Results 1 to 40 of 41
    Registered Member Two Rings Skydive@AI's Avatar
    Mar 14 2008
    Audi S4 Avant, GMC Syclone.
    Woodland Hills, CA
    Level10 for the Loss!
    As many of you know, my car was the second B5 S4 "full treatment" setups Level10 had done, four years ago, for use with my OTS APR Stage III kit. A few thousand miles after fitting Stage III, my car again went under the knife, and recently emerged with TiAL R650 Ball Bearing turbos. The Level10 transmission went belly up a couple of hundred miles later.
    After weighing options I decided to go with 517 Transmission this time, as Sam had been at Level10 but left with another expatriot to build his own operation, with an eye on honesty. He informed me of several of Level10's scams, and detailed all sorts of short cuts they take...
    He is now done with my "re-rebuilt" transmission, which is on its way back to California now, where it will be reinstalled in my car, and I we will have an opportunity to see what works....
    Here's an update. I am mindful of the fact that IPT is a major sponsor here at Audizine, so I will say that I have had no experience with them other than a couple of telephone conversations with John. John seems like a very nice guy, but he was unwilling to allow a third party observer to watch as my transmission was worked on. 517 was glad to have us. All three of these shops, (Level10, IPT, and 517 Transmission), are local to oneanother, and everyone seems to know everyone else. I did ask Sam for his thoughts about IPT's advertising, and he provided his thoughts.
    Here's what I know, which isn't all that much, but I am trying to educate myself. Sam has been quite forthcoming, and seems to be making an effort to be honest and forthright, which is a far cry from the others.
    Above, you can see the "spent" friction materials, clutches and reaction plates. According to Sam, the materials were all OE, and none of them appeared to have been replaced at any time. (Level10 be damned.) One can see that the clutch material is completely fried, and the plates are burned, (and apparently significantly warped though these pictures don't illustrate that very well).
    It's difficult to see, because the existing materials are used, burnt, and impregnated with fluid, but, according to Sam, the new material is of a much different quality, and should be much more durable and resilient. (These photos are worth a thousand words to him, but since I know very little about automatic transmission internals, it's difficult for me to do anything other than share what he's provided.)
    There is also an example of one of the original and replacement seals. The replacement features a positive fastener, while the original is merely a compression type of seal.
    You can also see the valve body "shims" which were placed behind the accumulator actuator spring by Level10. These are nothing more than hardware store washers. 517 has replaced the spring with a higher tension unit instead. Apparently, some other calibrations have been changed as well.
    The torque converter showed evidence of a trimmed stator and "bent fins". The stator has been replaced, and the fins properly adjusted for slightly higher stall speed.
    The pump seal has been replaced with a custom CNC machined piece, and all dowel pins will be replaced when the transmission is reinstalled.
    I did copy some text from IPT's website, and asked Sam to comment upon their package as follows:
    From IPT:
    * Valve body is custom calibrated to provide the ultimate in clutch application power and clamping force. Clutch apply time is greatly reduced and inadequate, sluggish line pressure rise is totally eliminated (The valve body modifications performed by us are of a proprietary design and are unavailable elsewhere).
    * Hi Energy friction plates and IPT laser cut, surface treated 1008 steel plates are installed in all shifting clutches.
    * *NEW FEATURE* We have now developed the industry's only 7 friction disk "C" clutch pack, 6 friction disk "E" clutch pack and 6 friction disk "F" clutch pack for a tremendous increase in second, third, fourth and fifth gear holding capacity.
    * New one way clutches (sprags) are installed in all locations
    * Planetary splines are heat treated to prevent stripping.
    * Cryogenic treatment is applied to input shaft and planetaries to eliminate stress related failure
    * Sun shell is heat treated to prevent stripping
    * Lube system is redesigned to provide increased flow and cooler operation
    * Lock up system is revised to improve converter clutch application, clamping force and torque holding capacity.
    * IPT's proprietary package of modifications represents the most robust and capable Audi automatic gearbox configuration available anywhere.
    Sam's comments:
    It's a line and a song saying what the original units are. Shafts and sunshells are already heat treated. If for example the planetary gears or any tooth of any spinning gear is strenthened, it will strip its counterpart that's not heat treated. In other words, if you strengthen one thing with out the other you only engineer an extremely weak result. The whole internal gear train must be temperature treated at extraordinary cost. You simply can not say, "Well lets upgrade the strength on this part but not this one." The stronger eats the weaker gear.
