    Jun 15 2008
    Gaithersburg
    VW Oil Spec Info?
    I did a search on a bunch of forums, and found many answers about the approved oil for a B6 S4. However, I also saw a lot of conflicting information. Could someone post a link to some solid info on the VW oil specs? Anything relating specifically to the B6 S4 would be an appreciated bonus.
    Thanks
    Veteran Member Four Rings 3ohAvant's Avatar
    Mar 09 2004
    east bay, CA
    Re: VW Oil Spec Info?
    look in your manual. it will tell you what to use.
    then look up that spec in this list.
    www.vw.ca/SP/ca/pdf/en/oilchart.pdf
    I know audi has a PDF too, let me see if I can find it without too much work... I'll re-update if I can.
    I'm sure you can find the PDF if you search for it here too.
    - Benny
    Feb 12 2004
    2018 M3 CS, i3 REx
    Orange County CA
    Look in your manual and it will tell you what standard your car needs. For my B7 S4 it was VW 502 00. Then cross reference it on this list:
    http://www.audiusa.com/etc/medialib/....0023.File.pdf
    Former:
    BMW F80 M3 CS
    BMW F80 M3
    BMW I01 i3 REx
    BMW F30 340i M Sport ZTR
    Audi B7 S4 25Quattro
    Audi B5 A4
    Veteran Member Four Rings 2PUTT's Avatar
    Nov 09 2005
    UBIQUITOUS
    i replied to your AW post with a link to the PDF listing all the info you need.
    2009 Audi Q7 TDI
    2001 Audi S4 Avant
    CHALLENGE MW
    AWE | AWE | AWE
    Jun 15 2008
    Gaithersburg
    I appreciate the info guys. The manual was the 1st place I looked. Unfortunately my 2004 manual doesn't mention VW oil specs once. The only approved oil according to my manual is ACEA A2 or A3, which I'm sure many VW spec oils are. Personally, I've used Pentosin in my German cars for some time & I've been very happy with it. However, oil brand wasn't what I was after. I apologize if I wasn't specific enough. I was looking for some links or sites that covered VW's Oil Specifications in depth. I'd like to understand the distinction between the different specs, and which vehicles are approved for which oils and why, according to VW.
    Thanks
