Results 1 to 37 of 37
    Veteran Member Four Rings Phrost's Avatar
    Jan 24 2007
    1977 VW Type 2 Westfalia
    Wisconsin
    Sedan Rear Bumper Removal
    Hey guys, been real busy lately but I needed to get this off to get it repaired and resprayed tomorrow. There are no DIY's anywhere for this, so here you go.
    The good news is you don't have to remove the rear wheels at all to get the bumper off! Here is what you'll need:
    T30 torx driver
    T25 torx driver
    10mm socket with ratchet
    1. Fold down both rear seats. There is a bracket between both of them that you're going to have to take off. The plastic cover comes right off, so just pull. There is a metal piece beneath it that is held in with a T30 torx screw.
    After you remove that bracket: take either seat, lift up on the side where that bracket was holding it down, then slide it toward the opposite side of the car. The whole back of the seat should come loose, and will be held on by one wire if your seats are heated so be careful with that. Remove both seat backs
    2. There are 4 metal tie-down hooks on the floor. Snap all of them upright, and remove 2 T25 torx screws from each of the four hooks.
    3. Now look at the plastic trim against the rear bumper, where the trunk latches onto. There are two gold 10mm nuts holding this on. Remove the two nuts, then force the rough plastic piece straight up. It is held down with clips so you'll have to tug.
    4. Now we're going to remove both carpeted sides of the trunk. There are two black plastic push pins on the top you'll have to pry out. Then start behind the rear seats, and pull the carpet toward the center like so
    Stand by the trunk and work the carpet out. It's easy, but there is a metal clip toward the top center (you can see) so make sure you look at how you have to slide the bottom out first to not rip the carpet.
    Also, there are two bare metal clips on each side. You don't pull these out, you slide them to either side (up/down). Metal clips are shown here
    5. The carpet on both side are the same, so take your time with those. However, there is the big cubby hole on the driver side that will need to come out.
    It is held in with 4 10mm screws, one by each corner. If you have satellite radio or not it doesn't matter, the wires are long enough for you to remove this cubby hole thing and place it aside.
    6. Now it's time to take out the nuts holding the bumper in. There are a total of 5 10mm nuts on each side. Take all 10 out and put them somewhere safe
    7. Move down by the fender liners, and remove the bottom 3 T25 torx screws holding the liner in. If you only have a long torx driver you'll have to go in at an angle, and if that doesn't work you may have to remove the rear wheels. I had a T25 torx bit I attached to a socket that worked nicely
    Remove the bottom 3 torx screws from each side, peel the fender liner back, and remove a total of 8 more (4 on each side) T25 torx screws holding the bumper on.
    Once all of these screws are out, tug on the end of the bumper away from the car. There are 5 snaps on each side you're going to have to pull out.
    8. Look under the rear bumper, where the valence attaches. There are 2 T25 torx screws that will come right out. You can see them if you just bend down and look up, they're right by the edge.
    Once all the snaps are out and all screws/nuts holding it on, the whole bumper will pull off the car with no wires or anything attached to it. That's it!
    Great success
    Ignorance is bliss.
    Active Member Four Rings 3.2some's Avatar
    Dec 19 2007
    ..is full of crap I dont need
    Escondido, CA
    Re: DIY: B7 sedan rear bumper removal
    good job bro, suprised you didn't heat gun it off........hey admin dude, can you sticky this to the DIY section.....thank you
    V/R -Phil
    B7 2006 Audi A4 3.2L Tip FWD Brilliant Black
    Jan 24 2007
    Wisconsin
    haha no, this DIY was too easy to include a heat gun.
    Edited for sweet photobucket arrows and stuff I added
    Ignorance is bliss.
    Veteran Member Four Rings Sly Raskal's Avatar
    Jan 22 2007
    Fontana, CA
    Thanks for the write-up, but did you decide to take the bumper off for the hell of it or did you do a mod with this? :P
    -Anil
    2019 A4 Sedan, Nardo Gray, 45TFSI, Prestige Plus, S-Line, Quattro, Black-Optic, PPF, Ceramic Paint Coating, Ceramic Tint, Audi Black Door Handle Kit
    Veteran Member Four Rings cstarky15's Avatar
    Feb 16 2008
    Oakdale, MN
    way to go. and good job on getting all the photos and making them all work! If i ever need to take off my bumper i'll follow your DIY.
    The usual things!!
    Resistor Install
    Dec 19 2007
    Escondido, CA
    Quote Originally Posted by Sly Raskal View Post
    read the top....again
    V/R -Phil
    Jan 24 2007
    Wisconsin
    I took it off for 4 reasons.
