I think I originally got this idea from Charlie's AVant.
Got the dremel tool out today and hacked apart my ash tray. My Apexi AVC-R now resides there
Very carefully took the ash tray apart:
With some help of the small end-mill on my dremel this photo shows most of the material removed. A little at a time. Trial fitting. More cutting. etc..
Electrical tape around the outside of the EBC to prevent plastic-on-plastic rattling. I've also got tons of double-sided tape on the bottom. Its solid and doesn't move when you push on the EBC or push the buttons.
Fits like a glove:
Cover installed (I had to trim this little piece off the underside of the cover):
Recall out ash tray cover automatically goes up and automatically goes down. You push on it in the down position to allow it to open. Well, this little piece is what allows the cover to stay in the down position. I broke it when trying to reinstall.
After brainstorming on how to reinforce, and glue, the piece I broke I decided not to use it.
How to keep the cover closed? Some rare earth magnets holding it closed? Nah. When I was reinstalling the cover I accidentally put one of the torsion springs (that open the cover) in backwards. Hmm. Idea!
Driver side is installed correctly (aiding in closing the cover) [dust cover off]:
Passenger side is installed opposite (aiding in opening the cover) [dust cover off]:
I also increased the tension. Note the relief I cut out for the EBC wiring.
What does this do? It allows the cover to stay closed on its own and also aides in opening the cover. I push on the back of the cover to get it partially open. I then push on the front of the cover to fully open it. Not as 'cool' as the original operation but it works just as good.
Everything installed in the car. Very clean!
