Results 1 to 7 of 7
    Senior Member Two Rings Switchblind360's Avatar
    Feb 26 2006
    '01 allroad 2.7T TIP, '95.5 S6, '91 200
    Boise
    235/45/18 Tires. Anyone try these for fitment?
    I just did a suspension swap, and now my 255/40/18 Dunlops are WAY too wide to fit up inside my wheel wells.
    Since I live in an area with roads that are filled with potholes, bumps, uneven pavement, etc. I was thinking of trying a plus size aspect ratio tire to smooth out the ride and help add some cushion to my rims.
    Anyone try this size? I am fully aware of all the other changes that plus sizing will make, but I am really concerned with whether or not the fronts will clear the tight fit of the upper arm.
    The 255/40's fit and by deductive reasoning, they are the same height as a set of 225/45's. Does anyone know what the height difference would be between 225/45 amd 235/45?
    HELP!
    '00 Audi A6 2.7TM
    HB Nefmoto Stage 3
    '91 Audi 200 QTM 20v
    TAP Stage I
    '01 Audi allroad 2.7T TIP
    Homestyle Nefmoto Stage II, 402 Mod
    '95.5 S6 QTM 20v
    034 Stage I
    Veteran Member Four Rings belinko's Avatar
    May 09 2005
    Audi 1.8T QM
    Encinitas, CA
    Re: 235/45/18 Tires. Anyone try these for fitment?
    Here you go.
    http://www.rims-n-tires.com/info_specs.jsp
    google is your friend
    1.8L, JE pistions, IE rods, APR stg3+, GT28 Turbo, Setrab, ER comp. FMIC, APR HFC, Milltek Cat-back, APR 91, 93, 100 - CM FX 300, CM 240 LWFL, JHM 4:1, AMS SS, RS4 Motor Mounts - 355mm Alcon 4 pot, 300mm Alcon S4 - Stasis/Ohlins MS, Hotchkis Front and Rear, Stern adj. CA Front, 034 adj. CA Rear - 18x8.5" Work CR Kai wheels, NT-01 & Dunlop Z1 star spec - RS4 Front bumper and grill, Tow Strap, RS4 E-codes - SPA Technique Dual Digital gauges Oil & Water temp, Oil & Boost pressure, RS4 Door Handles
    Feb 26 2006
    Boise
    Vielen Dank!
    '00 Audi A6 2.7TM
    HB Nefmoto Stage 3
    TAP Stage I
    '95.5 S6 QTM 20v
    034 Stage I
    May 09 2005
    Audi 1.8T QM
    Encinitas, CA
    Bitte Schon
    Veteran Member Four Rings oc-drop's Avatar
    Nov 20 2005
    B7 A4, C5 A6, 79 Camaro
    Newport to Rancho Sta Marg
    das auto!
    ~Rick .. currently driving a B7 3.2 S-Line 6MT Dolphin Grey | DTMish | EuroGEAR CF Hood | H&R | sick halogen Ecodes | AZ Plate frame
    is it 4:20 yet?
    Veteran Member Four Rings Gigi's Avatar
    Jan 23 2006
    2004 Audi A6 2.7T, 1999 Jeep W
    Charlotte, NC
    Qu'est ce que vous disez mes amis?
    if you're worried about width to clear control arm, 235 should clear as it is the normal width for a 2.7T, But in 45 tire wall ratio it'll be taller. DO you have good clearance up? fender side?
    Have a great day, Brice
    99 Jeep TJ, 4" lift, Mikey Thompson rims & tires
    http://i157.photobucket.com/albums/t...i/photo-22.jpg
    http://i157.photobucket.com/albums/t...20TJ/Jeep2.jpg
    SOLD: 04 Blue [B]A6 2.7TStage 2 +: Many mods
    Veteran Member Four Rings FrankA6's Avatar
    Mar 30 2008
    2004 A6 2.7T, 2012 Volvo S60 R-Design
    Pittsburgh
    ehhh, i don't think i would go with 45's, get 235/40's , then it should look good and work better.
    2004 Audi A6 2.7T