    1. When I bought the car used, the guy who leased it obviously got rear-ended and the dealership did the cheapest, shittiest job ever trying to fix it. Orange peel is really bad, you can see where they masked around all the cracks, and there are big "runs" in the paint where the bumper creases because they didn't even paint the whole thing.
    2. Because of the shitty paint job, I had a big section of paint chip off while washing it. I put touch up paint on it for now
    3. Last winter, some kid slid into me at my friends house and never told me. I confronted him the next day and he said he "looked at my bumper and didn't see any damage". He had an 80's truck, and he pushed me car a good foot out of my parking spot. It was dark so I never noticed. Hi everyone!
    Definitely needs a respray, but the paint is also cracked (from stretching) so it has to be repaired and reinforced from behind. When painting a bumper, it is much easier (cheaper labor) and will look better around the edges/cracks since it doesn't have to be masked off.
    4. Robie told me to
    Ignorance is bliss.
    Jan 22 2007
    Fontana, CA
    Quote Originally Posted by 3.2some View Post
    read The Top....again
    Doh!
    -Anil
    Jan 22 2007
    Fontana, CA
    Quote Originally Posted by Phrost View Post
    4. Robie told me to
    Yea, sorry, I completely missed that first line in your post about needing to take it off for repair.
    What else does ROBIE tell you to do?
    -Anil
    Jan 24 2007
    Wisconsin
    People with Mk5 GTI's have their Fast, and I have my Robie. He rides with me wherever I go, sharing our magical adventures and giving me pieces of his incredible wisdom as we ride down the road of life together.
    Ignorance is bliss.
    Jan 24 2007
    Wisconsin
    Also I just wanted to point out, taking out the rear reflectors is extremely easy. All one has to do is remove the 7 T25 torx screws from each fender liner, pull out the snaps, then easily snap out the reflector. I'm not even pulling the bumper out all the way in this picture
    People used to ask this question all the time and the response was always, "sorry you'll have to remove the rear bumper. Not gonna happen." Now we have proof it is easy
    Ignorance is bliss.
    Veteran Member Three Rings Zebman's Avatar
    Dec 25 2007
    '06 A4, 08 R6s
    Morgantown/Hurricane, WV
    Does anybody make smoked reflectors for the back? Do the front ones fit the back?
    2006 A4Q 6MT Arctic White - StageII++
    STaSIS SS Coilovers, EVOMS Intake, APR 93, OZ Ultraleggeras 17x8, APR Exhaust w/034 HFC, GSG Intake Pipe, AWE Front Mount, APR HPFP.
    2008 R6s
    : Racebike, don't feel like writing it all out.
    I don't get on Audizine anymore, so if you need me... sorry.
    Jan 24 2007
    Wisconsin
    No, the front and rear reflectors are different. Picture courtesy of ddfunkt: (front reflectors on top, rear on bottom)
    I have never seen smoked rear reflectors for sale, but people tint their oem reflectors. Lamin-X or other brand tint can work, and I sprayed mine with NiteShades.
    Ignorance is bliss.
    Veteran Member Four Rings Doctor's Avatar
    Jun 02 2008
    A4 B7 20vt Quattro,Golf MKV GT
    Greece
    Great DIY. Pretty easy, but helpful nevertheless. Great
    Veteran Member Four Rings redlabel81's Avatar
    Nov 24 2007
    A4 1.8TQ 2005.5 + A6 1.8T 1998
    Tromsoe, Norway
    Good DIY. Robie knows his shit!
    Life is too short to drive ugly cars!
    Phantom Black B7 A4 1.8TQ Avant
    //BSR PPC stg 1, 98 Oct//BSR cat back//S-line front rebuild//S-line suspension//Supersport loweringcaps//Votex valence//S4 doorblades//RS4 mirrors//S-line roofspoiler//S-line door sills//LED interior//Hoen fogs//mTec 6000k HID//RNS-E//S4 grill//MMR HR4//H&R 8mm//Dectane HL//LED licenseplight//Euro RS4 steering wheel//Sonniboy "Tint"//RS4 rear sway//
    Senior Member Three Rings georgio3gr's Avatar
    Jul 14 2009
    Greece
    Nice DIY... But what if the rear seats cannot fold down as mine???
    Oct 20 2008
    Denver
    sweet write up. I was hoping to find a way to take off the rear
    Veteran Member Four Rings A4A4A4's Avatar
    Jun 02 2008
    Victoria, Canada
    Quote Originally Posted by georgio3gr View Post
    Are you sure your rear seats don't fold down? Do you not have the handles right beside the rear headrests?
