Results 1 to 1 of 1
    Jun 15 2008
    Rockville Md
    K03's sounds like a cat not a cop
    Had a misfire
    Replaced plugs
    mis is gone
    30 miles later I down shifted to a stop and when I went to take off it sounded like a Subaru. I didn't over rev!!!!!!!!
    running on maybe 4 or 5 cyl
    loose metallic noise coming from drivers turbo not loud enough so be a thrown wheel
    once it started to spool the turbos only built 5 psi and sounded like a cat not a cop!!!!!!!!!
    than on driving the next day to try to diagnose, mis was gone till well after motor heated up
    tells me it might be a coil but at least its not a bent valve like I feared
    think turbos, coils and or one of the ignition control modules on the air box?
    but why at the same exact time
    another thing I thought of was that the ground came off the tip of a plug and went through the drivers side turbo
    If it only needs turbos and coils than great ill park the car for a min till I have the money
    At least I wont have to pay the labor, drop the cradle and call it a day
    What do you guys think it could be?