    As far as the adding of clutch packs goes, you are making the other clutches and steels thinner (and weaker) to add one clutch and one steel. This is a bad idea. Adding friction in a drum is retarded. Adding coefficiency is (clutch plate material) is the way to go, keeping the clutch count the same.
    The valve body thing is true except ours is as good, if not better. You do enough but not too much This is NOT a '69 Camaro.
    It sounds like someone likes to toot their own horn. The truth is told at 517, with no song and dance, if you may.
    In any case, we shall see. My transmission is on the return leg, and will be back in Los Angeles next week. I am inclined to trust Sam's word as he could have promised the moon and extracted more from the wallet, but he chose to advise against things and have me keep my money where appropriate.
    If any of you have experience with automatic transmission components and can see anything in these photos beyond that which I have been told, please share.
    If you'd like to find 517, please contact them directly, in Ogdensburg, New Jersey.
    -Michael.
    Feb 17 2008
    Ottawa Ont.
    Re: Level10 for the Loss!
    crap thats right on the border with canada. like 40 minutes from my house!
    edit, ive been informed by a passing penquin that my knowledge of american geography is lacking.
    Jan 17 2005
    2001 S4 - 2018 Subaru Legacy
    New Jersey
    That's real clost to where I live too. Maybe 30 - 40 minutes. Keep us updated. If I ever get to go stage 3 then I'll need someone reliable and honest!
    Active Member Four Rings
    Dec 11 2006
    Boston
    With all the money you have probably dropped into this tranny, why haven't you tried to do a M/T swap? Yes it is a lot of work, but I think it might have been worth it. Hindsight of course is 20/20.
    Stage 3+ RS6's
    Mar 14 2008
    Woodland Hills, CA
    Quote Originally Posted by deb38 View Post
    ...because I have surgical steel in my right hip and left femur, following skydiving accidents. I can drive a manual for fifteen minutes before things really begin to hurt.
    I do appreciate the thought.
    Dec 11 2006
    Boston
    Oh sorry, yeah that probably wouldn't help your cause.
    I like you noted accident(s), plural!
    Stage 3+ RS6's
    Mar 14 2008
    Woodland Hills, CA
    Yep... two of them, eleven years ago, eight months and 100 jumps apart. I've made several thousand jumps since, and not injured myself beyond a twisted ankle or riser slap now and again.
    I learn slowly, but I do learn.
    -Michael.
    Active Member Four Rings FrimmelNoJerz's Avatar
    Sep 21 2006
    Norjerz
    IPT can slurp my left ball. the last 6 thousand miles in my car were completely miserable because of them and their shit transmission. coasting from 2 to 1 could actually shoot passengers out of their seats because it was so jerky.
    SBSC
    I also like to live dangerously.
    Veteran Member Three Rings ThePaintballGuy's Avatar
    Mar 14 2007
    Phoenix Arizona
    Quote Originally Posted by Skydive@AI View Post
    -Michael.
    What happened??? I am jumping now to. Will have my "A" license in 3 jumps (hopefully next weekend ).
    As for the transmission I was looking at IPT if I ended up going Stage 3. Maybe I will re-consider now depending on what happens with this tranny.
    Josh
    Aug 30 2007
    nyc
    I have the ipt trans and my car is not jerky........... ~danny
    c5 A6 tip
    this n that
    Jun 14 2007
    2000 S4
    Connecticut
    Quote Originally Posted by FrimmelNoJerz View Post
    Mar 14 2008
    Woodland Hills, CA
    Quote Originally Posted by ThePaintballGuy View Post
    Josh
    Josh,
    I had accident number one at 40 jumps: Unstable opening followed by deployment through my legs, resulting in a horseshoe malfunction of sorts, and then an uneventful cutaway.
    I had accident number two at 138 jumps: Freefall collision with a camera flyer following poor communication when I was learning some freeflying.
    It's no more dangerous than snowskiing or scuba diving given proper respect...
    Have fun, be safe, and remember that it CAN happen to you if you let it.
    Blueskies!
    Mar 14 2008
    Woodland Hills, CA
    Quote Originally Posted by dannyn424 View Post
    Which options did you get with your package? Generally, the valve body work is what creates the very stout downshifts.
