Results 1 to 4 of 4
    Senior Member Two Rings TeeterTawter's Avatar
    Mar 26 2007
    2000 Audi A4 1.8T
    sauga
    A/C won''t turn off..its cold
    A/C won't turn off, the fan won't go higher or lower, niether will the temp, can't defrost or anything. the controls for the a/c are not working and its getting cold in there. no vag codes either. any ideas?
    thank you
    Sean
    Veteran Member Three Rings audinutt's Avatar
    Jan 11 2007
    2001 A8l 2001 A4TQM Avant
    texas
    Re: A/C won''t turn off..its cold
    Module master.com they have a kit less than $100 to fix you up.
    -richard
    2001 Audi S8
    2011 Q7 TDI
    2001 A4 TQ Avant
    Veteran Member Three Rings dingguhlbary's Avatar
    Jul 17 2007
    New Jerzzzzzzzzzzzzzzzzzzzzzzz
    in the mean time, just pull the fuse brah
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    hey, at least its not the other way around!
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
