Results 1 to 40 of 41
    Veteran Member Four Rings VTAudiA4's Avatar
    Oct 20 2007
    Not a virgin anymore (PICS) [o_o]
    So I finally bought everything I wanted for my engine setup. I will be upgrading the turbo so Im not virgin anymore but a modified Audi. I will give you guys a break down so you know how cheap this hobby is. The install will be done half by me and half by Nate's Automotive. I don't have all the tools and Im still new to turbo cars (I will admit it) so they will help me out.The owner there has a sick Ibis white S4 with K04's and a bunch more. He ran a 12.1 last time. He said next summer he is going GT series turbos and custom everything. It was one mean machine.
    Note that there are some things not pictured. Racetec FMIC is in the mail, as well as my borla, and my carbonio, TT, and EBC are already installed. My parts are both new and used.
    K04-015 w/new install kit: $460
    ATP manifold(new version): $200
    GIAC J-31, 317cc injectors, AFPR: $610
    Labree HFC: $280
    Carbonio: $210
    HKS TT: $40
    Greddy Profec B Spec II: $250
    Ractec FMIC: $830
    Borla Exhaust: $650
    Forge 007 DV: $125
    Oil, plugs, filter, drain plug, gaskets
    Knowing that I will have a reliable setup: Priceless
    This setup will also allow me later to upgrade to BT possibly with ease.
    Veteran Member Four Rings GetBoosted84's Avatar
    Apr 10 2007
    01 Audi A4 1.8T Quattro / 88 Mazda RX-7 GXL
    Eastern PA
    Re: Not a virgin anymore (PICS) [o_o]
    Make sure you put a de-fouler in your secondary o2 sensor for the labree. You will be kicking yourself in the butt if you don't when you get a CEL from it.
    I have a labree also and I wish I would have put a defouler in there when I put it in.
    BTW, good luck with the setup. Your going to love the low end torque with that setup. I know I do.
    Oct 20 2007
    Quote Originally Posted by GetBoosted84 View Post
    Could you go into more detail about this. I haven't heard about a defouler mod for a HFC. I know about TP's. Is yours a 400 cell count?
    Apr 10 2007
    Eastern PA
    Yep. Got mine made a few months back. After a month or a month and a half I started to see the effeciency CEL (shown below). I noticed after I went to Englishtown with my car and a CEL came up on the way home so I checked it and bang, there it was.
    16804 - Catalyst System: Bank 1: Efficiency Below Threshold
    P0420 - 35-00 - -
    I cannot think of a downside to installing the defouler since the 2nd o2 sensor is only used to check whether your cat is working or not so by installing the defouler beforehand you will prevent a headache later on.
    Oct 20 2007
    Do you have a link to the defouler mod for the hfc?
    Apr 10 2007
    Eastern PA
    This is what you are looking for:
    I just went to pep boys and picked up a set for less than 3 bucks.
    EDIT: Here is a link to what you want to do with the defouler. You want to drill it out:
    http://my.is/forums/f88/o2-sim-adapt...r-25-a-354011/
    Oct 20 2007
    I see. Thank you so much. Appreciate the heads up on such a little problem.
    Apr 10 2007
    Eastern PA
    NP. Should save you a headache later on.
    On a positive note, the fitament of the labree HFC is fantastic. It mounts just like the OEM unit.
    Oct 20 2007
    Did you use 2 or 1? Oh and its the 18mm (42002) pug?
    Apr 10 2007
    Eastern PA
    I used 2 just because I didn't want to have to do it twice.
    Veteran Member Four Rings jrock's Avatar
    Oct 02 2007
    Lone Tree, Colorado
    i have been runnin one for about 10k miles without one and i have the labree also just ta let ya know. You might not need it.
    Oct 02 2007
    Lone Tree, Colorado
    you should also do there downpipe if you end up doing an exhaust. the stock downpipe can restrict a lot of flow also.
    Apr 10 2007
    Eastern PA
    Lucky SOB. I wish I could say the same for me. What year are you btw?
    Oct 02 2007
    Lone Tree, Colorado
    99.0
    Apr 10 2007
    Eastern PA
    Maybe it's just my luck with the 01.
    Veteran Member Four Rings Mooseimage's Avatar
    Feb 15 2008
    2007 Audi A4, 2017 Audi SQ5
    Sacramento, CA
    If we do the defouler mod, it tricks the 02 sensor, but if we are required to do smog (cali), will it pass, or will they say no because of it? Cause I would really love doing a high flow cat or dp, but don't want to deal with the hassle of changing my exhaust every time i need to do a smog check. So would it pass or fail?