    Aug 30 2007
    nyc
    as far as i know i got every option..vb,tc, etc.... i had to pay for labor twice...... i tried to just do tc but if fed up... other than that the car shifts ok........ just like stock with a slightly firmer shift...........
    i go t a 12 month warranty but they said thwey would help with anything out of the ordinary (I dont beat on the car or anything really).. i should be ok for stage 3 if the time comes...........
    c5 A6 tip
    this n that
    Mar 14 2007
    Phoenix Arizona
    Josh,
    Blueskies!
    Oh yeah... I know I was just wondering what happened. LOL. I haven't really had any mishaps yet... I did have a canopy collapse on me on my 13th jump to to flying through a dust devil that I couldn't see. ALmost cut away but got it back open.
    Hope you get everything worked out with the tranny!
    Josh
    Active Member Four Rings Maverick's Avatar
    May 03 2007
    german
    heaven/hell
    this is very good to read because I am about to get s/c'ed and i only need to upgrade my torque converter.
    I had heard before that level10 uses home depot parts for their transmissions but not this shitty quality.
    OP, does 517 transmission have a website that I can look at? if not I will just call them to get a quote
    F80 M3 DCT|C250 Coupe|i3|16 RS7
    B6 A4 3.0 back to stock |B8 S4
    E46 M3 Heavily Modded IR/Black Cloth - track car
    E46 M3 TiAg/IR Moton/GC Track Ready - sold
    E92 M3 Melbourne Red/Black cloth/CF Roof - Exported
    E93 M3 AW/Black Sold
    E39 540iA Minor front end mods. Smashed|E39 540iA Aggressor - sold
    W126 1989 560SEC Totaled
    Bentley Continental GT Black/Black Mulliner Package - sold
    Porsche 944 NA - totaled
    Senior Member Two Rings schusters4's Avatar
    Dec 13 2007
    Portland
    Hindsight 20/20 but I did a full stage 3 upgrade and upgraded the tc and vb as well and I just got my transmission back from repair. The amount of power that a stage 3 2.7TT makes is too much for our tip transmissions. The torque from the engine acctually makes the transmission shift too much causing other weak parts fail.
    Veteran Member Four Rings Reich's Avatar
    Oct 14 2007
    2001 s4 ; 2001 jetta tdi
    Val-Belair
    Than's for your tips Micheal. Too late now i'm with ipt t/c and valve body. We shall see. I'm also with f..king big turbos. Only need my injectors and walbro for tuning now. Can't wait to put the car back on the road again.
    Veteran Member Three Rings MiniRS4's Avatar
    Aug 11 2005
    nice write-up, love learn something new all the time. speaking of which, ever think of learning how to drive a stick and giving 6MT a shot.
    i think you'll thank me/yourself later.
    Sep 21 2006
    Norjerz
    i guess you skipped the part where my man had surgery and cant drive stick for more than 15 minutes because of the fact that he's in great pain. you're 0-2 tonight so far sweetheart.
    SBSC
    Mar 14 2008
    Woodland Hills, CA
    Quote Originally Posted by schusters4 View Post
    Hence the additional enhancements beyond the valve body and torque converter.
    This is the big experiment. None of the "hard" parts within the transmission seem to fail. It is our hope that the improved friction materials as installed by 517 Transmission will allow things to work better, longer.
    We shall see!
    -Michael.
    Mar 14 2008
    Woodland Hills, CA
    Quote Originally Posted by MiniRS4 View Post
    YASTI! (No, really... you suck at the Internet).
    As stated above, I can drive a six-speed for a very short time. Due to previous injuries and hardware now holding my leg and hip together, I must drive clutchless to avoid pain.
    Thanks though!
    -Michael
    May 03 2007
    german
    heaven/hell
    So Michael, from your conclusion and after carefully reading this thread again. 517 transmission is the way to go?
    Mar 14 2008
    Woodland Hills, CA
    Quote Originally Posted by Maverick View Post
    Maverick,
    At this time, I would say yes. 517 Transmission is the best of the four options I have found. In my experience, Sam has been dead honest with me, and has gone a lot further than the others to make sure that I get what I paid for, and there is no B.S. involved. Further, he and his partner took a good, hard look at my transmission to see what could reasonably be done. They knew and welcomed the fact that my car is relatively high profile, and that the results will be equally public.
    The caveat is that I won't actually have my transmission back from them for another couple of days. I can say that my experience with them has been far and away better than any of the others... but I haven't been able to put the work to the test, yet.
