Fast Intentions. Danny put a new cat and no problem ever since.
    By the way, Danny is a great guy and his product is top notch.
    Jul 21 2004
    South Florida
    Quote Originally Posted by Dodge2Dub View Post
    So says they? I dont know how a more restrictive 400 cell cat would be better then a metal 200cpsi cat that doesnt throw a CEL. The only reason to use more restrictive cats is bc the quality of the cat is such that it requires you pick the 400cpsi one in order to not throw CELs. Labree had many cat failures ajnd CELS with their 300cpsi cats.
    cheers! Mike
    2018 Audi S5
    Gone-
    Feb 18 2007
    San Diego, CA
    cheers! Mike
    Agreed, but I was eating FI cats at the rate of a set every two months.
    Since switching to the more restrictive cats, labree claims no failures. At the very least, they offer a one year warranty on the part as opposed to FI's 3 month conditional warranty.
    Veteran Member Three Rings audiblack's Avatar
    Dubai, UAE
    I have the exact same problem. CEL with the low threshold code. I bought my APR DPs second hand as well.
    Is there a way to only change the cat in the downpipe at a local exhaust shop or the bad cat on the DP simply cant be fixed?
    Thanks
    Account Terminated Four Rings
    Apr 16 2007
    New Jersey
    cheers! mike
    my buddy has been daily driving his strait piped s4 for over a year now with spacers his dad made for him and not a cel yet.
    i just got my cat-less dp's put in with the VAST spacers and all is fine. (knock on wood)
    Jul 21 2004
    South Florida
    Quote Originally Posted by 91gl View Post
    They are more miss then hit but since you have Revo you wouldnt get a CEL anyways. APR and Revo take away the cat inefficiency code with their software.
    cheers! Mike
    2018 Audi S5
    Gone-
    Oct 11 2007
    Suburbia
    cheers! Mike
    I was told by an authorized APR dealer that they WOULD NOT clear the codes. Thats one of the main reasons why I went to get the flash at YarrowSports, which I couldn't get anyways because they supposidly don't support the 2005.5 model with a flash(not enough memory?). So I went ahead and got some Vast CELiminator spacers. They work fine...
    Apr 16 2007
    New Jersey
    cheers! Mike
    thats good to know about revo and apr but my buddy has GIAC and never threw a cel because of his lack of cats
    Dubai, UAE
    I got REVO tuning. Code went away then came back on a few days later and its still there
    Oct 11 2007
    Suburbia
    Quote Originally Posted by audiblack View Post
    Same boat as you AudiBlack
    Since my REVO flash, I took the Spacers off, and all was well for about 150 miles, then the CEL came back on.... Any idea why the REVO software ISNT taking care of the CAT deficiency codes? Thanks....