    GCC Rule #22 Enforcer
    marty was here: id stay away from the womb that gave birth to fail
    2007 Audi A4 2.0T MT Avant: JHM Stage 3 goodness
    2017 Audi SQ5: Stock (for now)
    Oct 20 2007
    Quote Originally Posted by jrock View Post
    99.0
    Hmmm I am a 00 so I wonder if it will throw me a code. Anyone?
    Veteran Member Three Rings khj677turbo's Avatar
    Dec 25 2007
    Tampa
    Why does it say ATW on your ecu?
    Current: 13 A4 P+ Sport, K04 etc, 18 SQ5
    Gone: 04 A4 1.8t USP 6-speed Avant
    Gone: 00 A4 1.8t K04'd
    Dec 05 2007
    I have an 01 and installed a Labree couple weeks ago. When I called the shop to order mt cat, the owner told me that he only makes 400 cell ones (I still don't know what that means). I first asked him about how I read threads of how people get CEL bc of his cat, but it was a great product. Then he went to tell me how he only makes 400 CEL ones now because of that. People would get CEL on 300 cell and so forth.
    And as for your exhaust. I believe the Borla has a 2.5" downpipe to 2.5" exhaust. If you plan on going big turbo, it would be a wise investment to return that exhaust now before you install for a full refund, and get one with a wider exhaust. Maybe at least 2.75". When you go BT (GT28rs+), the downpipe will be 3" and to have that travel to a 2.5" exhaust is restricting flow. I have 2.75", so mine will not be that bad. Custom is maybe the better route to take. Most shops can make you one (you choose downpipe, exhaust brand and diameter) for around $700+ installed. Cheaper than the Borla, and better investment.
    Make sure you get a good diameter depending on how much power your going to be putting out.
    2.25"-ko3 power
    2.5" to 2.75"-ko4
    2.75" and up- BT
    Either way to your set up man. Hope you like it.
    Oct 20 2007
    Quote Originally Posted by khj677turbo View Post
    The previous owner wrote it on the ecu.
    You are correct about the exhaust but Im not thinking about going BT for at least another 2 yrs so the borla is just fine for my setup. I only paid 650 shipped for a new borla so it was too good of a deal to pass up. Also when I do go BT I will sell the borla and get a custom one made like you said.
    So you didnt get a cell with you Labree?
    Dec 05 2007
    Quote Originally Posted by VTAudiA4 View Post
    Nope. What prompted me to get the Labree more, besides the price, was that Onemoremile has been running with his for years with no CEL.
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    Sounds like Labree made a change. I've been running one for a few years without a cel. The newer ones may be different. Mine used a Magnaflow cat and arrived in a Magnoflow or carsound box. I think it was summer 2005.
    Jim
    I Do Werk.
    Apr 10 2007
    Eastern PA
    Quote Originally Posted by onemoremile View Post
    Yeah thats weird. I was told mine was a 400 cell also. Maybe being at the track all day launching my car at about 4k rpms destroyed the material in it (long shot but it might explain it).
    Veteran Member Four Rings 20A4Audi1.8t01's Avatar
    Oct 08 2005
    '16 SQ5 '07 Corvette
    Orlando, FL
    Congrats welcome to the KO4 club
    -Brilliant Black 01.5 A4 1.8T Fronttrack Tip-
    GIAC Hammer KO4|APR TIP|Modded Carbonio V2|RaceTec FMIC|Forge 007p|SPP EFK|PSI TP|TT 2.5 DP|Custom 2.5 Magnaflow Exhaust|15% LLumarTint|215/40/18x8.5 RS4 Reps/Nitto Neo Gen|Ecodes|RS4 Grill|H&R Coils|Rieger Roof Spoiler|Pioneer AVIC-D3 NAVI|Cadence 10|JL Audio A6450|Almani door speakers|Cadence amp|8000K HID|3000K HID Fogs|In Pro mirrors|S4 Front/Skirts/Brakes|Cupra R lip|Apikol snub|All Red Tails|Shaved Euro Trunk
    Veteran Member Four Rings 20vpower's Avatar
    Oct 05 2006
    1998 A41.8TQMS
    San Jose, CA
    your going to love that hi flow mani. it really opens up the top end. and if you are installing the mani, you need to start all the mani nuts first before you push the mani fully onto the studs because some nuts will not go on if tighten one down. also bend a wrench because its a pain in the ass to do it with a straight wrench
    Previously: 12vPower
    97 12v fwd CACTUS GREEN (SOLD... thank god)
    98 1.8tqms MELANGE 50 trimd
    Oct 20 2007
    Quote Originally Posted by 20vpower View Post
    Thanks for the tips.
