finally got around to doing this.. i figured out that halogens are a pain in the ass since u cant remove the projector to take the reflector out so u have to slide it under the housing. (takes a while since u have to cut the reflector in pieces) nonetheless i got it done anyway. also, i highly advise using a small drill bit to break the reflector tabs. it came out alot cleaner with only a single pin hole..while the silicone dried i did the stealth bulbs mod front and rear.. heres some pics, enjoy!
before:
after:
