Results 1 to 14 of 14
    Senior Member Two Rings rings65's Avatar
    Jan 14 2008
    '06 A4 S-Line
    Wheaton/Winfield, IL
    RS4 Swaybar Part # Clarification
    Need some help in determining the correct part number for the Audi RS4 rear swaybar. Multiple posts here list the new part number as 8E0-511-409-AL, but when I enter that in several genuinevwaudiparts.com (and others) that part number come up in the 'Mechanical' section as:
    8E0511409AL $83.19
    Rear suspension - Stabilizer bar
    Stabilizer bar, a4 quattro, s4, 20 mm - a4 w/quattro (2002-07), s4 (2004-07) 2006 - 2007
    So, it would appear that this part number is for a S4 20 mm swaybar? If you input the older number is doesn't give you a detailed listing but it is higher priced:
    8E0511409AM $111.53
    STABILIZER
    Can anyone help clarify which is the correct part # to order?
    Re: RS4 Swaybar Part # Clarification
    You also need the 8E0-511-327-D Mounting hardware for the swaybar. another $5-15 depending on the discount off list.
    Eric Smith
    Champion Motorsport
    Veteran Member Four Rings Sly Raskal's Avatar
    Jan 22 2007
    Fontana, CA
    Quote Originally Posted by ChampionMotorsport View Post
    Is that the bushings or the brackets?
    -Anil
    2019 A4 Sedan, Nardo Gray, 45TFSI, Prestige Plus, S-Line, Quattro, Black-Optic, PPF, Ceramic Paint Coating, Ceramic Tint, Audi Black Door Handle Kit
    Jan 14 2008
    '06 A4 S-Line
    Those are the bushings.
    Jan 22 2007
    Fontana, CA
    Quote Originally Posted by rings65 View Post
    I don't remember if this question was answered previously in another thread, but being that the rear sway has a larger diameter, should the brackets in addition to the bushings also be changed when upgrading the sway to account for the extra space needed for the bar? Or is the bushing smaller?
    -Anil
    Established Member Two Rings smcgann's Avatar
    Apr 03 2008
    2007 A4 Quattro
    Macon GA
    Quote Originally Posted by Sly Raskal View Post
    Yes. Others will tell you, you don't need the different brackets but it is a REAL pain getting it bolted up and it squishes the bushings.
    07 A4 Quattro Quarts: APR I, K&N, RS4 sway-bar, Amp n Sub install, STaSIS Street Sports, chrome mirror caps, ECS under drive pulley, 18" R8 Reps
    Veteran Member Three Rings bengtc's Avatar
    Mar 13 2009
    2012 S4
    Dallas
    Has this question been answered? I am having the same ?'s
    Veteran Member Three Rings maka's Avatar
    May 01 2009
    2006 Audi A4 2.0T Q Auto
    West Vancouver Canada
    yea i'm also looking into ordering from that site. i put up the number and it just gave gave me an S4 bar. :(
    I have them in stock and ready to ship $119 plus shipping, if you want the pipe clips (brackets) I have them too.
    http://shop.dthaus.com/product.sc?ca...&productId=128
    May 01 2009
    i just checked and noticed that genuinevwaudi... doesn't have rs4 parts
    damn i'm dyslexic or something
    Mar 13 2009
    2012 S4
    Dallas
    Can anyone clarify the rs4 bar part number? I was looking into getting one but am confused on the different part numbers.
    In Limbo Two Rings
    May 29 2009
    07 Blk A4
    Minnesota
    Veteran Member Four Rings dblock110's Avatar
    Apr 11 2009
    usa
    just buy the whole kit from ECS, it comes with EVERYTHING you need
    http://www.ecstuning.com/Audi-B7_A4-...ay_Bar/ES7096/
    it should be about 160 total
    Veteran Member Four Rings elwigglero's Avatar
    Sep 04 2008
    B7 S4 DTM, B7 A4 2.0T Ti
    Lansdale, PA
    Quote Originally Posted by dblock110 View Post
    +1
    Where I got mine. Bolted up no problem.
    Justin
    DTM S4 Sprint Blue