    Quote Originally Posted by 20A4Audi1.8t01 View Post
    Im glad to be in it.
    Oct 20 2007
    Not only did I just join the K04 club but I just reached FOUR RINGS.
    I could have not done this without my fellow Audiziners. I would like to thank Jesus, God almighty, and all the little people. I would like to thank my fans, family, and friends. I just dont know what to say, Im speechless.
    Sep 17 2006
    07 cbr600
    You should be fine with the 2.5" borla if/when you go BT. There are plenty of people running Borla or APR 2.5" exhausts one their cars with BT. $650 is a nice price for a full exhaust so no need to worry about returning it or any of that shiz.
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    2.5" here on my T28
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Veteran Member Four Rings sean1.8t's Avatar
    Sep 17 2006
    I wish I had a garage.
    SLC, UT
    i don't understand the problem
    it's not hard to throw on the defoulers when the HFC/TP is installed. i got a CEL when i only had 2 spacers in there on my old 01 so i took 10 minutes and added a 3rd one. problem solved. it's not difficult
    Current:
    '16 Mercedes-Benz C450 "AMG": Stage 2 w/downpipes & 19" BBS CH-R's
    '88 Harley-Davidson Sporty 880: 1200 bottom - Ported & Cam'd top - S&S In - Screamin' Eagle Out
    Previous:
    '02 Audi A4 1.8TQM: Full GT28RS on meth w/everything else.
    '01.5 Audi A4 1.8TQMS: Tune and exhaust.
    '99 Subaru Legacy Outback wagon Manual: Bone stock.
    I don't even want to remember the others
    Sep 17 2006
    07 cbr600
    Quote Originally Posted by sean1.8t View Post
    word to that i can reach my 2nd o2 sensor with it on the car no problem
    Oct 08 2005
    Orlando, FL
    wurd x2!
    Oct 30 2006
    B8 A4 Avant 6spd
    Go full 3", with a gutted S4 muffler it was not loud unless I went WOT.
    < - - 14.6 1/4 mi K03 with my setup.
    -18 718 GTS
    Apr 10 2007
    Eastern PA
    Its just a pain in the butt to get back there to put them in. Much easier if I would have just tossed them in there from the start. Less aggravation and CELs.
    Veteran Member Four Rings Nebone's Avatar
    Jan 21 2006
    6MT BT Avant Ti
    RI
    There is a simple explanation to the Labree deal.
    2000 and 2001 cars run ME7 management using a wideband oxygen sensor which detects catalyst efficiency much more precise than ME5 cars which are 1999 and down. I have a 300 cpsi Labree designed catalyst and it did throw a cel and stayed on after a few months of use.
    Bottom line is, use the spacer. Onemoremile has a ME5 management.
    Ibis White 2008 Audi A4 2.0T Avant 6MT S-Line Titanium APR Stage 3
    Deep Sea Blue Pearl 2010 Audi A4 2.0T Premium Tip
    Dolphin Grey 2005.5 Audi A4 2.0T Avant 6MT *Sold after 7 years of ownership*
    Goodwood Green Pearl 2002 Audi A4 1.8T Sedan Tip
    Santorin Blue Pearl 2001.5 Audi A4 1.8T Sedan 5MT *Sold after 9 years of ownership*
    Dec 05 2007
    Quote Originally Posted by Militant-Grunt View Post
    I am just flashed with HFC and cat back exhaust (Milltek). When I go BT, I will maybe just sell the exhaust+hfc for maybe $700 and get a B5 S4 Milltek .Love that sound note.
    Quote Originally Posted by nebone22 View Post
    So, one should get that spacer for the 02 sensor? Does it have to be for secondary, primary, or both? I want to get this done before the CEL arises. Thanks!
    Jan 21 2006
    6MT BT Avant Ti
    RI
    First of all, the S4 is a V6 Twin Turbo so different sound note. The S4 exhaust is differently routed since its dual exhaust into single muffler so wont work for 1.8T.
    Put that spacer on the 2nd O2 sensor. Leave the first as is.
    Dec 05 2007
    I meant the sound note of the Milltek in general.
    Edit: Is there a particular size for the non fouler?
    Edit 2:
    Correction, not the S4. But the 3" single
    Jan 21 2006
    6MT BT Avant Ti
    RI
    Keep your Miltek for the bigger turbo man. Quiet is nice.
    Look on this thread, its all about this foulter. That HELP thing from autozone. One that fits the sensor.
    Jan 21 2006
    6MT BT Avant Ti
    RI
    The ME7 management is just more sensitive for the emission regulations. Best way to eliminate the CEL is a an adjustable spacer. Guy on Vortex makes them and I'm about to purchase one.
