Results 1 to 7 of 7
    Senior Member Three Rings erikas3's Avatar
    Feb 08 2008
    2003 Jetta GLI 24V
    Tinley Park, IL
    Squeaky Suspension
    As the title states, my front suspension started squeaking really bad. Whenever I turn the steering wheel or go over rougher road, it squeaks. However, it mostly squeaks when there is load on it (wheel on ground). From what I understand, it's the lower control arm that connects to the subframe or the sway bar link. Is there some way to lubricate this part or is it time to order another one? Thanks
    1998.5 Audi A4 1.8T (Hibiscus Red)
    Soon to be BT...
    Registered Member One Ring Shorty75's Avatar
    Jun 11 2008
    Raleigh, NC
    Re: Squeaky Suspension
    No zerk fittings on any of my joints. When mine was squeaking it was only a week before there was noticable play in it and I had to replace one of my uppers. Of course the pinch bolt broke and it turned into a 2 day bolt extraction. Lift the tire off the ground and push/pull the tire at different angles to see if there is any play in your joints, it may be your tie rod end also. That is what was squeaking on mine.
    Feb 08 2008
    2003 Jetta GLI 24V
    Tinley Park, IL
    Quote Originally Posted by Shorty75 View Post
    I already tried moving the wheel around with it off the ground and there isn't any play in it.
    Soon to be BT...
    Senior Member Three Rings LowSantorin's Avatar
    Oct 19 2007
    Dub State
    Check all the control arms. i have the same problem, well i did then it went away for a bit and came back worse. It only does it sometimes now but i also have a very annoying "clunk". Oh well control arms will get dropped off tuesday nad i wont have to worry about it after that.
    Awaiting Confirmation One Ring
    Feb 19 2008
    99.5 A4 Quattro 1.8tqm
    Columbus, Ohio
    had the problem replaced the all the control arms and called it quits lol, but i think it was the ball joint that was makin all the noise
    Veteran Member Three Rings BONFIRE074's Avatar
    Aug 13 2007
    sounds like a control arm bushing
    2004 Subaru Impreza WRX
    Aspen White
    Feb 08 2008
    2003 Jetta GLI 24V
    Tinley Park, IL
    Quote Originally Posted by BONFIRE074 View Post
    Do you know the bushings sell separately for the front control arms? Thanks
    Soon to be BT...
