Results 1 to 8 of 8
    Veteran Member Four Rings Ace's Avatar
    Nov 29 2005
    Belgium
    Decided to drive around with the A4 a bit longer, now tuning BT or 2.0
    I wanted to get rid of the A4 this year to get a S5.
    But after reading that Audi plans a 3.0 TFSI engine for the S5 in 2010 i decided to stick around a bit longer with this car untill that one is out.
    3.0 TFSI sounds better then 4.2FSI in my opinion, at least if you want to have some more horses.
    So now the question for me is what i will do this one.
    Go for a BT setup or do a 2.0 setup
    i have read up on both subjects a bit, but i still unsure which one would be the better choice.
    Veteran Member Four Rings PRY4SNO's Avatar
    Jun 28 2007
    1990 Coupe quattro with all the parts
    Edmonton, AB
    Re: Decided to drive around with the A4 a bit longer, now tuning BT or 2.0
    Depends on the driving you want to do.
    I'd say do a BAT 2.0 stroker just to be on the safe side.
    Maybe some of the OGs (mike, shawn, clint, jordan, greg, et al) here could shed a little light on the pros/cons of each...
    2013 Touareg TDI Execline /// Farmenwagen: Malone 2.5 tune, Darkside & Rawtek Delete
    1992 80 quattro 20v /// Eventual AAN'd Winter Sled
    1990 Coupe quattro /// Because Racecar
    Registered User Four Rings
    Feb 26 2006
    Over 20! too many plant pots!
    Earth
    Usually people do both as with the stroker set up you are pretty much rebuilding the motor.What turbocharger you have now?
    Nov 29 2005
    Belgium
    I did a upgrade at a local tuner(Heinz tuning) they changed the turbo but it was a custom made one(they called it a IHI Hybrid turbo)
    Feb 26 2006
    Earth
    ah yes....Europe...IHI/KKK land
    Real men run Garrett's :P
    Nov 29 2005
    Belgium
    Quote Originally Posted by Issam@034 View Post
    tell me about it lol, i gave them a chance.
    but i want something better and faster
    Jun 29 2007
    Raleigh, NC
    what tuning are you running with that turbo? any specs on sizes? (wheels, housings, what flange, etc etc)
    12.5 best ET -- 113 best trap
    The Awesome™
    BetaAlphaTau Member #42
    Nov 29 2005
    Belgium
    Never was told any details on the setup, thats what i hate the most.
    And it does less then a BT most people run here.