    -Michael.
    May 03 2007
    german
    heaven/hell
    can you give me their contact info? like how I can talk with Sam. I googled this company couldnt come up with anything. I need to order a Torque converter for my 3.0
    Mar 14 2008
    Woodland Hills, CA
    Sam Ismail
    517 Transmission
    (973) 823-6320
    Please let him know that I referred you. (Michael in California). He's been good to me, and I want him to know that I intend to get the word out.
    -Michael.
    May 03 2007
    german
    heaven/hell
    will do that sir. thank you
    Dec 13 2007
    Portland
    how's the transmission holding up? Just got mine fixed two weeks ago and it's back in the shop leaking all over the place.
    Mar 14 2008
    Woodland Hills, CA
    It came back from 517 on Friday. We've not had a chance to install it.
    Who did your transmission work?
    -Michael
    May 03 2007
    german
    heaven/hell
    ok I called them yesterday and I am going to do Torque Converter and Valve Body
    Dec 13 2007
    Portland
    -Michael
    Level10............. for the loss....
    i can vouch for their torque converter. i have one on my asp stage 3 setup, and i was afraid my TC was going to be first thing to go so i sent it to WMS to get it upgrade, only to find out WMS sent it straight to 517 trans and didnt do any of the work inhouse.
    the TC help up to my overboosting ASP setup and was working fine. the transmission itself however would just keep going into limp mode, and finally i blew out my clutch pack e.
    so my 517 TC held up nicely, no codes as i verified with my vagcom every day.
    i can say the clutch failure was due to lack of line pressure from stock valve body and exceeding the holding capacity for torque output from the engine
    since i had good luck with 517 i will probably get my rebuild from them as well
    Mar 14 2008
    Woodland Hills, CA
    Quote Originally Posted by goohead View Post
    For what it's worth, Mike/WMS reconnected me with 517 as well, even though I had been in touch with Sam years ago, when he was at Level10. Very few shops, (even dedicated transmission shops), do work in house on torque converters. It takes some special tooling and expertise to do it right, and very few torque converter specialists market directly to the public, so it's not surprising that Mike sublet your work to 517. That's how it's done.
    Anyway, we're making some last minute tweaks to some other parts of my setup, so the car is still on dollies, and the transmission is still on the pallet.
    I will certainly keep everybody advised as things go back together.
    -Michael.
    bump for any updates :)
    Senior Member Two Rings 70 eliminator's Avatar
    Aug 28 2010
    colorado 7300 ft
    3 year bump!!!!!!!
    Jan 03 2010
    Gloucester Ontario
    wow does time ever fly. Didnt he give up on this?
    Jan 17 2005
    New Jersey
    Here is a quote from him from 10-30-2008 11:59 PM
    Original Posted by Skydive@AI
    Actually... I fried a Level10 transmission, then a 517 Transmission. The Level10 setup was scam. The 517 build is perfect for K04s or K04 hybrids.
    I could probably throw more money at it and make it work, but the result would not be a car worthy of the comfort and style afforded by the Audi S4. I've decided to restore it to Stage II+ condition, and build something else that lends itself to big power through a clutchless gearbox. (I have steel in both legs from poorly executed skydives.)
    -Michael.
    Veteran Member Four Rings Rdp616's Avatar
    Mar 23 2009
    Hibiscus S4
    SW, Pennsylvania
    I honestly didn't read all of the OP..Once i saw the TIP parts i kind of shaked my head..Not to be a dick to the OP, but why put all that money in a TIP? M/T swap it and call it a day (i'm sure you've heard that before tho). Tip transmissions in general are suspect. But, that doesn't excuse the fact of how you were royally screwed.
    Edit: Holy fuck 4 year old thread.
    Single Turbo Hibiscus coming soon
    Established Member Two Rings ATCOs4's Avatar
    Aug 25 2011
    2011 Jetta SE (wifes sweet daily)///1965 Honda CB160
    wichita ks
    once again it was previously stated by op that he had several skydiving accidents and hardware in his hip/legs causing immense pain driving a 6speed for more than a few min.
    as for old thread i read through it all before i realized it was an old thread so dont feel to bad haha
    Mar 23 2009
    Hibiscus S4
    SW, Pennsylvania
    Quote Originally Posted by ATCOs4 View Post
    Yeah, didn't see that part. Well, i admire his deadication to that tranny and getting it to work.
