Results 1 to 11 of 11
    Jun 14 2008
    Vestby, Norway
    Question Changes in the TT?
    What changes where made, technical and cosmetic, in the TT from 1999 till 2001? Need to know if there's some important improvements or something.
    Thanks
    Veteran Member Four Rings InTTruder's Avatar
    Aug 21 2007
    2019 VW Tiguan
    Kennesaw GA
    Re: Changes in the TT?
    Only significant change ws the availability of the 225 HP (dual SMIC) versus 180. No other significant issues until the 3.2 in 2004 (? IIRC), and then the MkII.
    The Spartans do not enquire how many enemy there are. They enquire only where they are.
    Jun 14 2008
    Vestby, Norway
    Thanks. So no improvements in previous faults or things like that?
    Aug 21 2007
    2019 VW Tiguan
    Kennesaw GA
    Define previous faults.
    I have a 2000 with 116K running strong. The cluster and temp switch have long since been replaced. All is well.
    Jun 14 2008
    Vestby, Norway
    I wasn't referring to anything special. Just wondering. If there is any particular reasons to buy the 2000/2001 instead of the 1999. Except the age obviously. Cars are really expensive here in Norway you see
    Aug 21 2007
    2019 VW Tiguan
    Kennesaw GA
    Get quattro, whatever you do. The US spec (and maybe euro) 2000+ had the spoiler refit after a recall: early TT in US did not have the spoiler.
    Make sure the timing belt has been done on a 70K (miles) interval, along with a new water pump (metal, not plastic) and tensioner EACH time.
    Veteran Member Four Rings redlabel81's Avatar
    Nov 24 2007
    A4 1.8TQ 2005.5 + A6 1.8T 1998
    Tromsoe, Norway
    So you have had to change your complete cluster?
    Life is too short to drive ugly cars!
    Phantom Black B7 A4 1.8TQ Avant
    //BSR PPC stg 1, 98 Oct//BSR cat back//S-line front rebuild//S-line suspension//Supersport loweringcaps//Votex valence//S4 doorblades//RS4 mirrors//S-line roofspoiler//S-line door sills//LED interior//Hoen fogs//mTec 6000k HID//RNS-E//S4 grill//MMR HR4//H&R 8mm//Dectane HL//LED licenseplight//Euro RS4 steering wheel//Sonniboy "Tint"//RS4 rear sway//
    Aug 21 2007
    2019 VW Tiguan
    Kennesaw GA
    Nearly everyone did already. Class action suit I/P too (See AW TT Forum). Happy as a clam at 116K: car has seen 153 indicated on Road Atlanta, and it still makes me smile. All-in-all, too much fun. I've had P-cars and American iron: nothing comes close.
    Nov 24 2007
    Tromsoe, Norway
    Nice! So the cluster is a guarantee issue...:)
    Registered Member Two Rings
    Mar 25 2008
    Newton, Ma.
    I filled out paperwork and sent the receipt for reimbursement Class action suit I/P too for the cluster but havent heard anything back:-( I was curious what happens next?
    regards,
    lee
    Aug 21 2007
    2019 VW Tiguan
    Kennesaw GA
    CLuster is NOT a guarantee. Age, mielage, etc factor into resolution.
    Only the lawyers will make any money.