    -Cam
    New: MK6 Volkswagen GTI
    Old: E92 BMW 335i
    Older: B7 Audi A4 2.0T Quattro
    Sep 23 2009
    2006 audi a4,
    whered u get robie??
    Jun 02 2008
    Greece
    Quote Originally Posted by A4A4A4 View Post
    Yes. Folding rear seats is an optional extra.
    Jul 14 2009
    Greece
    Quote Originally Posted by Doctor View Post
    +1 Unfortunately my car does not have folding rear seats...
    Jun 02 2008
    Greece
    On our order, noone even mentioned it @ the dealership....
    Having added more than 10k of extras, 100euros wouldnt have been anything really...But hey...
    Greek stealership FTW....
    Jan 24 2007
    Wisconsin
    I was unaware folding rear seats was an option. If you're don't fold, look for bolts from inside the trunk or something. I'm not positive the rear seat backs have to come out, but it really made removing the side pieces a lot easier.
    Quote Originally Posted by s-man View Post
    Radio Shack in like 1982 lol. I have one more in mint condition that works, I'll ship it to the highest bidder
    Ignorance is bliss.
    Jun 02 2008
    Greece
    Yeap, they dont.
    Audi A4 in an RS4 body
    Mike
    Sep 23 2009
    2006 audi a4,
    really, wered you get him
    Veteran Member Four Rings toaster's Avatar
    Sep 16 2005
    Gone:A4 USP+ / A4 S-Line+
    long island, ny
    dude, robie eats CHANGE!!!
    ...he's gonna get sick and shit all over your car!!!
    ahhhhhhHHHHHHHHHHHHhhhhhhhhhhhhhhhhh!
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    Necro-bumpage, I will be using this to install my DTM rear this week.
    Jun 02 2008
    Greece
    ^^ piece of cake, dont worry....very straight forward...
    Mike
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    That rear seats/wiring thing worries me, but other than that it should be cake. I'm guessing about a half hour total?
    Jan 24 2007
    Wisconsin
    If you take your time. Once you figure out what the be gentle with and what to rip out, it takes about 15 minutes.
    And don't worry, that wire is only for heated rear seats. But either way, there's plenty of slack where it isn't really in the way. Just set them aside
    Ignorance is bliss.
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    What does the wire connect to? Can I not worry about that? I'm switching complete bumper covers here.
    Jan 24 2007
    Wisconsin
    I didn't see where the harness connect was. But don't worry about it, it's long enough to give you enough slack to slide the seat backs aside. The only purpose of removing the seat backs is so you can smoothly remove the carpeted side panels if I recall. Only takes a minute.
    Ignorance is bliss.
    Jun 02 2008
    Greece
    IF and only IF, your rear seats' back is folding downwards...otherwise...it is not so easy...
    Mike
    Feb 06 2009
    328d, Tacoma
    Woodland Park, Colorado
    And I shall begin using this today.
    EFR 6758 by UM
    Info:
    Build
    Pics
    Feat'd AZ'er
    Feb 06 2009
    328d, Tacoma
    How did you guys remove the silver trim piece (near the trunk)?
    EFR 6758 by UM
    Info:
    Build
    Pics
    Feat'd AZ'er
    Veteran Member Four Rings mcpcartier's Avatar
    Oct 15 2011
    12 Taco, 13 Ex, 16 Civic EX, 15 JKUR
    Been a while but wondering if you have any info on this?
    2007 2.0T Q 6MT, S-Line, Ti Package, BB
    Revo Stage 2 | JHM Stage 1 Clutch | K&N Drop in | APR HPFP | 034 HFC | AWE Catback | 034 SD Tranny & Motor Mounts | Neuspeed Snub | H&R Sport Springs | Bilsteins | Moog ACA | B5 Perches (removed) | RS4 RSB | ABT Drilled n Slotted Rotors | Redstuff Front & Akebono Rear | Podi Stepper Boost Gauge | Recaro's | H&R Spacers 15f/20r | Clear Corners w/Blackout | Smoked Frt Markers | Cupra R Lip | 20% Tint
    Established Member Two Rings CVTwhatadumidea's Avatar
    Jul 16 2008
    2010 MB C300 4Matic Sport
    Fort Wayne
    Just got finished removing my rear bumper with the help of this great DIY! A couple of things that were different for me, I have a wire that was holding in the passenger rear seats, but do not have heated rear seats. The PITA clips that hold the carpet in the trunk; I had 6 instead of 4.
    I couldn't find it anywhere, but to remove the trim (the aluminum look piece of plastic):
    1. I taped up the blade of a putty knife so it wouldn't mar the part... slide under either end of the trim piece, between the trim and bumper.
    2. Gently press down, and work your way from one end of the bumper to the other.
