Results 1 to 36 of 36
    Registered Member Two Rings
    Mar 23 2008
    seattle
    3/4 throttle mod
    Anyone else herd anything or have done it? seems like a crock but I've never tried it....
    http://forums.audiworld.com/s4/msgs/935010.phtml
    Active Member Four Rings RogueStatus's Avatar
    Nov 13 2007
    B5 S4 Avant
    Boston
    Re: 3/4 throttle mod
    http://forums.audiworld.com/s4/msgs/495764.phtml
    considering these numbers,i might even try it out...weird
    Veteran Member Four Rings Audi S4 Turbo's Avatar
    Feb 11 2005
    E46 Bmw M3
    Encinitas,San Diego,California
    Weird thing is on both my S4s, this was the case. It was weird, I found out that when I am at WOT my car felt slower than if I were at 60-90% throttle. I thought maybe it had something to do with running too rich by too much throlle input, but it is drive-by-wire, and should adapt. Not sure, but when I give rides I never give it WOT, always 3/4ths.
    Any other input?
    -Justin
    EVT 700 997 Turbo 6MT
    TDI A3 Prestige
    Senior Member Three Rings SoEvoL's Avatar
    May 11 2008
    2001.5 S4
    Bama
    Interesting situation, I've heard of WOT on certain cars (not Audi) isn't really WOT. Its like 80-90% on some drive by wire systems. It's not like old cable systems where 100% is pedal to the metal, the computer can change the throttle position to meet its needs, and that usually means staying emissions efficient on OBDII or TCS.
    Far as the dyno results I don't know, I cant say it works based on one dyno session, I would like to see more people do WOT vs Part Throttle (60-90) with a Log showing the computer recognized it as part throttle the whole time plus the dyno results. I don't doubt anything, I just want to see more proof especially with the actual mod installed, not just someone pushing it and assuming its a certain percent throttle.
    Keep It Simple
    2001.5 Silver S4 Stg 0.5 or 1-
    May 12 2008
    01.5 S4
    Irivne
    Sounds weird to me I agree need more proof and this was covered by the audiforums, I'll try and find it.
    Veteran Member Four Rings casawhites4's Avatar
    Jan 21 2007
    01.5 Silver Avant
    dc
    ill try it, its only a 1.60 to see how i feel in my car..not bad...and will see how it goes, man this stuff is so old, almost 7 years old.
    01.5 Stage 3 Casablanca White S4 (GONE)
    01.5 Stage 0 Silver S4 Avant (New Project, def Grocery Getter)
    watch out Casablanca!!! im coming back with a vengeance!
    Silver will be the fastest now!!! :-D
    Established Member Two Rings Diavan's Avatar
    Sep 16 2005
    Bartlett, IL
    where to get these rubber tips from?
    Conway's Law:
    In any organization there will always be one person who knows what is going on. This person must be fired.
    Senior Member Two Rings momento1's Avatar
    Feb 04 2008
    AUDI 2002 S4
    Sydney, Australia
    We already have the stopper installed here in Australia from the factory.
    i drove around for a couple days with it off once, and car didnt feel the same WOT...
    so quite possibly it does work
    CURRENT - Audi 2002 S4 Nogaro Blue Pearl - Stage 3+ 335Hp atw (but something isnt right...)
    PREVIOUS - Audi 2001 S3 Silver - 230Hp atw
    Veteran Member Four Rings Rated S's Avatar
    Apr 02 2007
    '01 S4 '94 D21
    Studio City, CA
    What if my car was originally H-Box, but put an M-Box in there with the chip?
    SoCalS4.com/Repair - For All Your Delicious B5 S4 Tuning/DIY Needs
    Don't like me? Feel free to email me and tell me all about it - [email protected]
    Established Member Two Rings 2k1.5blacks4's Avatar
    Jul 02 2007
    2001.5 s4
    Birmingham, Alabama
    So this is just for the m-box correct?
    Jan 21 2007
    01.5 Silver Avant
    dc
    what if im using vast software??? with a tcd??? is it the samething im assuming...i cant wait im going to do it 2morrow, but sorry guys cant log it, vag-com is being a hoe...i cant get it properly installed or what not..need help if ya wanna try and help..and ill be able to log it..
    Nov 13 2007
    B5 S4 Avant
    Boston
    i can do this today and log it on VAG. i'll do a pre-rubber piece FATS time and and after maybe?
    Apr 18 2007
    ny
    The reason why the stopper works is because WOT on these cars gives more than 1bar of pressure, which just activates the DV's and cuts power. There is a threshold at around 3/4 which doesn't activate the DV's, giving you max power. I'm curious to know if people with upgraded DV's feel a power loss at WOT.
    Jan 21 2007
    01.5 Silver Avant
    dc
    hmm good question, and def VAG IT NOW!!!
    May 11 2008
    2001.5 S4
    Bama
    Quote Originally Posted by A62TURBO View Post
    x2
    Keep It Simple
    Feb 11 2005
    E46 Bmw M3
    Quote Originally Posted by casawhites4 View Post
    Post immediately after.
    I wonder if there is a difference with stage 3 and non stage 3.
    -Justin
    TDI A3 Prestige
    Mar 05 2008
    2001.5 Black S4
    SLO, California
    I typically drive b/w 1/5-3/4 throttle. However, when I go from 3/4 to WOT, there does seem to be a little bit more juice.
