Results 1 to 16 of 16
Thread: Avant Down..
    Senior Member Three Rings Avant1.8BT's Avatar
    Nov 05 2006
    mycar
    Avant Down..
    Went around a corner in 4th gear, down shifted into 3rd. doing about 40mph and i hear a loud CLANK CLANK BANG, smoke poors out of my engine compartment. i pull over and all my oil poored out. get the car towed home and started taking it apart. huge hole in my block/oil pan on the turbo side. then on the other side there is also a large whole and what ever flew out of that side broke the peice that connects my motor to the motor mount. i took a few quick pictures. also i went to remove my oil pan and it seems to be stuck... every bolt is removed and i dropped my sub frame so there is plenty of clearnce. im not sure if something is jammed or stuck? or there is just soming stupid that im missing.
    now my options..
    sell my old turbo set up 2871r elim. and then buy a bottom end, put rods and pistons in it then get a 30r.
    sell my car as is with turbo kit, take out a loan and buy an s4.
    or.....suggestions
    first..
    then..
    Veteran Member Three Rings audimuse's Avatar
    Aug 10 2007
    09 MB C63 AMG
    denver, co
    Re: Avant Down..
    damn that sucks. good luck with whatever decision you decide to make.
    Veteran Member Four Rings TighTT's Avatar
    Feb 21 2006
    Widebody'd avant with AZR 3.0 TTE 950+
    NJ/NYC
    Re: Avant Down..
    2nd on that sucking big time.
    50% Blood
    50% Sweat
    50% Forced Induction
    Thats 150% motherf*cker.
    Established Member Two Rings Dlay's Avatar
    Apr 22 2007
    2006 A6 4.2 Quattro
    Greensburg, Pennsylvania
    Re: Avant Down..
    Damn dude good luck with the fix. Id go with an S4 if you decide to sale, nothing else.
    Veteran Member Four Rings Jibberific's Avatar
    May 22 2008
    az
    Re: Avant Down..
    damn dude. update once you get it apart more.
    and i think you should rebuild it. we have the technology
    {99.5 Avant}
    Veteran Member Three Rings creechsa4's Avatar
    Jan 06 2005
    san diego
    Re: Avant Down..
    sorry to hear that bud.. hope you get it on the road soon. that's a sick ride you have. you may have thrown a rod or two.
    i've been imploring peeps that go BT to get some sort of h beam rods to support that kind of abuse these motors take from BT's. hopefully more people will consider this when going BT in the future.
    heres one of my 'suggestion posts'.
    http://www.audizine.com/forum/showthread.php?t=216132
    82mm je pistons, scat rods, ported & polished aeb head. gt2871r, atp hi flow manifold (ported). 580cc injectors on custom giac tune. Once you boost, you'll never go back....
    Nov 05 2006
    mycar
    Re: Avant Down..
    Looks like i will be picking up a new block this weekend. so my plans right now are..
    scat rods and je pistons/rings.
    i might just stick with me elim 71r for now. gunna get my motor built then see how much i have left for a new turbo/mani/tune.
    ive never rebuilt a 1.8t so any advice is helpful
    thanks.
    Veteran Member Four Rings 20vpower's Avatar
    Oct 05 2006
    1998 A41.8TQMS
    San Jose, CA
    Re: Avant Down..
    jesus, how much boost were you running? e/mbc?
    Previously: 12vPower
    97 12v fwd CACTUS GREEN (SOLD... thank god)
    98 1.8tqms MELANGE 50 trimd
    Veteran Member Four Rings audiness's Avatar
    Jan 26 2007
    Charleston SC
    Re: Avant Down..
    dam dude
    Veteran Member Four Rings UN-PIMP-Z-A4's Avatar
    Jan 29 2007
    MR VTEC Lives...
    Yes We Can!!! Obama N Beyond!
    Re: Avant Down..
    looks like you already made your decision.
    I would have sold as is and upgraded to a newer whip
    Homebrew PES Powered Stage 3 A4 1.8TQM It can be yours for only $5k PM for details
    I have a JUSTINTERCOOLER 27 X 6 X 2.75 WITH 2.5" inlet / outlet (Brand New in Box) FMIC for Sale $90
    QUOTE OF THE YEAR:
    "Another thing, dont go flashing 15 second timeslips!"
    Nov 05 2006
    mycar
    Re: Avant Down..
    Quote Originally Posted by UN-PIMP-Z-A4 View Post
    thought of that but i have alot of money into my car so im just going to build and hopefully bore out the bottom end and keep my 71r for now.
    Veteran Member Four Rings Euro-Tuner's Avatar
    Jan 06 2007
    NH
    Re: Avant Down..
    I'd vote S4 but GL on whatever you decide to do, that must have been a shitty feeling, hope I never experience that....
    Oct 30 2006
    B8 A4 Avant 6spd
    Re: Avant Down..
    Shot a rod.. Wow, well, it would be cheaper to get a new block and build it up than getting rid of the entire car.
    -18 718 GTS
    Nov 05 2006
    mycar
    Re: Avant Down..
    yeah, im getting a block on saturday. mike is helping me out with some parts to build up my bottom end. hopefully ill pull the motor this weekend....never pulled a 1.8 quattro motor before.
    any hints? suggestions?
    thanks.
    Veteran Member Four Rings Sleeeper X's Avatar
    Nov 20 2007
    01.5 S4
    The city with tall BUILDINGS!
    Re: Avant Down..
    I'm sorry to hear, but IMHO I'd get a new block and build it. 30s and 35s are faster then most stage3+ s4's. Good luck with what ever you decide.
    l gotta-- l gotta get
    a form from a scientist.
    Nov 05 2006
    mycar
    Re: Avant Down..
    do to just graduating highschool going into college money is pretty low. so im going to bore out my stock block to a 1.9 and keep my 71r. then hopefully go 30r in the fall.