    I'd also like to add, that this is after the GIAC flashed Mbox. Before the flash, when I advanced the throttle from 3/4 to WOT, I was always surprised at how little I'd feel.
    GIAC Flashed ECU++++FORGE 007 DV's++++ECS 2 piece Front and Rear Rotors++++SS lines++++VOGTLAND GT's
    Dec 06 2007
    Calgary, AB, Canada
    LOL, ahhh you guys crack me up sometimes...
    Feb 11 2005
    E46 Bmw M3
    Quote Originally Posted by The_Jerbel View Post
    I was going to say, where is this thread going?! haha
    -Justin
    TDI A3 Prestige
    Veteran Member Four Rings JMTx86's Avatar
    Oct 03 2005
    :headbang:
    Im going to browse audiworld
    00 b5 s4 Single turbo
    1969 Chevy Nova 396 (Full resto, completed in 2016)
    1969 Chevy Camaro 454 (built 454/th400, body is a work in progress)
    11 Chevy z71 5.3 shop truck (Vortech V2 build in progress)
    Jan 21 2007
    01.5 Silver Avant
    dc
    so any info jerbel???
    Apr 18 2007
    ny
    You're the only one laughing, but you haven't given any input yet.
    Jan 21 2007
    01.5 Silver Avant
    dc
    my vag isnt working properly so can someone check this out and tell me if its true or not..and then we can have this settled...just need to log this block they said.
    http://www.audizine.com/forum/showth...throttle+trick
    Dec 06 2007
    Calgary, AB, Canada
    Yes, this:
    is wrong.
    This is the first time I have ever heard of anything regarding 3/4 throttle giving better throttle response or more power than WOT, and frankly I call BS. Don't you think that tuners like GIAC, VAST, APR, etc would have coded their software differently if that were true?
    More air = more power. Airflow @ WOT > airflow at 3/4 throttle. Seems pretty simple to me.
    BTW, the DV's are activated any time there is a boost to vacuum transition in the DV. Power does not = boost. You don't loose boost or power because of your DV's under WOT and constant throttle unless they are stuck open by a mechanical failure.
    Veteran Member Three Rings dak360rt's Avatar
    Apr 17 2008
    Sacramento, Ca
    I have noticed just after reading this and paying attention to how the car feels when driving that when i slam the gas to WOT the car lags badly, and when i hold the pedal less than WOT she picks up and goes
    So far the ass dyno has me believeing.
    Marty
    Light Silver Metallic - 2001.5 S4 - APR Stage 2+
    Piggy Pipes --- CC Mod --- Darintake --- Samco TBB
    AWE Boost Gauge --- 1 touch rear windows up
    JHM Weighted Shift Knob --- JHM Solid Short Throw Shifter --- Custom Straight Pipes
    Senior Member Three Rings GyzmoS4's Avatar
    Feb 07 2006
    Bronx, NY
    ^2nd. I was paying attention on the way to work this morning. Was checking the boost gauge also, and turbos actually spooled quicker at less than WOT than they did at WOT.
    J-Fonz tuned Stg 2+
    "Two wrongs don't make a right, but it makes us even."
    Nov 20 2007
    Murfreesboro, TN
    I am stage 3, and I feel the same thing. I don't know if it is in my head, but it really does feel like the throttle has a faster response at 3/4 than WOT.
    Veteran Member Three Rings OldYella's Avatar
    Aug 18 2007
    Ohio
    Quote Originally Posted by dak360rt View Post
    Marty
    Its turbo lag, if you give the turbos time to spool up or slowly push the gas pedal to 3/4 throttle it will feel faster. That doesnt mean i will be faster.
    2002 TT Silver 225
    2001.5 S4 Imola 6M (Sold)
    Dec 06 2007
    Calgary, AB, Canada
    ^^2nd.
    Apr 17 2008
    Sacramento, Ca
    ....Just like the time my mom told me santa wasn't real.....
    Thanks guys :(
    Jan 21 2007
    01.5 Silver Avant
    dc
    so is someone gonna try this out???
    Veteran Member Three Rings Dowskeet's Avatar
    Aug 10 2007
    Thanks guys :(
    Welcome to reality..
    May 12 2008
    01.5 S4
    Irivne
    wow well i am even more confused now then i was. Still am not buying it.
    Apr 17 2008
    Sacramento, Ca
    Reality sucks I'm gonna so play GTA IV
    Jan 21 2007
    01.5 Silver Avant
    dc
    come on guys...did anyone look into this..someone with a vag..take a second please...e
    Veteran Member Four Rings AMC's Avatar
    Jun 15 2007
    '19 Spektrum Golf RS, '18 Audi TTRS
    rob (xjinct) and i were goin to try this we went to home depot, they had all the rubber tips but were all out of the 5/8 that we needed, i guess all the other s4's beat us to it. if i see some 5/8 rubber tips i will grab some and ill check it out
    the rubber stop should probably help with turbo lag when banging thru gears since at WOT with a stage 3 youll most likely lag, im GUESSING this will eliminate it cause your only 60-90% on the throttle giving the turbos a better time to spool with less or no lag
    dont quote me i have yet to try it
    Driver Supply
    Current
    '19 Spektrum Golf RS DAZA
    '18 Audi TTRS
    Sold
    '07 Stage 3 2.7t swapped B7 A4
    '01.5 Stage 63463 Silver S4
    '13 black Audi S7
    '03 Porsche 911T
